Export Data From Arduino to Excel Sheet
8,533
177
Published
Introduction: Export Data From Arduino to Excel Sheet
Many times i thought of a system that will track a sensor readings for specific time and save that data for future analysis after doing the same task for several days.
So i make a system using the arduino and the amazing 1sheeld to save a LDR readings in an excel sheet and that is what we are going to do now.
LDR is an acronym for "light dependent resistor" as it's a resistance but it's value changed with light in the environment.
*1Sheeld is a platform for Arduino that allows you to tap into your smartphone's sensors and capabilities and lets you use them in your Arduino projects.
Basically, It is a hardware shield that sits on top of your Arduino board and communicates over Bluetooth to this Android app, to transfer data between it and your smartphone.
You can check all 1sheeld's tutorials which will take you from the early beginning into more and more advanced projects from that link ." http://1sheeld.com/tutorials/ "
and you can order it from here " http://1sheeld.com/buy/ ".
Step 1: Needed Materials
1x Arduino board
1x 1sheild board
1x LDR
3x jumpers
1x 10k resistance
1x Small bread board
1x Android phone
Step 2: Connect the 1sheeld Over the Arduino
Step 3: Download 1sheeld Library
You need to download and place 1sheeld library from here:-
https://github.com/Integreight/1Sheeld-Arduino-Li...
And then extract it to the location in libraries of arduino.
Step 4: Install 1sheeld App
Install 1Sheeld application on your android phone from here:-
" http://1sheeld.com/downloads/ "
Step 5: Design the Schematic of the Hardware
Step 6: Upload the Code to the Board
#define CUSTOM_SETTINGS
#define INCLUDE_CLOCK_SHIELD
#define INCLUDE_DATA_LOGGER_SHIELD
/* Include 1Sheeld library. */
#include
/* Define the ldr on pin A0. */
#define LDR A0
/* Define some variables for the time and ldr. */
int hour, minute, second, ldr;
/* Boolean to start logging. */
bool startFlag = false;
void setup(){
/* Start communication. */
OneSheeld.begin();
/* Save any previous logged values. */
Logger.stop();
/* Start the clock shield. */
Clock.queryDateAndTime();
void loop(){
/* Always get the time. */
hour = Clock.getHours();
minute = Clock.getMinutes();
second = Clock.getSeconds();
ldr = analogRead(LDR);
/* check If the seconds reaches zero. */
if (second == 0){
/* First insure to save previous logged values. */
Logger.stop();
/* Set a delay. */
OneSheeld.delay(500);
/* Start logging in a new CSV file. */
Logger.start("LDR values");
/* Set startFlag. */
startFlag = true;
/* Check logging started. */
if(startFlag) {
/* Add brightness level values as a column in the CSV file. */
Logger.add("Brightness",ldr);
Logger.log();
/* Delay for 2 seconds. */
OneSheeld.delay(2000);
    • Make it Move Contest
    • Planter Challenge
      Planter Challenge
    • Oil Contest
      Oil Contest
    This is useful for data logging
