the easy way to make writing with fire.
Step 1: Gather fire materials
1.you will need a lighter, or match.
2.a tube of flammable glue ( i found that the super glue brand fix-all glue works the best BUT DONT USE REGULAR SUPER GLUE IT IS DANGEROUS)
3.a space where you wont burn anything down and is well ventilated.
1-40 of 42Next »
Bob the dog says: Dec 11, 2011. 10:42 PM
I just use gasoline to do that
djlewis725 says: Feb 1, 2010. 4:17 PM
white lithium grease works best! good instructrable
LinuxH4x0r says: Sep 17, 2007. 4:12 PM
I have this spray de-icer that contains methanol which gives off a nice blue glow without all the smoke. Do it at night - during the day it is hard to see. Nice
hcold in reply to LinuxH4x0rJul 13, 2008. 7:20 PM
Spray deodorants do the same, though I don't recommend doing this at 3 in the morning, while everyone is asleep and you're very bored. On the other hand, if you make a spray deodorant flame thrower while inside, it creates an awful lot of carbon monoxide, makes any fire alarms in the vicinity go off (including ones not even in the same room).
Vulcanator in reply to hcoldMar 24, 2009. 6:53 AM
or on the school bus. oops my friend and i had a war on the bus using flaming spray deoderant cans it singed the hairs off of my arms.
bloke2022 in reply to VulcanatorJan 29, 2010. 5:17 PM
Your school bus must be pretty crazy.
LinuxH4x0r in reply to hcoldJul 13, 2008. 7:28 PM
Hehe, yep. Actually its the ionized smoke itself, not CO that makes the detectors go off.
im_tux (author) in reply to LinuxH4x0rSep 18, 2007. 5:03 PM
(removed by author or community request)
LinuxH4x0r in reply to im_tuxSep 19, 2007. 6:26 AM
I meant the de icer is hard to see. your shows up fine. BTW it comes in a red spray bottle (like windex).
Berkin says: Jun 11, 2009. 10:24 PM
I'll mix alcohol with Elmer's glue!!! MUAHAHAHAHAHHAAAAAAA
kaynegabe in reply to BerkinOct 8, 2009. 2:56 PM
Berkin in reply to kaynegabeOct 8, 2009. 5:31 PM
FLAMING SLIME
sharlston says: Aug 7, 2009. 2:09 PM
hand sanitizer or lighter fluid works best for me :)
cclark13 says: Jun 9, 2009. 2:40 PM
rubber cement works the best
mallorynicole68 says: May 15, 2009. 10:15 PM
There is also a product called "One match" by Rutland. It is intended for starting up pellet burning products but I find it fun to write with or squeeze out a blob of it and light on fire. You can find it at fireplace specialty stores or at some hardware stores. Worth finding.
eps6969 says: May 1, 2009. 11:13 PM
use hand sanitizer like the kind you get at dollar stores works great and spreadable and can relight over and over makes cool blue flame and no mess after its great
Evilblaze says: Apr 2, 2009. 2:04 PM
Actually this is not a good idea. From burning glue you get black fumes what are carcinogen. Don't do this if you want to die in cancer...... //and it is not good for the environment:-D
Feral_Messiah says: Aug 21, 2008. 5:18 PM
Metho: cheap, simple blue flame without the toxic fumes... Also, it's hot enough to light a fire-staff from!
MilotisX in reply to Feral_MessiahFeb 15, 2009. 2:58 PM
isn't that rubbing alcohol
Vulcanator in reply to MilotisXMar 24, 2009. 6:51 AM
no. rubbing alcohol is isopropanol (C3H7OH) not methanol (CH3OH) the simplest of alcohols
dontwealllovebuda92 says: Mar 7, 2008. 6:00 PM
Use white-out. A lot more affective smells bad and leaves charred remains so clean up so your parents don't find out. A lot more powerful and so much better. Not knocking on the crazy glue but WHITE OUT IS SOOOOOOO MUCH BETTER. Easier to write with and a lot more defined.
im_tux (author) in reply to dontwealllovebuda92Mar 13, 2008. 7:31 PM
heh my parents found the marks left by this and me and me bro got the talkin to
dontwealllovebuda92 in reply to im_tuxMar 21, 2008. 8:50 AM
sorry, hey not liable
goeon in reply to dontwealllovebuda92Mar 8, 2009. 6:57 PM
lol
Tennismaster58 says: Jul 5, 2008. 2:32 PM
A bit obvious am i right?
yellowsushimustard says: Jun 24, 2008. 4:55 PM
you could also use spray paint, ive done it before and it works pretty well. the flames arn't that high so it makes it easier to read
WICKY W3AZZY says: Jun 24, 2008. 4:38 PM
ok sorry but, thats doesnt say fu. its a flaming mess. come on
QuestionableDoubt says: Jun 1, 2008. 6:29 PM
You're kidding, right? The fact that you can write with a flammable substance seems to strike me as common knowledge.
awkrin says: May 31, 2008. 1:24 PM
this is rather: how to write on a surface using fire. if u'r using anything like u used, it must be over a large area to be able to read, because if I wouldn't have seen what u written while it wasn't burning, I couldn't read it. u should use something like smashed fire starter(solid one) and make an even line, or make a thin line with some aerosol spray
Shaman of Bliss says: May 19, 2008. 7:27 AM
I thought I'd just share, but lets say you want to leave a message, burned into someones drive way say... forever. Buy some rubber cement, spell out your message, then light in on fire. The only way to get rid of the burn marks is too tear up the cement, lol. Trust me its there forever.
drummonkey92 says: Nov 2, 2007. 1:02 PM
you can use tipex to do this aswell but only when its wet
halomaster007 in reply to drummonkey92Jan 5, 2008. 8:01 PM
yeah, much easier
James (pseudo-geek) says: Sep 25, 2007. 7:03 AM
I did that with plastic glue. it smokes like crazy and smell aweful tho. I tried using lighter fluid, and it looks AWESOME.
im_tux (author) in reply to James (pseudo-geek)Oct 2, 2007. 7:36 PM
DUDE ive gotta trythat thats awsome! ty for the great addition to this instructable
James (pseudo-geek) in reply to James (pseudo-geek)Sep 25, 2007. 10:34 AM
halomaster007 in reply to James (pseudo-geek)Jan 5, 2008. 8:01 PM
NICE
James (pseudo-geek) in reply to halomaster007Jan 6, 2008. 1:40 AM
Its lighter fluid. I don't know why it burns like that.
thoraxe in reply to James (pseudo-geek)Apr 13, 2008. 3:09 PM
wth? why is it burning like dat?
James (pseudo-geek) in reply to thoraxeApr 13, 2008. 10:41 PM
I haven't the foggiest idea.
master-of-chaos in reply to James (pseudo-geek)Oct 6, 2007. 4:00 PM
freekin sweet man
1-40 of 42Next »
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
