Introduction: Exhaust Replacement - 1981 VW Rabbit Diesel
Picture of Exhaust Replacement - 1981 VW Rabbit Diesel
Replace the exhaust system on a VW rabbit.
I could not find much info on the details of installing a muffler.  Hopefully this will help if you have to do the same thing
This was physically difficult for me to do, a lot of being under the car, which I don't like.
Note: The red bentley manual as a good exploded view, it also has the torque spec for the pipe clamps ... although I seem to have lost it.... you can get them from amazon here
Step 1: Get the Parts
Picture of Get the Parts
This is a complete replacement exhaust with accessories and tools.
Step 2: Document Part Numbers
Picture of Document Part Numbers
I photograph all the labeling as soon as I open the boxes.  If you need a part number latter, it is easier to look at the pictures then at the top of a muffler that is under a car.
Step 3: Practice Assembly - Pipe Clamps
Picture of Practice Assembly - Pipe Clamps
Step 4: Spring Clamps and Tool
Picture of Spring Clamps and Tool
Step 5: Rubber Hangers
Picture of Rubber Hangers
Step 6: Gasket for Down Pipe 'toilet Bowl'
Picture of Gasket for Down Pipe 'toilet Bowl'
Step 7: Yikes - What a Big Thing
Picture of Yikes - What a Big Thing
Step 8: Inspect the Pathway and Hangers Under the Car
Picture of Inspect the Pathway and Hangers Under the Car
Step 9: Remove the Old Down Pipe
Picture of Remove the Old Down Pipe
Use the spring clip removal tool, to remove the spring clips.  I tightened it as much as possible and still could not remove the clips.  I oiled the area around the clips and was then able to remove them.
Will reuse the heat shields.
Not sure if there is a small crack in the exhaust manifold -- does not look like damage, but does not seem like it should be there.
Step 10: Jack Up the Back of the Car and Get a Light
Picture of Jack Up the Back of the Car and Get a Light
Step 11: Install the Tail Pipe and Muffler -- Needs to Be Snaked Into Place
Picture of Install the Tail Pipe and Muffler -- Needs to Be Snaked Into Place
Step 12: Secure With Rubber Hangers
Picture of Secure With Rubber Hangers
Step 13: Deal With Rust
Picture of Deal With Rust
Rust sucks.
Step 14: Chip and Cut Away All the Rust
Picture of Chip and Cut Away All the Rust
Hitting the rust with a hammer will get rid of a lot of it.  Using a pointy hammer works well and helps you figure out where the edges of the rust are.
I used an angle grinder with a cut-off disc to cut back to good metal.
To weld you need a clean surface, so go around the edges with a wire  brush disc on the grinder.
Step 15: Patch the Hole With Sheet Metal
Picture of Patch the Hole With Sheet Metal
I used 22 gauge steel and a 90amp wire feed welder from Harbor Freight.
To get the right shape I first cut a scrap piece of aluminum (bottom of a 'catering tray') then traced the shape onto the steel.  I used nippers to cut out the shape, this is sort of a pain, but it does work.
Welder settings: MIN Power  and Wire Speed 2
Weld the new piece in place.  22 gauge is a bit thin, 18 gauge would have been better.  18 is the minimum thickness that should be used with this welder.  Had to patch a few holes after putting in the large piece.
Step 16: Transfer the Heat Shield to New Down Pipe
Picture of Transfer the Heat Shield to New Down Pipe
Step 17: Install Down Pipe With Spring Clips
Picture of Install Down Pipe With Spring Clips
Here is how I got it to work.
  • First installed passenger side clip from under the car.
    • Held up the downpipe with my knee while attaching the clip
  • Install driver side clip from above the car.
    • I was able to pull the bottom of the pipe towards the drivers side, stretching the passenger side clip.  This  made it possible to install clip.
    • It was hard to get the clamp off
Here is a link to the socket set I have Stanley 97-126 11 Piece 1/2-Inch Drive Metric Deep Impact Socket Set
Step 18: Install Middle Muffler Part...
Picture of Install Middle Muffler Part...
This was the easiest part.  The middle part of the exhaust hangs by one clip and attaches to the two other pieces.
Step 19: Seal Joints and Tighten Clamps
Picture of Seal Joints and Tighten Clamps
I'm worried I did this wrong, somehow.
The sealant was messy, most of it squeezed out of the joint.
Step 20: Straighten Everything Out
Picture of Straighten Everything Out
Probably should have done this before sealing and clamping the joints....
I was able to get everything lined up okay by twisting the muffler.  You want to get the pipes so they are close to the bottom of the car, not hanging down all over.
Step 21: Done for Now
Run the engine and check for leaks.... I guess.
As long as it doesn't fall off I'm happy for now.  In the end it will have to pass a 'smog test', should be fine.
rseidman1 (author)2014-11-27
Where can I purchase the spring clamp replacement/removal tool. What is yours specifically called? Trying to find cheaper than $22 on Amazon.
marc.cryan (author)rseidman12014-11-29
I think this is the one I used:
http://www.partsplaceinc.com/products/product-detail.aspx?keyword=VW+Exhaust+Spring+Clip+Tool+VW+-120-849&s=194&&sku=3515
You could probably make one.
marc.cryan (author)2012-11-14
late reply to VW diesel exhaust question ---- I have driven the car very little, so it is hard to say how good it really is. It has stayed on and exhaust comes out the end, and no where else. It does lean to one side, but it does not seem to matter.
the machine (author)2012-09-22
How has it held up since then?
About This Instructable
7,316views
15favorites
License:
Bio: Married to Domestic_Engineer (but I call her Meghan).
More by marc.cryan:Kitchen Sink - From AmazonCheapest, Bestest computer around, in beginning of 2015Cryan Family Gothic Green House
Add instructable to:
