3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Extremely Easy and Safe Trip Wire!
THE EASY AND SAFE TRIP WIRE!
Hi Everyone!
This instructable will be easy to create, fun to play with, safe, and extremely inexpensive to create!  I may post a laser trip-wire instructable in the future.  There are hundreds of ways to make one of these, but this one is EXTREMELY SIMPLE, and really costs less than a dollar or two to create.  Please have a look at my other instructables, and visit www.engineeringshock.com or www.electroniclessons.com !
WHAT YOU WILL NEED:
1) Soldering iron (with solder)
2)  A DC Piezo buzzer or siren
3) A 10k Ohm resistor
4) An NPN transistor (I used a 2N2222, but a 2N4401, or really any NPN transistor will do.
5) Two nails (Optional)
6) Some extremely thin wire (I prefer extremely thing gauge magnet wire.
7) 4x AA or AAA batteries, and preferrably a holder
You actually have a lot of room for the imagination here.  You'll see what I mean as we progress.
Step 1The Circuit
The Circuit
The circuit is extremely easy.  Let's go though it in detail!
1) If we place our 4x AA or AAA batteries in series, we're going to have a voltage of roughly 6v, which is perfect.  You can use a 9v battery, but you have to make sure that your buzzer is designed to withstand 9v.  If not, you may need a 5v LM7805 regulator.  In this case, place the batteries in series.
2) As you can see, we've got a 10k ohm resistor connected between the positive battery lead and the base of the NPN transistor, which is also connected to the first post.  Note that the second post is connected to the negative lead of the battery pack.  For those of you who don't know much about transistors, we are using it as a switch.  When power is applied to the base of an NPN transistor, the power at the collector will drain through to the emitter, which is connected to ground.  We're going to get back to this portion of the circuit in just a second.  Please note that I've included a bunch of images that give examples of how to use NPN transistors as switches.
3) We have the positive lead of the DC buzzer connected to the positive lead of the battery.  The negative lead of the DC buzzer is connected to the collector of the transistor.  Since the emitter of the transistor is connected to the ground line (negative lead of the battery), then power is applied to the base of the transistor, power is applied to the piezo and drains to ground from the collector to the emitter (Completing the circuit).  When there is no power tied to the base of the transistor, the buzzer circuit is not complete.  In other words, the buzzer will not sound.  When power is applied to the base of the transistor, the buzzer circuit is completed, and the buzzer turns on.
4) Let's have a look at the nail posts.  We have one nail post connected to the base of the transistor and the protective resistor.  The second nail post is connected to the ground line.  When we connect our magnet wire loop between the nail posts, this connects the base of the transistor to ground, which means that there is no power applied.  As soon as that magnet wire breaks, power from the positive lead of the battery pack is applied to the base of the transistor, and the buzzer will sound until you can either turn the power off, or reconnect the wire.
5) You can loop the wire pretty much as far as you want. As long as your magnet wire is intact, the buzzer will not activate.
IN BASIC TERMS:
- Power is required for the circuit to work. We are using a 6v battery pack (4x AA or AAA batteries in series)
- Until power is applied to the base of the transistor, power at the collector (connected to the negative lead of the DC buzzer) will not connect thorugh the emitter of the transistor and connect with ground.
- The 10k Ohm resistor acts to protect the base of the transistor, as well as limit the current to the circuit.  Without it, there would be absoluately no load, and the battery pack would short circuit.
- When the magnet wire between the posts is connected properly, the power at the base of the transistor is sunk to ground (0v)
- When the magnet wire is broken, the path to ground at the base is broken  When this happens, the base of the transistor receives power, and the DC buzzer circuit is completed.  the result?BEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEP!!!!!
5 comments
Mar 13, 2012. 9:15 PMToyospearo says:
I also had to splice some wire on the ground side. I didn't have enough. Thats the purple you can see.
Here is the magnet wire I am using.
I am trying to get this up and running for a friend of mine who's x boyfriend keeps slashing her tires late at night.
Mar 13, 2012. 9:39 PMToyospearo says:
one more thing... If I wrap this 36 gauge wire back on itself 10 or so times and then connect all the wrap together strands to the two nail posts it STILL will not work. Could it be the wire I am using? The place I bought said it was magnet wire. Could you give me a specific company or brand name perhaps? I am thinking this wire is the issue.
Mar 13, 2012. 9:01 PMToyospearo says:
I followed the instructions carefully and I am reasonably certain everything is in order. However, I attached 36 gauge magnet wire to the posts and I couldn't get it to work. I did get it to work with a thin piece of wire from some 14 gauge. If 36 gauge is not working what gauge will???
A few differences in mine are I used a 6v dc buzzer not a piezo buzzer. I also used a battery pack with an on off switch.
Any comment on what's up with mine not working please let me know
Nov 9, 2011. 3:26 AMamchugh says:
I love this circuit, i wish i could have found this earlier and made a sentry light with the trip wire.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
69
Author:EngineeringShock(engineeringshock.com + More!)
Hi there! My name is Patrick, and I am an electronics engineering technician who works full time as a lab tech, and part time as an electronics engineer/salesman. I own an ebay store, and two website...
more »
