External Trigger for Stop Watch
 by vkoudymov
Featured
This instructable will show how to add an external trigger to a stop watch so that it can be used for event timing from circuits. It's designed to accept from 1.5 - 50 VDC, though I've only tested it from 1.5 - 9 VDC.
Step 1: Dissemble Watch
Take the watch apart.
amandaghassaei says: Aug 28, 2012. 10:59 AM
neat, what are you planning on using this for?
vkoudymov (author) in reply to amandaghassaeiAug 28, 2012. 8:01 PM
A microcontroller that I'm wanting to use has a discrepancy between the datasheet timing and the simulator timing so I want to see how much time analog-to-digital conversion takes. I figure I'd be able to put the analog-to-digital conversion inside a loop and then calculate it from there.
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
