3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Evil Dark Detecting Solar Piggy Night Light
Adding lights to random things in your house is great fun for kids of all ages.  Adding solar lights to random things in your house is even more fun.  Adding red eyes to a piggy bank to make it evil is probably the most fun you'll have all afternoon.
I found this piggy bank at my local Dollar Store and instantly knew he'd look great with evil red eyes.  I could have gone the simple route and wired the eyes to a power adaptor, but where would the fun be in that?
In the end I made a simple light detecting solar circuit that fits inside the pig.  I'll stick him in my classroom next week and see if the kids notice him.
This is cheap to put together, easy to build, and long lasting.  (Also, you don't have to stick this circuit into a pig.  It'll work with anything.)
If you'd like to build this circuit I happen to have a kit available on my gadget site browndoggadgets.com, as well as a variety of solar cells for projects like this.
Step 1What You'll Need
What You\
Parts:
Container (In my case a $1 piggy bank)
Two Red LEDs (For this project they need to be red)
Two 100 ohm resistors (or 50 ohm works as well)
Two AAA or AA rechargeable batteries
One AAA or AA battery holder
One solar cell with a power greater than 4 volt
One blocking diode (1N914)
One PNP transistor
One 5,000 ohm resistor (or close to it)
Wire
I also used two 5mm LED mounts, but you might not need them.
Equipment:
Soldering Iron
Wire Cutter
Drill
Hot Glue Gun
Cost: $5-10
Time: 30-60 minutes.
5 comments
Jul 18, 2011. 11:11 PMshanakoenig says:
I'm pretty new to electronics so I apologize in advance for the basic questions.
I have actually tried using 3 batteries and 3 solar cells each in series so I can drive my LEDs brighter, but once I do, the dark detecting part no longer works. It works fine with 2 batteries and 2 solar cells or 1 battery 1 solar cell and a joule thief at the end. Though none of these drive my LEDs as bright as I want and I assume to most efficient way to drive 10 - 15 LEDs in parallel is with 3 batteries and 3 solar cells in parallel. (I will add further solar cells in series to provide enough charge to my batteries to run my LEDs all night).
I assumed that this was because the voltage difference between the solar cells and the batteries is no longer enough to trigger the switch. I tried changing my 5k resistor first to a 10 k and then a 1k hoping one would solve the problem but it didn't. Can you please explain why, and if there is a way to modify this circuit to work with 3 batteries. If not I can also try making a switch with a photoresitor to control the "on/off", but I am not sure of the technical details to do that, from what I have read it would involve a voltage divideer circuit.
Any help would be greatly appreciated.
BTW I just bought a solar panel and one a simple joule thief from you, I think your IC circuits are the same as rcisneros is using in his solar light string instructible and I want to play around with that, I can't get god results form the one in mine.
Jul 19, 2011. 12:50 AMshanakoenig says:
Nevermind, late night user error, works great now :)
Jul 19, 2011. 3:11 AMshanakoenig says:
It works but the transistor seems to be limiting the current, the LEDs (in parallel) are only getting 2.4 volt . I accidentally connected my battery positive to the emitter end of the transistor on my breadboard and my LEDs got blinding bright, as they should be receiving 3.4 volts each.
Based on other posts I read about joule thief circuits I figured the 2N306 transistor rated for 200mA was limiting it, so I switched to a 2N4403 resistor rated for 600mA, but it didn't make a difference.
Do you have any suggestions? I want to run 10-15 LEDs (including color changing LEDs, I know they have a problem getting past red with a joule thief, but I plan to add a diode and cap at the end to fix this) at full brightness. Size of enclosure isn't an issue single I will need several solar cells to support this.
If using 1-2 batteries and a joule thief more efficient then directly charging 3 or 4 batteries and then running the LEDs straight off them?
Thanks in advance for any help!!
Jul 19, 2011. 1:18 PMshanakoenig says:
Thanks for the prompt reply :)
Yes, I figured I was doing something wrong wrong with the joule thief part of the circuit, probably my toroid wrapping. Tried one with 22 AWG wire I had around but could only fit 6 turns, tried another that I wrapped with 30 gauge wrapping wire with 15 turns. I have seen many joule thief circuits on the web and some seem to use 7-10 turns, others 20 others 40. Somewhere I read the more tuen the more volts you will get, other time that it raised the inductance, or that it doesn't really matter.
I would love an explanation on the relationship of the number of wraps to the circuit.
Also I love to know why when I use the PNP transitor for the dark detecting part of my circuit the voltage provide to my load goes down to 2.4. When I attach the load + to the collector leg of the PNP (basically bypassing the switch), I get 3.4 volts (as expected) to my load +.
Thanks!
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
162
Author:JoshuaZimmerman(BrownDogGadgets)
I'm a middle school science teacher in Milwaukee, Wisconsin. I like making random things and then teaching my students how to do the same. I also run a little website where I sell some of the things...
more »
