FM Bugger Circuit.
Published
Introduction: FM Bugger Circuit.
About: Hello All. A great thing in all our life is SCIENCE. Whether it may be any branch but it studies and gets off a solution for the world. We all being scientist made many instructables , Let us go forward and ...
Here’s a great project fromEEWEb.
Author : Charlene Tessa Descallar and S. Sai Jayanth.
Editor : S. Sai Jayanth / LearntoDiscover.
PROJECT SUMMARY
The project circuit design is a FM Bugger circuit. It works like a the same frequency to be able to transmit and receive information in the same channel. The FM bugger circuit is originally designed to be used like a spy gadget to eavesdrop other people’s conversations. Though it is designed that way, it is pretty much useful as a transmitter or transmitter that transmits and projects information signals into the air wherein a FM radio will act as a receiver which would receive the transmitted signal. The circuit and the FM radio must be tuned-in with as a walkie-talkie to relay messages in a distance. {image3} PROJECT DESCRIPTION
Introduction
The FM bugger circuit is designed to be used as a spy gadget that would monitor a person through his conversations. Though it is illegal to be used in that way, there are actually spy agencies that would use bugger devices in spying someone. It is originally a spying device but it could also be used as a transmitter to transmit messages in a distance and receive the messages through a normal FM radio. Operation
The operation of the FM bugger circuit is the same as of a transmitter. The audio or the information signal is the analog input of the circuit which will be picked-up by the mic. The input will be filtered by C1 which is used to remove the noise and distortions in the signal. The C6 and L1 serves as the tank circuit that will produce the carrier frequency for the input signal in which it will be modulated with a transistor. The modulated signal is then transmitted into the air through an antenna in sending it to a receiver with the same tuned-in frequency.
FM Bugger Circuit Diagram The receiver for the FM bugger circuit can be just a normal FM radio. Both the transmitter and the receiver must be tuned-in with the same frequency to be able to transmit and receive information signals at the same channel. It can be done by adjusting the trimmer capacitor of the circuit to tune-in with the frequency channel of the FM radio or by adjusting the FM radio to tune-in with the frequency of the FM bugger circuit. When both are tuned-in with the same frequency channel, the FM bugger circuit is set to transmit messages and conversations from the line to another line which is the receiver. Testing and Design Procedure
The FM bugger circuit is tested using Partsim and the NGSpice to test the output of the circuit.
FM Bugger Circuit Simulation R1 Net1009 Mic 22K R2 Net1009 Net1016 47K R3 Net1003 0 33K C1 Net1016 Mic 1NF C2 Net1016 0 1NF C3 Net1002 Net1003 4.7pF C4 Net1002 Antenna 1NF C5 Net1009 0 22NF C6 Net1009 Net1002 50pF L1 Net1009 Net1002 9NH Q1 Net1002 Net1016 Net1003 2N2222 V1 Net1009 0 3V V2 Mic 0 SINE ( 1 1 20Khz 0.0S ) R4 0 Antenna 1K .options rshunt = 1.0e12 KEEPOPINFO .MODEL 2N2222 NPN IS =3.0611E-14 NF =1.00124 BF =220 IKF=0.52 VAF=104 + ISE=7.5E-15 NE =1.41 NR =1.005 BR =4 IKR=0.24 VAR=28 ISC=1.06525E-11 NC =1.3728 RB =0.13 + RE =0.22 RC =0.12 CJC=9.12E-12 MJC=0.3508 VJC=0.4089 CJE=27.01E-12 TF =0.325E-9 TR =100E-9 .control OP · OP Let expressions, if any: write Net1002 Net1003 Net1009 Net1016 Mic Antenna I(V1) I(V2) set appendwrite true rusage everything .endc .end
The simulation of the FM bugger circuit in PartSim shows that the circuit is working. The microphone was assumed to have an input of a 20 kHz sinusoidal wave. Then, the output signal at the load, R4 assumed to be the antenna for the circuit, turns out to produce a FM signal. Therefore, the FM bugger circuit itself has a great possibility to succeed and operate in real life when it will be put into test.
For more Information and for more best science projects, Visit
https://learntodiscover-science.blogspot.in
    • Microcontroller Contest
    • Casting Contest
      Casting Contest
    • Make it Move Contest
