Extra Hand for a Drink Cup
1,462
28
10
Posted
Introduction: Extra Hand for a Drink Cup
I have been working on a project in a library. I am able to take a drink cup, but sometimes am short a hand for managing doors while carrying everything. This carrier suspends my cup from the bag for my supplies. A cup could also be suspended from a belt loop or a lanyard around one's neck.
Materials
  • 3/16 inch rod
  • Links from 3/16 inch chain
Tools
  • Caliper
  • Hammer
  • Vise
  • Hacksaw
  • Welder
  • Grinder
Step 1: Measure the Cup
I used a caliper to determine the diameter of my drink cup in the area where I wanted to steel ring to support the cup. If the ring can be as high as possible, the cup will be more stable. This cup looks like a paper throw-away, but is actually plastic and double walled. It is from Bed, Bath, & Beyond.
Step 2: Bend the Rod to Fit the Cup
The rod may be formed around a piece of steel pipe. Instead, I made small crimping bends and fitted the resulting curve to the cup, making adjustments as needed.
Step 3: Does It Fit?
My plan had been to multiply the diameter of the cup by п (3.14). I even allowed a little extra, but still came up short.
Step 4: Chain to the Rescue
I cut the end from a link of chain and welded it to the two open ends on the ring. (At the end, I welded a short piece across the link of chain to keep the handle from sliding down around the ring.) The chain link allowed some final adjustment of the ring size. I could squeeze the chain link in a vise to make the ring a little smaller, or I could drive a wedge, like a cold chisel, inside the link to spread it and make the ring larger.
Step 5: Bend a Handle
I bent the end of a piece of rod like a shepherd's crook. The tool I used is described in this Instructable.
Step 6: Attach a Chain Link to the Handle
I opened another link of chain enough to slip the end of the rod handle into the opening. I slipped the link of chain over the link that closes the ends of the ring. I welded the handle rod to the chain link.
Step 7: Grind Smooth and Use
I ground away any roughness in the welds.
The finished carrier folds relatively flat when not in use.
    • Science of Cooking
      Science of Cooking
    • Microcontroller Contest
    • Spotless Contest
      Spotless Contest
    10 Comments
    What a great idea!! Thanks for sharing! :D
    Thanks. I keep thinking about a version without welding and/or a lock that would keep the cup level for less chance of spilling.
    Beautiful welding !
    I assure you, you are the only person to say that to me. Thanks.
    Thank you.
    This is what I search for. Thanks for this instructables.
    Thank you.
    Thank you.
