3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
FAST FOAM LATHE
Step 3PATTERN PREP
PATTERN PREP
Turning can be done freehand - or by using a pattern. It is useful to learn how to use a pattern if you want to make a lot of one thing (like a chess set). I'm using a pawn as an example.
Steps: PATTERN PREP
-Find or make a pattern
-Cut out the positive and negative profile
-Transfer pattern to rough cut stock
-I used a pattern from - http://www.freechesssetplans.com/
-I find it easiest to resize in power point. I made a few sizes that would be close, then held the blank cylinder up to them to pick a size. You need the diameter of your cylinder to match the largest diameter in your pattern (or at least be close)
-Carefully cut out the profile using an exacto knife. Both the positve and negative profiles will be useful.
-Mark the major featurs on your cylinder. I do this by holding up the positive profile to the spinning blank sylinder and markin the high and low points with a marker. Mark the bottom of the peice with a thick line, this will help you to alight the pattern as you move along.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
42
Author:marc.cryan
Looking for access to land or water in Boston Metrowest area.
