3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Expanded Vocabulary Easy Button
The Easy Button is available from Staples for $5 and it simply says "that was easy" every time you smack it. The easy button is well constructed for the price, but requires a little work and about $10 worth of parts to make it recordable.
Step 1Get your parts
Get your parts
I chose to use the ISD1600B voice recorder chip and essentially build the reference circuit for it. I made sure to get a microphone that had good low frequency response since the speaker in this thing is so big and can reproduce low frequency voices well.
You will need [digikey part numbers in brackets]:
(1) Easy Button
(1) ISD1610 Voice recorder [ISD1610BSY-ND]
(1) Electret microphone [P9925-ND]
(1) Pushbutton [EG1826-ND]
(1) 1k Resistor [1.00KdXBK-ND]
(1) 80.6k Resistor [80.6KXBK-ND]
(3) 4.75k Resistor [4.75KXBK-ND]
(5) 0.1uF Ceramic capacitor [BC1101CT-ND]
(5) 4.7uF Caramic capacitor [445-2854-ND]
You will also need these supplies:
Wire (I used 24 AWG stranded and 30 AWG solid)
Glue (I used 5 minute epoxy)
Solder
And these tools:
Soldering iron
Wire cutter/stripper
Tweezers
9 comments
Jan 14, 2010. 11:13 AMjpstaub says:
Great hack. I did the same thing but with the guts from a recordable card from Hallmark. It has all the bits on a PC board. The only challenge in fitting it all inside the button.
Feb 25, 2009. 7:09 PMdegroof says:
I tried using the SOIC chip but it was a bit too small for me solder, even with a magnifier. I ended up cramming an ISD1620 demo board (DigiKey I16-COB20-ND) in instead. Wasn't enough room for both it and the spring, though. Still works pretty well.
Jun 23, 2009. 11:33 AMcmrc says:
I used the demo board and fashioned a new spring out of the spiral wire off the back of an old notebook. It worked well. All it took was removing some of the plastic that was getting in the way, and mounting the spring in such a way that it did not interfere with pushing the button down.
Feb 13, 2009. 4:27 AMakatsuki666 says:
umm can ur little chip download stuff off the computer? if not pls tell me one that can ty
Jan 21, 2009. 10:34 AMcyrozap says:
a video of it would be cool.
Jan 21, 2009. 10:07 AMcflowers says:
Awesome hack! I featured it on The Daily Hack. Keep hacking, modding and building! :)
Charlie Flowers
twitter.com/charlie
Jan 19, 2009. 11:33 AMinventorjack says:
Awesome little project. I just happen to have one of those ISD chips laying around, and one of my coworkers has an Easy button at work. When he comes back next week, it will have a new vocabulary :)
Jan 19, 2009. 9:32 AMjeff-o says:
Now that is some crazy "squished bug" soldering!
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:instain
