Introduction: External Winamp Control
Nowadays, winamp have full support to keyboard shortcuts. But some time, when winamp didn’t have this feature, I was thinking in some way to make a easy way to change music by simply pressing one button, it would make things faster and would help me to change music during games. So I decided to make a external control painel, to make it easier to change musics, volume up or down, toggle shuffle and many other features by pressing just one button. I found one winamp plugin that shows how to configure a external control using the Serial Port, being able to make 4 or 15 buttons control. I decided to make this, step-by-step, how to do it, hope you enjoy.
My site for those who would like to see more of my How-To's:
Pasteler0's Tech Blog
Material:
1. 4 push-buttons
2. SERIAL connector
3. Connector Box
4. Cable
5. Soldering iron and accessories
As you can put the buttons wherever you want, I decided to put mine in one old diskbox.
I decided to use a network cable to connect the Serial connector to the buttons, because its easier to organize and makes the work simplier and faster.
Material:
1. 4 push-buttons
2. SERIAL connector
3. Connector Box
4. Cable
Step 1: Step 1
Making the control:
1. Looking in the scheme, we see that we have to connect one side of each buttons to one cable, these will be solded in the pin number 4.
Step 2: Step 2
After have done the soldering in one side of each button, you must then connect the other side with a cable that goes to the pins of the serial, now however is important that they are connected with the indicated pins (Just follow the scheme) .
Here you can see a picture of my work until now, it looks quite ugly I know, sorry
Step 3: Step 3
Configuring Software
The software I used in this was COM-port Winamp Control V.1.42.
1. You must set the COM port you are using, usually normal computers have up to 2 ports, so just select the one you plugged the control.
2. Select the number of buttons does your control have. (In this HowTo, we’d choose the “4 buttons”)
3. Now you much remap the buttons, Its now the time you’ll see it is everything working. If you are able to remap all the buttons, congrats, its working!!
4. Its ready, now the last step, you have to configura what you want the buttons to do. This can be found in the “WINAMP” of the program. There you can setup many different options, like Volume Up, Volume Down, Next Song, Previous Song.
5. One cool stuff is there in “Type:”, where you can configure the way you wanna the buttons pressing to respond.
- Click: Just one click to make it work. Can work with one or double-click.
- Down/Up: This will activate the option when you press and a different one when you release the buton.
- Turbo: Here you configure the options for holding the button, usually used for Volume Up and Down.
- Clicks + Turbo: You can configure “Clicks” and “Turbo”Option at the same time
- Clicks + Hold: You can configure “Clicks” and “Hold” Option at the same time
Step 4: 4 Step
And here is the final work... :)
Please visit my website for more howto's
pasteler0's tech blog
Thanks!
Thanks!
