3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Extensible LED Beam
Extensible LED Beam
Extensible LED Beam
Do you get tired of that hundreds of LED doing the same thing over and over again? Turn on together, turn off together and flash together?
Or, if you know basic programming of micro controller, how many LED can you control with I/Os?
In this instructable, with the help of 74HC595, you would know how to form a standard section of 8 LEDs, which can be extented limitless. And it only takes 4 I/Os.
Not only on/off control to individual LED, but also brightness control on single LED can be carried out.
animation video of 2 Sections (16 LEDs):
http://youtu.be/aADcOLSNU0M
animation video of 3 Sections (24 LEDs):
http://youtu.be/qvYaGY43A5Y
animation video of 4 sections (32 LEDs):
http://youtu.be/FeqEkkHhzhE
Step 1Make the base board of a single section
Make the base board with a 80 x 40 perforated PC board.
Dimension matters. because not only the distance between LEDs in one section should be equal, but also the leds between section need to be distanced equaly, 1000mil.
Tip: When cutting off the board, you do not have to cut it through, cut groove on bothe sides, and bend it with a plier. It would take off easily.
5 comments
Jan 2, 2012. 3:33 AMagis68 says:
ok...i dont know about the extensibility of this circuit....i have some doubts....but anyway is a good idea....could you please upload in pdf or jpg the diagram for the leds in perforated pcb....(you have it here in small image) I need it larger.....plz
Jan 3, 2012. 1:15 AMagis68 says:
ok....thanks for your reply.....my email agisstr@yahoo.com
have a great new year!!!
Jun 19, 2011. 12:50 PMkelvinmead says:
how extensible do you think this could get?
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:aguegu
