3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Expandable Hydroponics System from Junk - Flood and Drain
I have been messing around with hydroponics on NO budget and HATE throwing otherwise useful things in the garbage, so being both cheap and EXTREMELY LAZY (I call it efficient), I decided to break a nail and this is what I came up with.
I've learned first hand and read that the most unreliable, but seemingly necessary piece of equipment in most systems is the water pump. If you want something reliable, you are going to have to spend money and be prepared to maintain the pump and nutrient delivery system. Too much work for a potentially catastrophic failure if you ask me.
I found inspiration in an instructable that I can't seem to find any more. I'm sure it was called "The World's Simplest Flood and Drain System". I would like to apologize to anyone else that I do not mention or refer to due to my incompetence, but if you see any similarities please do provide links in the comments as I do not claim to have many original thoughts.
The air pump has become a staple component in most systems for various reasons. Moving water with air makes complete sense to me while solving several issues and being cheap, reliable and easily serviceable. Pump maintenance is algae free and time will tell just how reliable.
Next, the system had to be sort of "free",so this meant parts that are common, cheap or reclaimed. Enter my friends, the pop bottle the milk bag and their goofy sidekick Aluminized Bopet (chip bag to most).
Step 1What You'll Need
1 ea aquarium pump
1/4 inch air tubing as required
3 ea 2L pop bottles or more as desired
1 ea pop bottle cap(reservoir cap)
2 ea Sunlight dish detergent bottle caps or pop bottle caps(planter drain)
3/8 inch inner dia. vinyl tubing as required (approx 2 ft)
1 ea 3/8 inch nylon plumbing TEE adaptor
1 x 3 length of wood or equivalent planter support
Growing medium (I use pea gravel)
Milk Bag optional
Chip bags as required
1 ea elastic (aka rubber) band
Drill
7/32, 3/8, and 1 1/4 inch drill bits (that's 1 and 1/4 inch)
Hot melt glue gun.......maybe
65 comments
1-40 of 65next »
Aug 10, 2009. 3:42 AMJendenuvaden says:
Can you spare some details about your timer setup? I've found some round one on/one off timers, and am not sure what to look for for a setup that goes on and off three or more times daily. Thanks!
Sep 28, 2008. 2:35 PMawakebyjava says:
I think this system HAS to be a little loose. Just set one up, and the water I used to test it just plain will not drain back into the reservoir! This picture shows anti-siphon valves, because I had them laying around, but even without them the water will not drain! Any ideas on how to make sure the air pressure can be released when the pump is not on? I haven't check for valves that perform this function, but if anyone has ideas let me know! Great work wiley!
Jun 18, 2009. 8:59 AMdmcunningham says:
As mentioned previously, there is a good chance that your air pump has an anti-siphon built in it (this is because people will still put their pump below the water level - even though the instructions say to never do this without a check valve - so that if the power goes out as siphon wont be created). A lot more of the higher quality ones are doing this now.
Jan 18, 2009. 7:00 PMNaTeB1 says:
Dont know if this problem has been solved yet, but sometimes aquarium air pumps have built in anti-siphons. You can tell by blowing into the hose while it is connected to the pump, If you cant, then it probably does. alternative-innovation.com
Nov 22, 2008. 8:26 AMbwpatton1 says:
What works is if you take the hose off the air pump when you want it to drain. That is what I do.
Oct 26, 2008. 7:18 PMredkcir says:
I don't know how technical you want to be, but a low or middle voltage solenoid valve would allow for this. If the system were tight, an added valve tied into the time would work. Tie it in so it stays energised while the pump is on and it will open and drain when it goes off. A time delay would allow it to keep the fluid to stay up longer if you wanted it to. If you need an electricial drawing, send me an email and I will make one up for you.
Oct 28, 2008. 5:08 PMawakebyjava says:
Yah, I think that is more work than I am up to. But I did find out there is a hydroponic store in my town, so I might check that out. Good suggestion!
Sep 29, 2008. 10:49 PMchamunks says:
you could also simply add another water pump to pull all the water out instead of pushing it in this way you could extend the length of time the roots are exposed to the water / nutrient solution this would also have to be on a separate corresponding timer
Oct 16, 2008. 7:54 AMgomiboy says:
I'm going to try this with my daughter's 4th grade science class, and as we'll be building it in the classroom, I'm not going to have much room for tinkering with it. Nobody has volunteered a pump yet, so if mine doesn't allow air backflow, how large a hole do you think I'd need in the reservoir or air hose? I'm hoping I'll have some spare bottles, but won't have much spare hose handy if I screw it up. Thanks!
Oct 16, 2008. 2:43 PMawakebyjava says:
Just an update. I tried putting a very small hole in the cap, the smallest drill bit I could find, to no effect. It seems that even that small of a whole lets out too much pressure. I enlarged the hole and put in a screw, which I can adjust in order to change the amount of pressure in the bottles. Not quite perfect, but as my pump doesn't let air back out, it works for now. Still working on what to plant in these, as no stores have seeds anymore.
Oct 16, 2008. 8:08 AMgomiboy says:
Sorry to add more - I'm planning on building with a single reservoir, pretty much straight from the 'ible, so I won't be needing to sync anything. Thanks again for any and all advice.
Sep 28, 2008. 6:12 PMawakebyjava says:
Thanks! Great artists steal. I just cut a little notch on the side of the airline hose hole in the cap. Works fine, but its hard getting the two reservoirs to sync, and I ran out of caps. I'm a high school teacher though, I can get plenty of those. My pump doesn't allow air back through, so the siphon valves aren't hurting anything really. At least I know where they are if i need them. Now I just need to figure out how to start plants going in there!
Jun 18, 2009. 4:26 AMbeehard44 says:
i was wondering if i can use straws interconnected for that and maybe a serial port powered switch by python. especially useful in a server PC hihihi! gotta try as soon as possible!
Nov 30, 2008. 4:32 PMchuckisnutz says:
If you could add something to the bottles that would gradually release pressure, like those nozzles on inflatable innertubes used when sledding, you would definately have something there. or, maybe something which doesn't begin releasing pressure until a minimum pressure is met, and then releases all pressure.
Nov 22, 2008. 8:27 AMbwpatton1 says:
I built this system but with three bottles instead of two and it worked PERFECTLY! Very good idea A++++ Wonerful Instructable Thanks!!
Oct 29, 2008. 8:57 AMfuzvulf says:
Absolutely wonderful instructable. Going to add some small ribs for stability of the recycled containers and paint them to ward off algae growth but otherwise absolutely great instructable.
Oct 28, 2008. 9:51 AMgomiboy says:
I did this with my daughter's class, as I noted earlier - huge success! I built two setups, and tried to power both reservoirs with 2 air pumps pushing through a 3-way gang valve. Couldn't get enough pressure to do both, but because it's so modular, we were able to fall back to just one reservoir/2 pots and it worked great! Fantastic Instructable! Thanks for the inspiration!
Oct 26, 2008. 7:44 PMFreshPineSent says:
Calling carbonated beverages "pop" FTW.
Oct 27, 2008. 1:05 PMFreshPineSent says:
I believe a high-five is in order.
Oct 17, 2008. 8:00 PMPumpkin$ says:
cool! is there a way to grow avacados with these?
Oct 21, 2008. 4:29 PMpass-the-beans says:
do you think if I put fish in the reservoir they could take the pressure from the pump going on and off changing the pressure? really cool!! :)
Sep 25, 2008. 6:36 PMMatt_ says:
I good Idea for expanding this is incorporting a fish tank into the setup
http://www.farmfountain.com/
Sep 27, 2008. 10:32 AMMikey D says:
That's a heck of an idea! I just happen to have a 55 gal aquarium in my living room right across from our home Hydro unit (slide show to come) Hmmm... ...I wonder what momma (read wife) would say to me hanging a bunch of 1 liter bottles from the wall above the tank?
Sep 20, 2008. 12:01 AMMikey D says:
Brilliant! I have used the tube in the cap idea for many things but never this. This set up is referred to as "air over hydraulic" and is a great way to create large hydraulic pressures (lifting your nutes) with comparatively miniscule pneumatic pressures. As we know the aquarium air pumps make almost no pressure. but when applied to the large surface area of the nutes in the pop bottle, creates enough pressure to lift the fluid. Sorry for the preaching but it is the teacher in me loving your idea! I'm definitely going to put something like this together to teach my automotive students about hydraulics! Thanks!!!
Sep 26, 2008. 1:52 AMsynthetic.actuality says:
If you could turn the reservoir bottle on its side somehow, that would provide the extra surface area, but then the placement of the air inlet becomes problematic. Perhaps a 45-degree angle on the reservoir with a short extension of the inlet to ensure it's at the top of the bottle still?
1-40 of 65next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
49
Author:wiley coyote
