Drknotter made an awsome Lord of the Rings Sword. Following his lead I decided to make a sword myself. I got on the internet and searched "excalibur dimensions". I divided what I found by 9 and got to making this tiny sword. It comes in useful when I want to get midieval on my letter opening. To make it I used a piece of 3/16" steel rod, a 1/4" shelf pin, a bullet shell, and a little polymer clay.
Credit goes to my seven year old son for setting up the sword to "look cool" for the photo shoot.
Step 1: Hammer out the blade
Heat the dowel until it glows and hammer it about 1.5mm thick. For these dimensions you’ll want to hammer out at least 10 centimeters. As you hammer, check the blade against the edge of a ruler to make sure your sword is strait.  To do this you have to hit the rod squarely. If you hammer off center the rod will hook to the right or left.
Step 2: Shape the blade
Use a sanding attachment to rough shape the sword. Don’t “sharpen” the entire blade. Leave a section square. Use hobby files to further refine the blade.
To get a consistent bevel on the edge use a marker to color the entire blade. As you file away it’s easier to shape in a strait line.
Use a grinding disc to remove material for the handle. Don't forget to wear your safety googles.
Step 3: Form the guard
Heat a shelf pin until it glows. Hammer both sides flat. Use a grinding wheel to rough shape and files to refine. Once you have the shape you want curl the ends downward with round nose pliers and some torch heat. Drill a hole in the middle large enough to fit the handle.
Step 4: Cut the pommel
Just like the shelf pin, use what you have on hand. In this case I have a rifle shell casing. I mounted it in my drill press, spun it round and used a file to cut a piece off. I then drilled a hole and placed it on the handle.
Step 5: Solder, polish, clay
Solder both the guard and pommel in place.
Use progressively finer sand paper to polish the sword. I start with 400 grit, then move on to 1000, 2000, and finally polishing compound on a polishing wheel.
Form polymer clay around the handle and through the pommel. Smooth it out before you bake it in the oven.
Thanks for reading.
1-40 of 49Next »
teodoropires says: Feb 1, 2013. 7:46 AM
Fascinating!
Dusk Shadows says: Jul 13, 2012. 4:27 AM
Love it!
ThatKnottyguy says: Apr 10, 2012. 7:51 PM
Please reply!
Would you mind if i made a stand for this, mentioning your instructable and giving you full credit? Can you give me the dimensions for the width?
Mrballeng (author) in reply to ThatKnottyguyApr 11, 2012. 1:32 PM
PS. You don't have to feel obligated to mention me. I post my instructables under public domain.
ThatKnottyguy in reply to MrballengApr 12, 2012. 2:12 PM
Do you have these for sale at your site?
Mrballeng (author) in reply to ThatKnottyguyApr 18, 2012. 12:55 PM
Not right now. For as much time as it takes to make it makes for a better gift then something to sell.
ThatKnottyguy in reply to MrballengApr 18, 2012. 5:10 PM
Would you want to sell one of these privately?
Mrballeng (author) in reply to ThatKnottyguyApr 11, 2012. 1:31 PM
That would be awesome though I don't have the sword anymore. I gave it to my sister. But If I was guessing I think the blade was 5mm x 1.5mm.
TheAmateurArtisan says: Jan 6, 2012. 10:29 PM
I remember having one and then throwing it at crab apple trees when I was younger. Was really good at it but then... meh.
electridanger in reply to TheAmateurArtisanJan 8, 2012. 3:17 PM
But then...
you took an arrow to the knee
curvy77 says: Nov 21, 2011. 11:53 AM
i commend you on being one of the few to go into detail about angles measurments and dimensions. you truly make a fine artisian in the metalworking arts. Amazing!
Mr.Sanchez says: Sep 28, 2011. 7:02 AM
What about a Stone Stand for excalibur...? that would be awesome.
mcshawnboy in reply to Mr.SanchezNov 5, 2011. 4:04 PM
Hide in the stone an electro-magnet activated via remote to remove or prevent removal of Excalibur by the unworthy?
Mr.Sanchez in reply to mcshawnboyNov 5, 2011. 6:35 PM
So clever pls try....=)
mcshawnboy in reply to Mr.SanchezNov 5, 2011. 8:08 PM
I'd have to build Brent's sword first. I'm limited in what I can do here as my brother-in-law's fussy! I wanted to build a small version of Kiko Denser's "Earth Oven" & he wouldn't allow it.
Mr.Sanchez in reply to mcshawnboyNov 6, 2011. 8:14 AM
Wouldnt allow it..?..well...Its his creation but once the instructables is submited anyone could reply and why not better up the Project.Good luck...!!
mslaynie says: Oct 2, 2011. 7:16 AM
Oooh, congrats on getting featured in the email digest!! :D
Mrballeng (author) in reply to mslaynieOct 3, 2011. 4:53 PM
Thanks! I'm not sure why but I don't get those emails.
mslaynie in reply to MrballengOct 4, 2011. 10:13 PM
Check your settings. I know I didn't get them for a long time, but now I do. I'm not sure if I changed something or not. They might also be going to your spam folder.
Hi there, i was juts wondering what kind of torch you used for the project, propane, mapp gas etc.? Thanks
Mrballeng (author) in reply to isetmyselfonfirefollowinginstructablesOct 4, 2011. 9:04 AM
It's a common propane torch. I bought it in the plumbing isle at walmart for $15.
Thanks so much. I've been looking at your 'ibles, and the way you can transform common items into masterpieces such as this one is incredible. You sir, are a very talented and brilliant person. Hope to keep seeing more from you and keep up the great work!
mjursic says: Oct 2, 2011. 6:39 PM
Lovely little instructable. When hammering it out, here`s a piece of advice that runs counter to your experience: Hammer on an angle. Flip. Hammer on an angle. Flip. Etc, etc. Keep repeating and you`ll get a tapered profile and a ridge up the middle that looks swell. probably not as swell as yours, but it`s worth a try. That`s how I make my blades, and it`s easier to grind them if the profile is already tapered. Please don`t take this as criticism. It`s a beautiful little project.
Mrballeng (author) in reply to mjursicOct 3, 2011. 5:00 PM
Thanks for the tip. Next time you make a blade snap some pictures. I'd love to see your methods.
domestic_engineer says: Oct 2, 2011. 6:41 AM
very cool.
you should make a polymer clay "stone" to hold it in. then every time you open a letter, you can remove the sword from the stone. Should make paying the bills a little more adventuresome.
Mrballeng (author) in reply to domestic_engineerOct 3, 2011. 4:52 PM
Great idea.Thanks for the comment.
brssnkl says: Oct 1, 2011. 1:24 AM
Do you think about making more of that and selling them, i would love to buy one
Mrballeng (author) in reply to brssnklOct 3, 2011. 4:50 PM
I would have to get more efficient at making them. That way the time and effort would more reasonably match the price.
SNACKS says: Sep 30, 2011. 8:37 AM
This looks like fun I use to make little Swords out of nails good job...
gamos in reply to SNACKSOct 2, 2011. 3:40 PM
That is a great idea, i will try it.
deathnotx101 says: Oct 2, 2011. 11:31 AM
If you make a slot into a little rock you can become the king of kings every time you use it. :)
whiteoakart says: Oct 2, 2011. 10:51 AM
Very nice, Mrballeng. The finished piece looks great and your directions are easy to follow and look quite do-able.
mr.squeakers says: Oct 1, 2011. 11:47 AM
I actually have purchased one of these.
bconway1 says: Sep 28, 2011. 10:22 AM
What size shell casing is that?
Mrballeng (author) in reply to bconway1Sep 28, 2011. 11:39 AM
.223
mcshawnboy in reply to MrballengSep 29, 2011. 8:26 AM
Until I saw the picture on the plate I thought you were cutting up .50 cal brass ! Another nice job Brent ! Are you open to trades? Lots of friends like copper necklaces & crosses I've made as gifts for friends that've asked if I could make one from seeing somebody else's. I do wire-wrap & lost wax casting too. I'd love a Spaceship Photo-holder from the master!
jsomerhalder says: Sep 28, 2011. 5:07 PM
you always make awesome stuff, and yes...props to your son for awesome photography styling. Think he has a future career there...
mslaynie says: Sep 28, 2011. 7:01 AM
One of these days we're going to have to work out a trade... maybe exchange a hand-crocheted, custom scarf or maybe a sculpture for a pendant. You make the COOLEST stuffs!! This is gorgeous, and you make it look so EASY!
Mrballeng (author) in reply to mslaynieSep 28, 2011. 11:37 AM
Deal. That would be awesome.
mslaynie in reply to MrballengSep 28, 2011. 1:10 PM
Sweet!! Also, I'm working on my first photo instructable, a show and tell of a bead set I made several years ago. Polymer clay for the win! ;)
Thanks for the inspiration!
1-40 of 49Next »
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
