Here are the basic steps:
SETUP
-Assemble simple drill lathe
-Cut stock (pink foam)
-Mount stock on lathe
Rough Cut
-Shape the square stock to a round cylinder
PATTERN PREP
-Find or make a pattern
-Cut out the positive and negative profile
-Transfer pattern to rough cut stock
Shape
-Follow the pattern
-Cut largest diameter of first feature
-Cut smallest diameter
-Connect the cuts
-Check against pattern
-Sand
Finish
-Sand with fine grit
-Seal or paint
-Polish
-Remove
Remove these ads by
Signing UpStep 1SET UP
This lathe uses a face plate, so the work is only supported on one end instead of two. The face plate is okay for small projects, think of it like a potters wheel. This face plate is from a Craftsman sander attachment for a drill. (does anybody know what it is called?)
To assemble the lathe, just put the sander attachment in the drill chuck and mount your drill on a workbench.
Next - cut the stock to roughly square. For this project I am using pink foam insulation. This is easy to cut and sand and if it flies off the lathe it will not hurt you. (I do cannot guarantee that you will not get hurt). You could also use white packing styrofome, but the pink foam an a smaller "grain" to it making for nice cuts. Plus I had some in my basement.
When cutting the stock you want the final piece to be as square as possible, this will make the next step easier. Cut the stock to the length about 2 inches longer then your final product will be. (You will need to sacrifice the bottom portion, and it helps to have room for error on the top as this will be your first cut). I think that 8 inches is the limit for this faceplate technique.
Now - Mount the stock on the face plate. I do this by using HOT hot glue. I have a big Craftsman glue gun that gets very hot. I use this with high temp wood working glue sticks. They take about 5 minutes to start melting and are yellow for some reason. I also use this method for mounting wooden stock on the faceplate of a full size wood lathe. The only problem I have had is getting all the glue off the face plate for the next project. With a wooden face plate you can use a heat gun, or throw it in the oven. With the plastic face plate used here you will have to scrap it off carefully.
Great - now you are ready to start turning!
lol seriously though excellent results! I would love to see some people's faces though if one started playing chess with these on a backpacking trip ...especially if they and the board (which should be foam as well) were made to look like they were made of granite :D
Wonder if anyone has tried any hot wire foam cutting tools combined with such a "lathe" as this? I sometimes cut foam with a hot wire to make papier mache objects, but foam on a lathe never occurred to me.
It does not look like they do.
You should contact Craftsman, this is a neat product for hobby use - well suited for the Instructables crowd.
This is too bad -- I've noticed a major decline in the quality and variety of tools available through most retailers.
Woodworkers Warehouse used to have an amazing selection of chisels and lathes - I don't know where you would buy one today adn I don't mail-order and any tools that could kill me.
They have retail shops and online shopping.
Here is their findastore:
http://www.harborfreight.com/cpi/ctaf/retail_stores.taf
1. The foam will not absorb any liquid. It is a closed cell foam, not like a sponge.
2. You can not use any solvent based paint or resins on the foam. It will melt quite quickly into a nasty goo.
3. Some things you can use to coat and seal the foam: spackling, epoxy resin, plaster, watered-down white glue or wood glue, acrylic paint, or latex paint.
4. Once you seal the foam, you can use any type of paint or finish on it. HOWEVER, if you have even a pin hole open to the foam, it will dissolve from the inside out. Trust me on this. I once lost 30 hours worth of work on a model for a college packaging design class.
My favorite sealing medium to use is epoxy resin. It gives a nice hard coat that sands well. You can build up many coats to make a thick shell and hollow it out with acetone through a hole in the bottom, but this makes a toxic goop that you will need to clean up.
Here is a 1/4 scale design of an imaginary futuristic Formula 1 car I did as a student many years ago. It is made with this kind of foam and epoxy resin. Finished off with automotive grade base coat/clear coat paint.
In general anything that spins can be made into a lathe - it is just a question of safety. Foam is good to experiment with because the foam will typically break first.
The chuck on my router doesn't close enough to hold the sanding pad shown in this Instructable (that is as far as I got)
For safety - I always start on the lowest possible setting, usually I flick the power on-and-off quickly just to see how the set-up will move.
It is best to rotate the piece by hand before turning on power. But with alot of non-lathe power tools this is not possible.
Please let us know how you make out!
I think GIANT FOAM LATHE would be a good one too - I just don't want to buy the foam!
