What is a Question?
Questions are a super-easy way to get answers from the Instructables community. Learn how to build, do, or make anything! You just ask a question and the community will provide answers. You choose the best answer!
Submit a Forum Topic! The forums are the place to ask questions, share a cool project from another site, find collaborators for your latest project, or discuss anything of interest to the Instructables community.
Do you have a lot of images to upload?
If you prefer to upload your images before you submit, then this is for you.
Remember to tag them so they will be easier for you to find when you are viewing your library.
You can also upload images when you are creating your posts.
Did you find a bug or have a suggestion for us?
We appreciate all the help our users give us in tracking down bugs and making the site better for everyone.
PhotosPhotos
How to Demonstrate the Instability of High Explosives
video How to Demonstrate the Instability of High Explosives
This is a demonstration of why you should not mess around with high explosives. Just breathing on it sets it off. So when someone says, "don't try this at home", follow the instructions.
How to do this
get a high explosive.
Blow on it
Step Back
Count Fingers and Toes
Well you must not know what you are doing. TATP is relatively stable at room temperature and will not go off when you blow on in. It is not one of the more stable explosives and should not be stored for more that a couple of days. Also, you must check the term HIGH EXPLOSIVE and what it means. High explosives range from TATP to C4 to AN, and Nitroglycerine. C4 will not go off even when exposed to flame and heat, neither will ammonium nitrate. Next time to try to make TATP, do it in the freezer like you're supposed to. Explosives are things that demand respect and preparation. Do your research, and for God's sake, don't put anything inside of a metal conatiner to blow up. I can't stop you from making the stuff and and not telling you not to, but please, know what you are doing first.
That probably wasn't high explosives at all. It was probably a low explosive of some obsolete and seldom seen high explosive (I just contradicted myself) that was very sensitive. Today high explosives that are sensitive like that are almost never used or made. They have all been dumped in favor of more stable explosives that require a blasting cap(like C-4 and Semtex).
im not sure, i was reading something, i think it was on wikipedia, that said that the speed that flash powder burns at isnt considered deflagregaton, (which is how a low explosive eg gunpowder, is defined). it burns at a much faster rate than low explosives, and there fore is considered HE.
the reason i said *most* flash powder up there is because you can make impact/friction sensitive stuff that will go off really easy.
Even when you set a small ammt. of flamable high explosive off, such as TATP, it deflagrates. It detonates, though, in high quantities unconfined, and in basically any qty. confined.
Sounds as tho you're getting primary and secondary explosives confused. Common HEs like C4 are secondary xps...it's primary xps that detonate the secondary ones.
high explosives don't always detonate, it's just that they have the ability to detonate. if you light acetone peroxide with a flame then it just makes a flash, it doesn't go bang, if you hit it with a hammer then you'll need new eardrums
true. you can burn c4 and it just burns like it was a fuel log. it takes a shockwave to set it off. What I was saying was that the reaction looked more like a deflagration then a detonation and it was not set off by flame but rather a (extremely light) shockwave which would trigger a detonation in a high explosive not a flame. I could be wrong but that is my guess. My quess is they used some highly unstable low explosive.
an electric pulse won't nesisarily due anything to C4. In order for C4 to explode you need high heat and high force. Electricity might get you high heat via a nichrome wire or high voltage arc but no shockwave(force). The electric ignition systems work by igniting a less stable explosive that will detonate on ignition which in turn supplies the high heat and shockwave to the C4 producing detonation.
as for the possiblity of Nitrogen Triiodide - not a chance. The Iodine in the Nitrogen Triiodide colors the smoke purple and I did not see any purple smoke in the video. Nor does Nitrogen Triiodide produce a flame. It merely detonates leaving a cloud of purple smoke.
I looked up C-4 on Wikipedia (I know the info could be false) and it says: "Either electric or nonelectric circuits may be used to detonate the charge." But I suppose that is referring to the booster charge.
"Detonation can only be initiated by a combination of extreme heat and a shockwave..." I now stand corrected. You were right.
In Vietnam soldiers used C-4 to heat food. This is from C-4's wiki "While many soldiers used C-4 safely in this manner, there are anecdotes about soldiers trying to put out the fire by stamping on it —causing it to detonate."
Ammonium triiodide goes BANG all at once and gives off purple dust, no fire. The fireball is pretty consistent with badly made TATP, or as mentioned diacetonediperoxide. My guess is that the synthesis was performed at too high of a temperature, and the crystals were dried inconsistently over a large area, so as to create moist areas or pockets to prevent DDT (deflagration to detonation transition.) Properly made TATP you can hit lightly with a hammer and it won't go, however striking it with the force used to, say, drive a nail, will set it off.
Nitrogen triiodide can also be used. Look up 'Peter Logan's Exploding Paste' on YouTube and you'll find some hilarious examples of what you can do with it.
This is Acetone Peroxide. However it was not actually initiated with his breath, he just set it up to look that way. He probably inserted a length of nichrome wire into AP off camera and pressed a button right when he blew on it to make it seem like it went off from the blow. A "friend" of mine has made AP with no cooling on a 110F day and it was just as sensitive as AP made at 5C. There really is no noticeable difference.
How so? It was just a really quick flame, catch some hair on fire... Yes! very possible, lose a limb or the head... very doubtful. There was no shrapnel to cut or tear or pierce, there was no real concussion. So please explain to me why this would make him literally lose his head. This is plenty realistic, I don't see anything that looks fake at all... stupid, yes; fake? no.
a soldier blowing his own foot off
Sargent: "What happened Smith?"
Smith: "I was trying to put out my C-4!"
BUT KEEP IT COOL AT ALL COSTS! IF THIS STUFF HEATS UP, IT BECOMES THE TRIMER. AN INCREDIBLY UNSTABLE FORM. TEN TIMES THE SENSIVITY OF NG!
