3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
FFVII Buster Sword Tutorial
Step 5Putting together the frame
Now that you have all that done then you can sand them down so they are nice. Now take the back and the supports, you are about to put them together. Take the gorilla glue and follow the instructions on the container and glue the supports in intervals on the back, take the nail gun (probably connected to an air compressor) make sure that the pressure is not too high since that will just go through the wood. It would be a smart idea to test it out a scrap piece of the same wood. Once you get it right then you should put them together. That is quite enough work for one day, and you need to let this dry for AT LEAST 4 hours, but you should let it sit a full 24. If you still want to do more work or you have come back after a day then you’re ready for the hand guard and handle. Take some large pieces of wood (if you’re lucky like me they should just bee sitting near where you do all of your work and you won’t have to buy them). Mark the center; this is where you are going to drill the hole. Now use a bit that is a bit bigger then the large dowel you are using as a handle. Drill them through both
[see pictures 1-3]
Go ahead and glue them in place, clamp them and take the handle, cover the part of the handle that will be inside the sword with some gorilla glue, not too much but enough. Now put in the handle and cut it off a bit longer then you need it for the sword, at least that is what I suggest.
[see picture 4]
Now let that dry over night. You can move on to a different part but leave that part dry, you should now have a nice looking drying frame.
[see picture 5]
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
9
Author:ditto125
