3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Extreme Surface Mount Soldering
Step 5AC Control Unit - Mechanical Construction
Have another look at Picture 5 to see what the completed unit looks like. Well use the single switch box as a support inside the double box. Cut it so that you have a piece about the width of the perf board the circuit is built on  about 1.6 inches. It's not critical, you just want this to support your circuit and hold the terminal block. Picture 13 shows this.
Mount the terminal block to it about midway up. To make this fit in the larger box you may need to do some additional cutting on one box or the other. Picture 13 and Picture 14 show details. Basically, your goal is to hold the parts firmly so they can't short out. The stiff, 14 gauge copper wire will help with this.
The diagram AC Control Hook Up and Picture 14 show how to hook things up. When you're done, the unit should look like Picture 5.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
41
Author:doctek
