The choice of nozzle is very important for external mix snowguns. Make Snow dot Net offers a package including all of the nozzles in this project for $60 bucks, all are stainless steel or nickel plated brass Here's the kit: http://www.makesnow.net/ExternalMixSnowgunNozzles.shtml.
Brass nozzles that have not been plated will wear quickly, and should be avoided.
DISCLAIMER: Dealing with high pressure water and air is dangerous, never point water towards people or pets, always use fittings rated for the pressures used. Wear eye and hearing protecton at all times. Makesnow.net is not responsible for any damages or injury.
1 MSM-X250 Nozzle (available at http://makesnow.net )
2 MSM 0204 Nozzles (available at http://makesnow.net)
1 MSM – X2A Nozzle (available at www.MakeSnow.Net)
1 22mm to ¼”NPT fitting (available at www.MakeSnow.Net)
2 ¼” NPT Street Elbow – 90 degrees (rated to at least 2000psi)
2 ¼” NPT Female T- fittings (rated to at least 2000psi)
2 ¼” NPT Female Elbow – 90 degrees (rated to at least 2000psi)
3 ¼” X 1” close nipple fittings (rated to at least 2000psi)
1 ¼” NPT Female to 1/8” NPT Male Bushing (rated to at lease 2000psi)
1 Roll of Teflon Tape
1 ¼”NPT female thread Compressed Air Quick Connect
1 Piece of Metal to mount the snowgun on
Remove these ads by
Signing UpStep 1Assemble the water plumbing
threads before attaching the fittings together, including the threads on the nozzles. Attach the Street Elbow to the end of one T-Fitting.
As the rest of the group has stated for future iStrbles you may want to just reference a supply house of choice and be much more detailed with your deign and assembly.
If there is anything One thing that is overwhelmingly clear throughout this entire post it would have to be "Don't sell us, Show Us!!!" Keep in mind the audience here is much more focused on doing, rather than buying. We understand that all projects will have a parts list, but it should be just that.
Thanks again for your willingness to share in the first place and we all look forward to your next iStrble.
More details would be greatly appreciated in a broader sense than "connect pipe A to fitting B and oops make sure you connect it right or it will not work". Also an explanation of why the pressure washer is required would be good. The instructable is interesting though.
I have several critiques of your design that I will say only to help with your snowmaking endeavors. I am not trying to tear apart your build, rather am just trying to share the knowledge I've acquired.
I would recommend using a rubber (not pvc) garden hose for your air line. The reason for this is the air being pushed by your compressor can be very humid and you will experience a buildup of ice on the walls of the airline. This will constrict your airflow and will eventually freeze it shut. Using a larger diameter line for your air will reduce the amount of restriction and will increase the time it takes for enough ice to build up to completely block the air. Not to mention, there will be less friction from the air on the lining of the airline and you will be able to push more air, since you want high volume, at low psi (I run about 13 cfm at 40psi). Those 1/4" air fittings are especially prone to freeze-ups, since it is a cold metal with a small opening.
Another thing you might want to consider is insulating your gun. Depending on the weather conditions, it can be very easy for the nucleating nozzle to freeze. Insulating the piping helps with this.
Also, it is a lot cheaper to buy nozzles directly through a distributor than from a specialty "snowmaking" website, which I can't help but notice you plug a lot. Sometimes you can even get free or highly discounted samples from directly from the manufacturer. I buy all of my nozzles and specialty fittings, like pressure washer hose fittings, quick-connects, garden hose fittings, etc. from Pressure Parts, and then I buy all of my plumbing from MasterCarr. The nozzles should be more than about $20 total for all the nozzles you'll need for most snowguns, unless you buy a special nozzle.
I get really annoyed when an Ible is more of an advertisement for product sales than an instructible.
amend your Ible to include a detailed description of that please
Possibly I'm missing something here but that bit comes off a bit like an embedded advertisement for the pre-built option.
Otherwise, a fine and detailed instructable, thanks and well done.
