FBRKN String Lamp
7,358
331
7
Published
Introduction: FBRKN String Lamp
About: Fabriken is swedens first makerspace and now we're at Malmö Makerspace
Build a sixties inspired string lamp.
At FBRKN we cut out the pieces in the laser cutter and the assembled them by clicking them together. The string then holds it all in place.
Begin with downloading the AI vector file FBRKN_lamp.ai and convert it to fit your requirements.
Step 1: Cut, Paint and Absemble
Cut out the pieces in the laser cutter. We have used 4mm MDF but you can use acrylic plastic or any other material of your choice. If you don't have access to a laser cutter it is possible to cut the pieces with a scroll saw if you are patient.
You should get 6 "sides" and a top and bottom piece. The top piece is the one with the round hole that fits a standard, Swedish, light socket. Change the hole size if you have a different fixture.
When the pieces are cut you can paint them, we choose a black acrylic spray paint.
Step 2: The Parts and Assembly
The sides pieces also have a top and bottom. The left one in the picture above is the top one and the right the bottom one.
In picture 2-4 you can see how they fit together. Begin with the top piece and put all the sides together by pushing them in the notches on the top piece. It might be a good idea to use some ordinary glue in between but it'll stay without.
Step 3: The Bottom
Turn everything around and do the same thing with the bottom piece. Start with one side piece and work your way around.
Step 4: The Thread
Take the thread of your choosing and thread a needle. There are four small holes on all the side pieces, one by each angle. Choose where you want to start and pull the thread through and make a knot.
Now it's time for you to start wrapping the tread around the lamp. You can thread it in different ways for different patterns and effects. You're also able to change colour of the thread if you like. You can either make a knot by a notch and glue the thread down or you can go through one of the holes on the sides. It's all up to you!
Step 5: You're All Done!
    • Make it Move Contest
    • Woodworking Contest
      Woodworking Contest
    • Casting Contest
      Casting Contest
    7 Comments
    I put a vintage lightbulb inside and hung it with an IKEA cord. For yarn I used some pretty thick stuff to diffract the light, and the material was a fiberboard from a clipboard at a local arts store. In total this came out to $35 (laser cutting was free at my school's shop). It's an awesome project and looks great when you're done.
    15, 3:17 PM.jpg
    Wow! That looks really great!
    Looks like a have a new project to try. Thanks for sharing.
    We actually tested that with at short EL-wire and it was really cool. We only had 1,5 m of EL wire in the makers space to we didn't end up using it. But it is a really good idea. Our next string lamp will be made with UV-leds and phosphorescent thread/dyes in a "classical" rave manner :)
    Very cool, I am definitely going to give this a go!
    This is really cool! I love obscure lamps, thanks for sharing!
