Step 3Dissolve the Caffeine
Allow the mixture to settle into 2 layers.
Wait until the alcohol layer becomes clear.
After it settles suck up the clear solution with the eye dropper and pour it onto the pane of glass.
The solvent will evaporate leaving a layer of caffeine crystals.
Continue adding the solution and drying until you run out of clear solution.
Then add more alcohol and repeat this step until you feel that there is no more caffeine in the undissolved bottom layer.
5 bucks for 2 ounces (about 60 grams)
id be nervous having that around though 2 grams is enough to make your caffeine high very unpleasant and around 20 grams is enough to kill a 100 kilogram guy like me.
Very interesting!
But you can now buy caffeine powder on amazon.com too.
More or less you will want to wait for any of the insoluble particulate matter to settle to the bottom of the solution. This is easier to do if you pour the solution out of the mortar and into a small beaker (or smooth piece of kitchenware, such as a shotglass, if you do not have access to laboratory glassware).
