After dealing with it long enough, I decided to see what I could come up with. I wanted something cheap, and easy to disassemble so it wouldn't affect the portability of the stroller. I came up with two different handle designs. It cost less than a dollar more to make both, so it's worthwhile to be able to test both and see which suits you more.
Remove these ads by
Signing UpStep 1Materials and Tools
These are the materials I used, however, different stroller models will likely have different needs. Use this list to get a general idea of what you will need. I used 3/4 PVC because that's what fit the handles of my stroller. I stuck with 3/4 throughout as I figured it'd make a stiffer handle. It is easy to switch from 3/4 to 1/2, or 1/2 to 3/4 if needed. The best way to determine what suits you best is to wheel your stroller into a hardware store and start testing different fittings.
Velcro Ties - $4.99
PVC Cement - $3.38
1 - 3/4 PVC 5' - $1.49
1 - 3/4 Self Seal foam pipe insulation - $1.50
1 - 3/4 PVC Tee - $0.33
1 - 3/4 PVC Cap - $0.39
2 - 3/4 PVC Snap Tee - $1.32 - Basically a tee with the bottom cut off to allow snapping onto a piece of pipe.
2 - 3/4 PVC Threaded/Slip Elbow - $0.91
Tools
Most folks probably have these on hand, or can borrow them for an afternoon.
Hacksaw - for cutting the PVC to length
Utility Knife - for cutting insulation
Sharpie - for marking stuff
Not pictured - Tape Measure - for measuring stuff
I'm definitely using this!! Thanks!
And great Instructable!
