Evil LED Goat
3,178
43
5
Posted in HomeHalloween
Introduction: Evil LED Goat
About: Creative Technologist.
Around Halloween, even the most innocent of things seem to turn evil. For example our office mascot, Goat, has started acting weird lately...
This tutorial teaches you how to make your own plush toy with LED eyes that can be controlled by an iPhone. The perfect Halloween scare!
Step 1: Get the Parts
goat-1
We will be using an Arduino compatible microcontroller called the LightBlue Bean to change the color of the LEDs. It connects to your phone over BLE and comes with an iPhone app called LightBlue that you can use to control it.
This is what you'll need:
  • One LightBlue Bean
  • A plush toy of your liking. We used this goat.
  • Two common cathode RGB LEDs (common anode also works but requires a bit of extra work)
  • Six 270-330 ohm resistors
  • A 2xAA battery holder
  • Two AA batteries
  • Wire and some heat shrink tubing
  • Basic sewing gear
  • Soldering iron
  • Wire stripper
  • Step 2: Solder the LEDs
    Connect the battery to the BAT pin on the Bean and ground. Then connect the RGB pins to pin 0-5 on the Bean with resistors in between, and the cathode to ground. Insulate with heat shrink tubing.
    goatfritzing
    goat-2
    Step 3: Perform Surgery on Goat
    Find a plush animal of your liking. Cut a hole in its abdomen and feel like a horrible human being for doing this to an innocent toy. Then feel even worse when you remove its eyes.
    goat-3goat-4
    Step 4: Put in the Electronics
    Put the LEDs, battery holder and Bean in your toy and adjust the LEDs so that they fit in the eye sockets.
    goat-5goat-6goat-7
    Sew the goat together where you put in the electronics. Also sew a bit around the eyes if the holes are too big for the LEDs. Nobody likes saggy eye sockets. That's just scary in a wrong way.
    Step 5: Install SoftPWM Library
    To be able to fade the LEDs, we will need to use a SoftPWM library. This lets you use any digital pin on the Bean as analog output. By calling the function SoftPWMSetPercent(PIN_NUMBER, BRIGHTNESS) we can go from 0-100 percent brightness. If you need help installing libraries to Arduino, check out this guide.
    Step 6: Upload Code to Bean
    Upload this code to your Bean.
    iphone6-sandbox
    Download the iOS application LightBlue, open it and connect to the Bean, click options and choose Sandbox View. Use the sliders and checkboxes to control the LEDs!
    The first slider will set how red the LED is, the second green, the third one blue and the last one sets Goat in disco mode. Nothing makes a party like that!
      • Woodworking Contest
        Woodworking Contest
      • Casting Contest
        Casting Contest
      • Spotless Contest
        Spotless Contest
      5 Comments
      Thanks for this tutorial. I have a couple of questions. Am I supposed to be soldering the legs of the RGB LEDs as depicted in the image in Step 2 (with Redpin1=0, Greenpin1=1, and Redpin1=2, Redpin2=3, Greenpin2=4, Bluepin2=5) or as delineated in the code?
      In the code, the pins are identified as follows:
      // The pins that the LEDs are soldered to
      #define redPin1 0
      #define redPin2 5
      #define greenPin2 1
      #define greenPin1 4
      #define bluePin2 2
      #define bluePin1 3
      Using your code and the diagram in Step 2, I haven't been able to get the common cathode RGB LEDs to light up. The code is, however, working well to control onboard RGB LED. What am I missing?
      (P.S. I have checked the connections of the RGB LEDS. I am able to blink them both in all three colors using a Blink sketch. I am using six 330 Ohm resistors and brand new AA batteries).
      Thank you for your nice instructable.
      Rima
      Noooooooooooooooooo! That evil goat is very very evil! Great work on the goat, even if he is evil. You gave me a big laugh today :)
      This is some mighty fine work! The video of the evil LED goat in action is the best.
      Poor, poor penguin. : (
      Thank you! And don't worry about Penguin, he's a pro stuntman and is doing fine!
