Things you will need:
Breadbord that is big enough to fit a few capacitors.
Disposable camera circuit boards. (x5 recommended)
Soldering iron
Solder
Needle nose pliers
Magnet wire, I used 30 gauge
Graphite pencil lead (The wooden pencil thickness, not the mechanical pencil type), for shorting the Capacitor leads, minimizing damage.
Wire cutters
Hookup wire, I used 22 gauge.
I am assuming that you have a basic knowledge of electronics and soldering, so read up on these fields before attempting this instructable to prevent harm to yourself, and to make this a lot easier.
Also, ignore the capitalized improper nouns, I'm thinking German.
MVI_8424.AVI(320x240) 2 MB
Remove these ads by
Signing UpStep 1Explanation of the problem.
The Primary transformer on the circuit board converts the 1.5-volt source of the battery to the 300-volts that the board needs to charge the capacitor.
The secondary, on the other hand, performs a completely different operation. When the capacitor is fired, some of the electrical energy is passed through the secondary, where it is converted to over 1000-4000 volts. This energy passes through a small portion of wire, which is placed near the flash tube. When this happens, the neon gas in the tube is ionized, which allows the 300-volt payload of the capacitor to run through the flash tube, and emit light.
Most likely, when and if you mounted the flash tube externally, you forgot this important detail. This is why you likely had problems with it.
Please build a discharge tool before working with these, and make sure caps are discharged.
You guys shocking yourself is not a good idea, especially with the cap bank described.
thx
Also, what type of capacitor leads are you using? I know they have different resistances and such.
