3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
FFVII Buster Sword Tutorial
Step 8Now it's starting to look like a Buster Sword
Now it\
Now we need to prep the large ply wood pieces to get them on the frame. Sand the edges and then take the fabric and white glue. Line up the two larger pieces of wood how they should be and then water down some white glue a bit and cover the fabric in it. Put it in between the two pieces of the wood so that they connect. While it’s still wet (make sure it stays on though) put some glue on the supports, back, and that big piece of wood so you can put the big pieces of the plywood on. After you put it on nail it in place with the nail gun. Turn it over and do the same thing to the other side. Now take your wood filler and fill all the holes where you put nails, fill all the little parts that you need to and you can also put some on the buster sword to make the transition between the two pieces of plywood look a bit better (after painting of course). You now should put the final medium pieces on the ends just like the others, you should have a nice buster sword shape that looks (and is!) almost done.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
9
Author:ditto125
