●FIX HOLES IN LEATHER BOOTS●
91,825
69
21
Published
Introduction: ●FIX HOLES IN LEATHER BOOTS●
This is how I fixed my leather boots.
I hope they are going to last me for way longer now, because I really like them…
I'm wearing them from quite a while now and seam this method worked really well.
Step 1: WHAT YOU NEED
You need:
-waterproof leather glue, a good brand that dry flexible and clear,
-a scrap piece of nice leather of the same color (or not!) of your boots,
-sand paper.
-(a pair of holed boots).
Step 2: CLEAN THE BOOTS
Clean your boots really well around the broken part.
Allow to dry completely.
Step 3: ROUGH THE SURFACE
With the sand paper rough the surface of your boots around the holes, only and everywhere under where you are going to patch them, from one side to the other of your boot.
Step 4: CUT a STRIPE OF LEATHER
Place the leather on top of your boots and cut a stripe that cover the holes, going from one side of the other of your boots.
Step 5: PUT THE GLUE
Put the glue allover the behind of the leather stripe you cut.
Spread it really well and deep everywhere, especially on the edges.
Step 6: PLACE THE STRIP
Place the strip and clean off the left over glue.
Press hard on the strip everywhere, placing one hand inside of the boot. I did this operation for few minutes on each boot, to make sure the leather strip was stick really well on the boot.
Step 7: DONE!
Done, let them dry over a night or until your leather glue need.
The stripe is noticeable, but I don't think it look so bad!
Now you can polish them and make them look nice whit a bees wax lotion: https://www.instructables.com/id/BEES-WAX-LOTION-for-hands-boots-and-wood/
  • Stick It! Contest
    Stick It! Contest
  • Pets Challenge
    Pets Challenge
21 Comments
Something else you could use instead of the leather glue is Neoprene liquid seal cement. That's what we use at the leather/shoe repair shop I work at.
I have another tip if you skive the long edges so that they thin downward at an angle it will help blend the two pieces, that way it's less noticeable.
That is also a really good idea, Thanks!
Thanks for sharing! But do you have any idea, how to repair red steels? :D I don't want to paint them because I'm scared it would be worse
Well yeah... but I'm afraid it would look weird, because they have stired black paint over it. And it would be also hard to find the same color. I'll try to figure out what to do with them :)
If the paint wasn't intentional you could always try a leather dye to match the two colors.
Gonna have to do this for my old motorcycle leathers.....thanks for this
Ah...is this the start?? I'm expecting more from you ;-) very nice idea
I've got boots with the left side of the left toe worn to the steel toe from rubbing on the "Dog Leg" while driving truck, while the right side is fine as it was holding the pedal to the floor of a 318 Detroit Diesel 2 axle Semi. Since I'm retired I like them that way, but I can think of many ways to use Your advice. Thanks again. : - }
I wish I had known this technique during my school days :), Thank you so much for sharing.
Nice job! A good pair of leather boots can last forever if you take care of them properly :) How is the glue holding up?
