3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Everything about a bass: How to play, pick out, and have fun with an electric bass
So deterring from my usually computer type insructable, I decided to make an "artsy" one. I am not a master bass player, but I've been playing for 3 years and know a little about what I am talking about.
Step 1Picking out a bass
Picking out a bass
If you have a bass already, just skip this step and buy an amp if you don't have one.
The first step of picking out a bass is NOT deciding the budget, however if you truly never have played a stringed instrument before a bass you get a Walmart with the amp should be sufficient.
If you have played guitar before, or don't ever plan on buying a new bass, or just have played before, go to a music store. Ask to try out the basses, and they will try to talk you into a bass. Just ignore it, and try out any bass that looks good to you. What you should look for in a bass is whether you will be playing only rock, only jazz, or a little of each. If you only plan on playing rock, I suggest a precision bass, they have a deeper tone. A jazz bass is the opposite, it has a brighter tone. Personally, even though i play mostly rock I love my Jazz bass, it seems more... well... customizable. You will be able to tell the difference even if it is not in the name like Fender. A jazz bass has a narrow neck towards the tuning parts, but it gets wider towards the body of the bass, therefore the strings spread apart. A precision bass is different in that the strings stay more or less the same length apart down the whole neck.
When you are looking at basses, don't look at the price tag, that comes next. If you fell in love with a bass, tell the workers there why and they might have a cheaper version. Also, ask for someone who can play the bass, people who don't will not know much about a bass.
Fretted over Fretless: For a first bass, get a fretted. They are easier and you can slap them and such. For a secondary bass get a fretless if you want. That does not mean don't try a fretless out, they are really fun to play.
Full sized over 3/4: Get a full size, even if you are young. You will grow into it. It will also get your fingers used to reaching.
4 String over 5 or 6 string: For your first bass, get a 4 string. Until you feel you need another string (most of the time the string is lower) stay with a 4 string bass.
24 Fret over 21 Fret: Actually don't worry about that. Any of the two will do. The 24th fret is just another octave.
Active over Passive: Active electronics means you get better sound quality from your bass, mostly more bass. It also takes a battery. However, you can usually shut it off so you can play it like its passive if you want that sound.
Solid over Semi-Hollow/Hollow: GET A SOLID! Although the hollow ones may look cool, once you crank up the volume the air inside will resonate giving it a muddy tone. Unless you are planning on always playing softly, get a solid bass.
Of course, you can go against all those if you truley fall in love with a bass. Just i suggest you pass the bass with someone who plays the bass. They will hopefully tell you if they like it. Also, before you buy it, go to a different music store if you can and try a few basses there, and compare prices.
Strings: Don't worry, unless you are really good at the bass you probably will not notice the difference.
Some other tips: Unless you think you are good at the bass, I suggest you don't crank up the volume on the amp at the store, it is pretty embarrassing to have no idea what to do and just hit random notes, most people will know that you have no idea what you are doing.
Looks are a lot in a bass, only try the basses out you like the looks of. It is no fun having an ugly bass.
Get a hardcase, they are sturdier than softcases and more protective.
Get an bass amp, not a guitar amp.
Used basses ARE good, they will not lose sound quality. They may even gain it. You can also get a great deal on a used bass, I saved more then $500 on my Fender Jazz Bass, (the first picture in the intro)
My suggested price ranges when you do end up buying a new bass:
100-300-Beginner. Keep this bass for a few years until you get good and decide to stick with the bass
300-500-Intermediate. Keep this bass for a while, until you feel the instrument is holding you back.
Above-Good. The store just made some cash, and you have a bass thats really good. You probably don't need a bass that good until you are good.
My suggested price ranges when you do end up buying a used bass:
This is harder, but I suggest 300-500
I got mine for 400, it's a $900 bass. I also got a really good deal on it though, they were having a sale.
Amps: The bigger the better, don't get a used one. The more watts the more punch you will feel when you hit a note as well. As a beginner, you probably only need 20-30. As you get better, trade it in for a bigger amp. You really shouldn't need anything fancy in an amp, no effects or anything, however they are fun sometimes. You're bass should have enough knobs built in to get the sound you want. You could also look into tube amps, or even build one! Build a Tube Amp
For the case, depending on how good your bass is, any old hardcase will do, they range from 90 to a lot more. I got mine for $90
Strings: Your bass will come with strings! Once you get good enough read the Strings step in this instructable.
Also, get a tuner if your amp does not have one built in, and a cord. Just ask the store workers for one and they will give/sell you one. It really does not matter on the type of cord or tuner, anything will work.
26 comments
Mar 31, 2012. 4:21 PMblenderking says:
Also, check out Stevie Wonder's Bass in songs like "I Wish", I love him. Also Michael Jackson in his early years had some REALLY awesome bass like in "I Want You Back" or "ABC"
Mar 31, 2012. 4:19 PMblenderking says:
I am a very experienced musician, I have been playing for about 6-7 years and I play roughly 5 instruments but I love the Bass it is a great instrument and its just fun to turn your amp up and rumble sometimes but some advice for beginners: Picking a Bass: I was once told by a Bassist who had been playing for several decades that when you are looking in the <$350 (less than 350) range for a Bass, Ibanez makes the best, above that, go with fender. I totally agree with this as I took his advice and bought an Ibanez for about $400 and I love it. Also when you are picking a Bass I would throw all my money towards a Bass and then, next time you have money, get an amp. You will be much better off in the long run, if you are thinking that way and take Bass seriously enough, if you aren't sure, go with a cheap bass and cheap amp.
Jan 14, 2012. 5:18 PMfreeza36 says:
that gibson sg bass looks good
Oct 30, 2011. 7:47 PMDaev says:
Jaco Pastorius played with Weather Report & the Jaco Pastorius big band, among others. Victor Wooten plays with Bella Fleck and The Flecktones (his brother, "Future Man" plays an electronic drum machine guitar of his own invention in the same band. Both Wooten and Pastorius have released remarkable solo bass albums.
Sep 21, 2010. 6:53 PMgpadepedro says:
Check out the bass player of the band Rush, Geddy Lee.
Sep 16, 2010. 6:02 PMstuntdude47 says:
Do you perfer humbucking or single coil pick ups. I want to build a bass so i'm gathering information.
Jun 27, 2008. 2:34 PMJake-off says:
do you think the same concept could be used to learn how to play the double bass
Jun 28, 2008. 11:00 AMjohnson_steve says:
The P-Bass design is derived from the double bass so yes, but you hold it upright and it has no frets. playing a double bass is very much like playing a fretless and every single one I have ever seen had markings on the fretboard where the 3rd and 5th frets would be for referance.
Jun 28, 2008. 3:55 PMJake-off says:
thank you
May 4, 2010. 11:31 AMmacmaniac says:
The 2 are incredibly dissimilar - no way in hell is playing a double bass like playing a fretless. Johnson_steve has clearly never touched a double bass, and the one's he's seen with markings are in the minority.
Think yourself lucky you didn't say that here - they probably would have hunted you down and killed you.
Jan 16, 2010. 2:48 PMPbyrd says:
NIce Instructables. I just got my first bass for my birthday yesterday. Also, I think Krist Novoselic should be on the good bassist list.
Jan 17, 2010. 9:28 AMPbyrd says:
A black and chrome Dean Edge 4-string.
Jul 31, 2009. 4:24 AMpenguinbassist says:
I'm afraid i have to disagree...
The bass guitar, like a double bass (also awesome), is tuned in *fourths*, unlike the violin family, which *is* tuned in fifths.
The difference is that the tuning is named relative to the position of the note in the scales, a fifth is A-E, or G-D. You were right about the fifth fret though, just nomenclature.
Jul 9, 2009. 1:03 PMatho710 says:
you might want to add Jon Entwistle to the list of amazing bassists...
Nov 24, 2008. 6:37 PMklooa says:
Also, The Roundwound produce more finger noise, the Groundwound a wee bit less, and the flatwound produce almost none. Hence the Round wound will force you to learn to pickup your fingers to reduce unwanted noise.
Nov 24, 2008. 6:17 PMklooa says:
Whatchyamicallit = Bridge. Intonatable Bridge, to be precise.
Nov 24, 2008. 6:16 PMklooa says:
I find the "Get a solid" to be misleading. A Danelectro Bass is hollow body, and maintains a crisp and clear sound despite that, Due to its Lipstick Pickups. Although, It does lack sounding holes, but in that case the term should be "Semi-accoustic". Overall though, great advice.
Oct 19, 2008. 6:24 PMdreese says:
Have you ever played just an electric guitar? That's what I play and I wasn't sure if bass was easier. I'm not the best; the hardest song I can play is Stairway to Heaven. I'm thinking about getting a bass but I have never played one before and I just like the sound of them. Should I take a few lessons to get the feel of one before I buy a bass?
Jun 27, 2008. 8:19 PMjohnson_steve says:
I've been playing for over 10 years and this is a great instructable. I'ts obvious that a lot of hard work went into this and it's quite a comprehensive guide for beginers. You seem to be a fender man as you only mention P and J basses; I happen to like gibsons. it's worth mentioning especialy for people just starting out that you can buy a Squire for a lot less then a Fender and get basicly the same bass. same goes for an Epiphone instead of a Gibson. both are owned by there respective parent companies and build guitars and basses from the same plans for less money for those who can't spend as much money. You could also mention tube amps and Cliff Burton of early Metallica.
Jun 28, 2008. 10:55 AMjohnson_steve says:
The Precision bass was Fender's first bass they own design of he the P and J basses but, you are not 'wrong' as these are some of the most often 'knocked off' designs. I have an epiphone Accu-bass which is obviously a P-bass clone. It doesn't sound bad but it doesn't sound like a fender P-bass on the other hand a squire p-bass is a real p-bass for about half what you would pay for the fender. buying a squire is like buying a VW when you can't afford an Audi; it's made by the same people to the same high standards with the same quality parts, just cheaper. Cliff is my personal hero if you can check out the video 'Cliff'em all' I used to like metallica till that damn bus fell on him twice (seriously they picked it up with a crane then dropped it on him again.) Claypool is my Hill-billy God. I can't offer much advice as to what tube amps sound good as I prefer to build my own but I do like my Electro-harmonix 12ax7 guitar preamp tubes even for bass they give me just the right amount of bite when I need it.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
11
Author:heyzuphowsitgoin
