Step 9Final things
[see picture 1]
I went out and happened to find these small half sphere pieces of wood at hobby lobby that had a flat looking round bottom that came out. So I drill these indentations into the hand guard for the 5 half spheres on it. One I put those in with glue it just lit it sit over night. Now, the problem with plywood is that it’s not a natural wood, making it hard to make it nice and smooth so it looks good with paint. The top part (not the blade part) was easy since I used paint that gave it a hammered look; all I needed to do there was fill holes and indents with wood filler after sanding it by hand. Since the blade needed to look a bit different I used a metallic paint to make it look a bit more like it was sharpened. This kind of look is hard to get with plywood so I needed to make it smoother. After sanding it down by hand I took some wood filler, I watered it down, and spread it all across the bottom of the sword. After it dried I sanded it down so it would be level and made sure the rest of the sword was level. Get some masking tape, plastic bags (of just some sheets of plastic), and your paint. Usual painting on wood thing. Make sure anything you don’t want painted in that color is covered. And always keep the handle covered. Once you paint everything (like 2-3 coats should be good) you should notice some weight gain in the sword. After it dries then take some acrylic paint and paint the handle, obviously red and the end gold or yellow. Now I am adding a part to this that I did NOT do, but I am telling you so you don’t make the same mistake. After you paint the whole sword (handle included) put a clear coat on top of it all so that the paint job does not get damaged, I did not do this just to save money and now my buster sword needs a new paint job, just costing more money. At the end you should end up with something like in picture 2.
[see picture 2]
15
comments
Add Comment
Add Comment
