3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Extending the range of your keyless entry.
So this is my 1st instructable so CONSTRUCTIVE criticism is welcome. Anywho this site has got me looking at every day objects totally different now. I'm constantly asking myself how i can make ordinary objects better, or just make something cool. If your like me you have keyless entry on your vehicle and sometimes wish it could work farther away. Well this will help improve the range of your key fob a bit. Now before you go tearing apart your nice new factory key fob keep in mind this is easier to do on after market ones.
Step 1Identify antenna
Identify antenna
Ok, once you have removed the case of your key fob you will need to find the antenna. it will probably be a smooth flat surface so to solder to it you may need to rough it up a bit. Sand paper works fine. something with a lower grit rating is suitable. just be careful not to destroy it. Some antenna's are in the PCB board so you may have to figure out which circuit is the antenna.
29 comments
Jun 10, 2009. 10:10 AMyahooti12 says:
Actually, a long time ago Mythbusters tested out putting your keyless entry to underneath your chin to extend the range. It works because your voice box is a natural amplifier. I don't think it give you more than 20 extra feet. Anyways, that's what I do when I can't seem to find my car.
Sep 16, 2011. 9:00 AMgeorion says:
check that Mythbusters---again!!!!!!!!!!!!!!!!!!!!!!!!!!!Not the voice Box !!!!!!!!!!
Jun 24, 2010. 6:37 PMandrew_h says:
Ages ago i learnt a cool trick for extending the range too. It sounds 100% stupid but it works a treat. Simply put the remote under your chin (up against it) as you press the button. Generally extends the range by 20-30% or helps when your battery is a bit flat.
Apr 26, 2007. 2:59 AMscott00 says:
The looped wire is really smart and works for sure.. but the other "body antenna" step is unnecessary and effects the aesthetics of it. BTW, might not want to do this to new car keys as they are REALLY expensive.
Apr 19, 2008. 4:17 PMawkrin says:
really? well until now, I never knew what's inside one. the one from the pics above only has an microchip and 2 push-to-make switch so I guess the case is REALLY expensive...
Dec 20, 2008. 1:14 PMquentinwolf says:
Actually what Scott00 probably was referring to is the new car keys where the Key and Remote are all in one casing. They typically can cost $100-$200 to replace since they have a specific code for the vehicle that has to be programmed. So if you mess it up, that's what the dealer will charge to get you a new one programmed. The remote above looks like a standard add-on keyless entry system which would be fairly cheap.
Nov 7, 2009. 8:30 PMPyromaniacDaniel says:
I lost my original key fob to my Chrysler seabring. the key fob was $25. the service of linking it to the car was $75. however if you already own one and want to program a second there is a method found in the owners manual.
An instructable on how to DIY the linking service sure would be nice.
Sep 26, 2007. 6:27 PMvantheman says:
What works as well and doesn't need any modification: hold the keyless entry against your head (your temple is best). Press the button now and you will see you have just greatly increased the range. Your whole body is now the antenna. Try it, it works!
Nov 22, 2008. 11:44 AMNottslad89 says:
I used to do the same thing years ago, but I pressed the fob to my chin - putting it to your temple looks like you're gonna shoot yourself LOL
Dec 10, 2006. 6:55 AMTool Using Animal says:
Hmm clever, i've never thought about adding an antenna, it will be hit or miss though on proper length.
Jan 30, 2007. 4:54 PMIan01 says:
The frequency is probably printed inside.
Dec 11, 2006. 2:51 PMStrangeRanger says:
Not sure if this will work for other brands, but I use to work for a VW/Audi dealer and by simply holding the key fob up to your chin when pushing the button your range would be extended by 2-3x. Try it sometime. j
Jan 30, 2007. 4:52 PMIan01 says:
That probably worked because you were holding it higher.
Dec 12, 2006. 4:02 AMSidney Floyd says:
i found that for some reason, the keyless worked at a slightly longer range when i held it to my temple and looked at the car dont ask why i was doing this at the time
Dec 10, 2006. 8:08 AMkeng says:
well, nice idea but maybe clean up before doing the pics or do some photo cleanup afterwards.
Dec 10, 2006. 7:59 AMmrmath says:
Constructive: I don't understand what the round wire was for? You had us sand the antenna, then fit in a piece of wire with one end stripped, then you had us solder on the flat wire. What was the first wire for? Non-Constructive: Could have done without the pubic hair!
Dec 11, 2006. 6:34 AMmrmath says:
Yea, but what's the normal wire in step two used for?
Dec 11, 2006. 10:36 AMcrapflinger says:
maybe you could have soldered the pube in as an antenna....pretty sure that the pube (especially the labeling of it) was QUITE unnecessary (note to self: DO NOT try ANY of AgentDanny's soup recipes) might want to relabel the steps to show that they are alternate methods (i.e. Method 1 - permanent antenna, Method 2 - Your body as an antenna)
Dec 10, 2006. 11:30 AMtrebuchet03 says:
The range on my last key fob was decent -- about 60 feet... But if I could figure out the right wire length, I would have done this :P My new (to me) car has one expensive key fob... Not even a key fob, it's a switchblade key... For a grand total of $275 because VW has to plug in an uber computer so the car will accept the new key.... I think I'll leave that one alone :P
Dec 10, 2006. 3:48 PMteknubic says:
It's not so hard to do and certainly won't cost so much.
http://www.passatworld.com/forums/showthread.php?t=181120
Join the online VW community if you haven't already. They're good peeps. :)
Dec 16, 2006. 1:25 AMtrebuchet03 says:
I'm on vortex ;) I don't have a master key -- so I'd need a VAG-COM or the dealer to program. Then, we're not 100% sure which immobilizer version my cluster is running. So eBay keys may or may not work (and I don't have the cash to test). I've been slowly saving my pennies :P
Dec 10, 2006. 2:33 PMjohnson_steve says:
Ha, I have the same key I think it's quite a bit more complicated then the remote shown you never need to replace the battery and it even has an rfid tag in it; go ahead wrap it in tinfoil and start your car it will stall right away what vw do you have?
Dec 16, 2006. 1:30 AMtrebuchet03 says:
The keyfob has the same concept (in a different package). It does have a battery for the key less portion :P Here's how to replace the battery from a switchblade keyfob. I never thought of the tinfoil thing :P Sounds like a Faraday cage and an awesome prank :P
2000 Jetta... 2.slow edition.... on original coil packs (take that 1.8t's :P)
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:AgentDanny
