3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Extra special fancy moisturizer for eczema
Step 4Cream instructions
Cream instructions
In a separate container, warm up:
8 tsp distilled water
1/2 tsp glycerin
Using your milk frother, slowly drip 2 tbsp of the oil mix into your hot water and glycerin till the cream is well emulsified. Blend in 0.1g Germall Plus, about 4 drops.
Pour the cream into one of your containers, and the remaining oil mix into the other. Store in the refrigerator. LABEL your jars properly!
If you are making the cream for the second time using left-over oil, you will need to melt 2 tbsp of the oil mix in your double boiler before blending it with the hot water.
Note on preservatives:
Germall Plus is a proprietary mix of Propylene Glycol & Diazolidinyl Urea & Iodopropynyl Butylcarbamate which comes in liquid form. It is paraben-free and should be used at a rate of 0.1 to 0.5% of the total formulation (by weight). It is particularly important to be careful about bacteria growth in your moisturizer if your skin is compromised -- but on the other hand, having sensitive skin might make you react more than other people to preservatives. This is why I generally prefer to make very small quantities often, and omit the preservative. In fact, I usually half this recipe (I use 1 tbsp oil mix, 4 tsp water and 1/4 tsp glycerin). Once I have the oil mix it just takes about 5 minutes to make a batch of cream, so I don't mind making it often.
Note on ingredients:
Although I've never been able to detect any difference in the cream quality between regular tap water and distilled water, when I'm making this special ointment cream I generally prefer to used distilled. Tap water is fine though, at least in New York...
Glycerin is a by-product of soap making. It is a humectant, which means it attracts and absorbs moisture. Adding it to cream helps your skin absorb moisture from the air, but if you use too much the texture of the cream suffers, it starts feeling sticky. You can try replacing it with a pinch of urea (which is also a humectant but won't make the cream feel sticky). I like urea better, but it makes my husband's skin itch. One important piece of advice: don't try to make your own urea -- at least if you are in a relationship and want to remain so.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
265
Author:belsey
I am trying to work on an overly ambitious tome, MAKE ANYTHING, a handbook for saving money, living green and having fun with trash. Trouble is, I keep getting distracted by pop-ups -- the cards, not ...
more »
