3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Expedit Bookcase Size Reduction
Step 7End Section 2
End Section 2
You need to pull this part of the inner frame out and re attach it to your cut down section. This is what it looks like when you pull it out.
Then you need to cut this down a bit because it is too wide to fit back into the hole (if you cut it off at the right place). Cut it shorter than the gap it is going to fit back into, that way you get a bit of adjustment when you fit it all together and things don't quite line up.
Also make sure you take all that cardboard off that is stuck to it or it won't fit back in nicely. I used a belt sander to do that.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:GrayW
