This must be the easiest and best gosh darn looking table it is possible make:
Ingredients:
1 x Window found on the roadside
4 x colonial table legs
8 x Metal Brackets
4 x wooden Dowels
wood Glue
28 x Screws (depth and width appropriate to brackets and depth of frame)
Tools:
Power Drill
Hammer
Screwdriver
1. Remove hinges from the window.
2. Turn upside down and rest on a couple of crates
3. Measure up and drill a hole in the leg and corner of the table to fit the dowel. Fill hole with a bit of wood glue. Tap the dowel into place with the hammer. Attach leg to window so nice and sturdy. Repeat.
4. Place two of the brackets on either side of the leg attaching to window frame. Drill holes and tighten in the screws. Repeat for all legs.
That's a table. Easy Peasey.
simdude2u says: Dec 2, 2012. 1:03 PM
How high is the table & where did you get the colonial table legs at?
terielise (author) in reply to simdude2uDec 11, 2012. 4:51 AM
The legs were from Bunnings. The legs are 44cm high from the floor + the window frame width adds another 2.5cm (right on an inch) to the height.
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
