Expandable formal dining table that seats ten and fits in a closet
 by falk
Contest WinnerFeatured
Step 15: Constructing the rear section
Cut out the four plywood panels as shown in the diagram.
* Rear side (C), 14 5/8" x 4½"
* Rear back (D), 39½" x 4½"
* Rear bottom (E), 38" x 5"
On the two side pieces (C), drill two holes 1½" from the bottom and ¾" from the end.  Make the holes large enough for the 3/8" hangar bolts.
Drill two more holes higher up on the sides, large enough to accommodate the alignment pegs you'll be using.  I used ½" dowels for strength.
Assemble the back section as shown in the diagram.  Biscuit joints are best, but screws, dowels, or cleats are acceptable too.  If you use screws, plug the screw holes for best appearance.
Be sure to attach one sliding rail to each of the rear rails before screwing the rear rails into place.
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
