Extreme CD Repair
Extreme CD Repair
This method is the most extremely effective way on bringing back unreadable and heavily scratched CD's but a word of CAUTION! it is also the most risky and dangerous!
You need the following to begin with.
1. A Gas Stove
2. Cotton Towel
3. Pot with 2 inch of water.
4. Fork.
Step 1Position the fork into the CD.
You need to insert the two tooth of the fork into the center of the CD.
Make sure that the fork doesn't change the CD's contour too much, and it must be straight and even.
63 comments
1-40 of 63next »
Apr 15, 2010. 5:15 PMBuskieboy says:
This is a joke right?  Maybe you can "dry" it in a microwave after too?
:D
I know we can flag comments, but how do you flag a whole instructable?
This should be removed before too many, um, challenged people try this.
Jan 25, 2012. 5:34 PMilpug says:
No, it isn't a joke. This works, although not very often. This really doesn't need to be flagged. Nowhere near as bad as some instructables. At leas this one won't kill you.
Aug 8, 2011. 8:59 PMBALO77 says:
or as I like to call him : SUPER VILLANO
Aug 8, 2011. 8:34 PMBALO77 says:
WELL, HIS USER NAME IS .....supervillain!!!!!
Mar 26, 2011. 8:44 AMvideogamemaster says:
Wow. That's desperation for you. I just use lotion.
Jan 6, 2011. 4:40 AMDanixoldier says:
Thanks! this help me alot :D
Dec 13, 2007. 9:52 AMch4zl33 says:
I tried this on my windows vista CD and you ruined it. It just melted the CD. thanks a lot.
Nov 11, 2010. 12:04 PMcybercoho72 says:
it is more like u ruined it u are the one who tried this method so it is your fault. so look in the mirror before u point fingers.
Apr 13, 2010. 10:08 PMbounty1012 says:
Well, there was a disclaimer before doing this, and you should've known better to cook your CD over a flame...
Feb 11, 2010. 5:49 PMbasketball is life says:
haha. this comment made me laugh for like 5 minutes
Dec 28, 2009. 9:06 PMnobodysfool says:
Technically YOU ruined it.
Aug 26, 2008. 7:04 PMDavvik says:
Why would you WANT to fix a vista cd?
Jun 20, 2008. 7:08 PMgamerguy314 says:
like sumplesnoob said, why in the hell are you going to use a CD that you are going to use again for your FIRST TIME TRYING? thats just plain dumb. when doing an instructable like this don't use something you really need -.-
May 8, 2008. 4:03 PMGamernotnerd says:
Think of it as a good thing. Now you never have to commit suicide due to mental trauma from vista - Vista owner.
Jun 23, 2008. 2:15 PMchibiturtleboi says:
Vista isn't that bad as long as you have a good bit of memory. Most people only make jokes about Vista because it's become such a widespread thing. Xp is great but vista is good as well
Jan 5, 2008. 10:50 AMsumplesnoob says:
First of all, why didn't you try it on a CD that doesn't cost over 100 dollars before the Vista CD? Second of all, if you were reading this tutorial, your CD was ruind in the first place. Don't blame this on people that try to help.
Feb 28, 2010. 8:40 PMgruda says:
 it actually kinda worked for me, but I did it as a last resort and I practiced with blanks first.
Nov 8, 2009. 4:35 PMyouhurtmehbrain says:
I tried this... and it warped my cd just SLIGHTLY, so being the rocket scientist genius I am, I decided to try and bend it back with my hands. I snapped the cd clean in half. Fail.... do you have a repair tip to put it back together? :(
Feb 11, 2010. 5:51 PMbasketball is life says:
lol fail!!!!!!!!!!!!!!!!!!!!!!!!! oh and on putting the disk back together i suggest using elmers glue.
Jul 24, 2009. 4:32 PMGage987 says:
everybody says this dosent work or its dangerous it works because you remelt the bottom of the cd getting the scratches out permanantly and if you have a brain you should be able to do this
Jul 2, 2009. 9:18 PMvandal1138 says:
Or how about this? Everyone use common sense! If you feel the need to do this, its your fault for screwing your cd's up. The system works for the guy who wrote this. If it doesn't for you then blame yourself, not him.
Apr 23, 2009. 11:05 AMneumanngregor says:
lol if you got scrached cd/dvd's there is a kit for repairing scrached displays of GSM phones, clean the disc with WHITE alcohol and use a cooton pice of cloth to GENTILEY wipe the surface, then use the kit's fluids/tools AS IN THE TOOLS INSTRUCTION OF USE on your disc.
Jan 6, 2009. 2:37 PMUS.Marine9_11 says:
This is borderline bogus. If you heat a cd in one place or entirely without a press, it will deform (warp) and there's no way to fix it. Also, to get it to that point, you have about a 90% risk of disconnecting the film from the top side. I bought my first Sony cd player for my car in 1986 and due to the outrageous prices of compact discs, I learned how to repair my own cd's. I started out with extremely fine grit wet/dry (auto body) sand paper, but now I've graduated to using my Dremil tool. I use a fine buffer pad, A LOT of patience and the ultra fine polishing creme (greene stick) that I got from Lowe's (Home Depot or Marvin's). It does take plenty of time because it's a really slow process if you don't want to destroy the cd. With the price of games for PS 2/3 and X-Box/360, it's well worth the time.
Nov 25, 2008. 5:57 PMhadtotry says:
Ok, my sons xbox 360 game was ruined. Tried every other fix so this was worth a shot. I used an electric stove top since I don't have gas and figured it just needed heat. I left it above the burner a second too long and the inner plastic melted and fell off my fork onto the burner. (Wish I would have used tongs.) I have to say that the scratches were gone on the areas that didn't touch burner! This method probably works. Advice for those who might give it a try: practice on a CD you don't care about and use tongs.
Nov 12, 2008. 1:07 PMjunits15 says:
does this actully work?
Jan 4, 2008. 9:33 PMidiotjohn says:
Sorry to be a nitpicker, but the cd isn't as good as new - it still has all of the data on it (thats if it does work) and isn't new (because new cds are blank) John
Jul 5, 2008. 8:06 AMDeltaforce2555 says:
Not unless you buy it with data on them.
Oct 2, 2008. 8:12 PMDBLinuxLover says:
Depends on your defination of new.
Aug 30, 2008. 1:09 AMdariel24 says:
oooohhhh.... I's A Brilliant Technique!!!! :-D I tried this and the CD "magically" (even though i know it's based on scientific reasons like jessifu said down there) remove all the scratches on my CD. i am sure any CD "Meltdown" only occured if lack of care is given to the CD and you have low "sense of heat" (as i called it) Just a few tips from me: - if you think you are going to use candle instead of stove because of less flame, DONT do it. it will give the CD a nasty black spots on the CD surface. - When heating the cd on open flame, give some space between the CD and the stove using simple estimation or guess using your "sense of heat" - dont use fork if you have any other holder, because fork can cause a heavy scratch on the data side of the CD, ruining the files.
Aug 27, 2008. 12:38 AMdariel24 says:
i do think it WILL repair the CD after reading jessifu's comment down there. but maybe after boiling the CD, wait for it to cool down cus' taking it straight away when the water still boiled may bent the cd..... someone aggree? ps: i'm not yet trying this instructable at home for financial and health safety..... lol
Aug 27, 2008. 12:41 AMdariel24 says:
oh... or maybe try boiling it only. (without open flame heating) boiling it will still melt the polymer into its original shape isn't it?
Aug 9, 2008. 8:13 AMallureoftheearth says:
this just melts the cd and unuseable.if your quick. it won't
Jul 20, 2008. 11:18 PMXcr0n says:
where the title says Extreme CD Repair, it should read Extreme CD Destruction! Anyone who actually tries this to fix a cd is a moron.
Mar 20, 2008. 5:10 PMkillajones says:
Try toothpaste to remove the Vista melts.
Mar 13, 2008. 2:13 AMkillajones says:
OK, i don't want to real comments for the next half hour. So, does this method wipe the CD clean or repair it so it will work properly??? P.S. I am going to try this with by brother's Halo CD because it's so scratched up now it won't even load up.
Feb 14, 2008. 5:56 AMThe magical duct tape kid says:
Truly amazing +1!
Jan 18, 2008. 10:02 PMMoto42 says:
I'm seeing a lot of people posting comments that read "I tried this, and now my $ cd is stuck to my overpriced saucepan. [b]You[/b] ruined them both!" The first thing I have to ask is, why are you doing this to a cd that are not already destroyed beyond all other hope? Your neglect (or bad luck is some, atypical, cases) already killed the cd. If the cd still worked, then your foolishness in submitting it to such treatment destroyed it. What part of "This is the most risky and dangrous [method of cd repair]" did you miss? As for the saucepan, well, why are you hacking with your good cookware?
Jan 30, 2008. 3:24 AMblckpythn says:
I have to agree with you here, these people are complaining about something that nobody made them do. It's the internet since when is 100% accuracy guaranteed. It's called "User Error" and you now know it well, people.
Jan 18, 2008. 10:04 PMMoto42 says:
Oh, and just for the record. I have used this technique successfully in the past. Though it erased the CD-RW I tried it with.
Mar 28, 2008. 5:31 AM_soapy_ says:
That makes sense, as it is a thermal effect that wipes them. The "blobs" are made with a reversible dye.
1-40 of 63next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:supervillain
