iImage Information
After a dozen years of use, our washing machine no longer works during what should be the spin cycle. The timer will need replacement, but can be given a temporary extension of life to get us through a few more loads until the timer I ordered on-line arrives.
Step 1Remove control knob
iImage Information
The black arrow points to the control knob. Push it inward as you would to turn the machine "off." You can turn the push/pull knob counter-clockwise and it will unscrew from the timer shaft (red arrow). Pull the round indicator plate behind it off, too.
I don't have a welder and after reading the advice about why solder won't work I decided to slightly bend the tip of the arm up as to allow the worn contact to rest more firmly against the receiving contact.
So far so good. I don't expect it to last too long, hopefully long enough to track down a cheap replacement.
Again, what I did is only a temporary fix, although it would be tempting to see how long I could nurse this timer along before it was irretrievably useless. I am not sure I can get my spousal unit to agree. She likes things "from the factory." But, the price of these timers is astronomical. The first of these timers I bought back in the 1970s shocked me at around $37 US. The second was somewhat higher, maybe around $70. The local store price for this timer is about $185. I got a new one on-line for $112. I wish someone sold the contacts array as a separate item.
As for annotations, while in edit mode, simply clicking and dragging on a picture sets one, no button needed to start. Simply hit save when you're done typing to store the annotation :)
however I could be wrong...
I once repaired at sending unit in a car's gas tank that had its contact worn down from sliding across the windings on the rheostat. The wires on the rheostat act like a file over time, and on my 22 year old car the nub of a contact didn't contact. My method was to strip all the insulation off a fine stranded coper wire, it may have been a section of old Christmas light wire, then wrap as many of the fine strands around the contact. It is still giving a proper fuel reading and that fix was at least 5 years ago.
I have done some similar repairs, not for lack of time but of money. Here at "3rd world" that is normal. That I did was to solder over the old contact a thin brass sheet using tin, and I was successfull. Sometimes the new contact is too thick, and you must file all the old contact.
Your instructable warn me about the matter, our washing machine is some years old and possibly soon it will fail. I will be alert, thanks.
I keep in a compartment of my toolbox all contacts, are copper or bronze, when destroyed an electrical appliance, like a plug, switch, etc.
I'm thinking it looks like the brass pins breaks the whole current for their functions, makes sense that spin cycle would be the one to go since that involves running a motor at high rpm for a long time, just the motor freewheling must give some arcing feedback. I think you could extend the life further by letting it break a proper relay instead. That way the relay would take the arcings and feedback from the motor coils. Relays are usually better at it due to faster switching.
And, I have decided part of the reason my aim with the arc from my welder was inaccurate is that the wire comes out of the nozzle with a curve from the spool on which it comes.
