Introduction: FPV Internet Controlled Toy Excavator
Picture of FPV Internet Controlled Toy Excavator
The goal was to transform an old and broken RC toy excavator into a First Person View controlled over the internet one.
Trying to reuse as much as possible, and involving the kids in the process.
Controlled from a web browser from anywhere in the world with internet connection.
The main components I used:
  • rc toy excavator
  • raspberry Pi 2 Model B
  • USB WIFI adapter
  • webcam
  • sd card (16Gb was used here)
  • Two external batteries (one of them an external usb battery)
  • Dozens of jump wires
  • Some tools ( Soldering iron, saw, scissors, screw drivers...)
The software involved :
  • Raspbian as the OS of the Raspberry Pi
  • Webiopi as the Raspberry Pi IOT Framework to control the Pi's GPIO's
  • Some scripts and configuration files
  • mjpg_streamer
The first two steps are about the instalation and configuration of the RPi software If you want to see something more specific about this instructable, skip to step 4.
To fully understand this instructable You should have some basic knowledge about the usage of the shell, linux, some raspberry basics (what GPIO are...) and some basic notions about electronics too.
If you don't, you should spend some time learning about that. It's not necessary to have a degree, just some basics :)
Step 1: Setting Up the Raspberry Pi (1)
Picture of Setting Up the Raspberry Pi (1)
The software installation into the sd card has been done using a computer running Debian.
I think the process is almost the same for most of the other Gnu/Linux based distros.
I set up a headless instalation in the Raspberry Pi2 but maybe it could be easier connecting a monitor and a keyboard.
These are the steps:
1-Download raspbian image (Jessie) from:
https://www.raspberrypi.org/downloads/raspbian/
There are many places that explain very well how to install and configure your Raspberry Pi, for example:
http://elinux.org/RPi_Easy_SD_Card_Setup#Using_the...
2- Connect the sd card to the PC ( running Debian), unzip the os for the RPi.
Check the path where the sd is mounted.
$ unzip 2016-02-26-raspbian-jessie.zip
$ df -h
/dev/sdc1         15G    32K   15G   1% /media/USER/79C2-6827
3- Log in as root. Unmount the sd card. Check again to see if it is really unmounted.
$su
passw
#umount /dev/sdc1
#df -h
4-Write the unzipped .img into ALL the partitition (in this case /dev/sdc) NOT only in sdc1.
#dd bs=4M if=2016-02-26-raspbian-jessie.img of=/dev/sdc
After a while... quite a long time. (The output is in Spanish here, just information that the process was completed)
960+1 registros leídos
960+1 registros escritos
4029677568 bytes (4,0 GB) copiados, 3883,82 s, 1,0 MB/s
Step 2: Setting Up the Raspberry Pi (2)
Picture of Setting Up the Raspberry Pi (2)
Unplug and plug again your sd card. It will be recognized. You should see that you have two partitions, something like that:
/dev/sdc1 mounted on /boot
/dev/sdc2 mounted on /media/$USER/443559ba-b80f-4fb6-99d9-ddbcd6138fbd
You can check it out using
#df -h
Now we can enter in our main partiton
#cd /media/$USER/443559ba-b80f-4fb6-99d9-ddbcd61
And we must modify some configuration files. I used nano as editor. And I decided to perform a headless setup. The only RPI connections will be the power source and the ethernet cable.That's why it is needed to configure some files beforehand.
#nano /etc/network/interfaces
We should change this paragraph
allow-hotplug wlan0
iface wlan0 inet manual
    wpa-conf /etc/wpa_supplicant/wpa_supplicant.conf
For this one
auto wlan0
allow-hotplug wlan0 auto wlan0
allow-hotplug wlan0
iface wlan0 inet dhcp
iface default inet dhcp
Remember saving using CRTL+O. Before exiting (CRTL+X)
Now we open resolv.conf
# nano /etc/resolv.conf
By default we'll have google namserver(8.8.8.8), we can add our own..
nameserver 8.8.8.8
# Generated by NetworkManager
nameserver 80.58.61.250
nameserver 80.58.61.254
Now we configure wpa_supplicant.conf file
# nano /etc/wpa_supplicant/wpa_supplicant.conf
We must add:
ctrl_interface=DIR=/var/run/wpa_supplicant GROUP=netdev
update_config=1
network={
        ssid="WLAN_53F4"
        psk="G5ZQ8XDNPI2ZXAXG64DW"
Do not forget to save it.
We unmount the sd card ( the two partitons) and we plug it into the RPi.
We also attach the usb wifi adapter. We power up the Rpi and we can check what is our local address, looking in our router.
Sometimes It is difficult to make the usb wifi works at the first try, so in this case it is better to connect the ethernet cable to the Rpi, log into the Rpi from your pc using ssh (my local address 192.168.1.39)
If you don't know how to set up you ssh client/server, check this place
https://www.digitalocean.com/community/tutorials/h...
We'll log into the RPI in graphical mode.
More info about graphical loggin here:
https://www.cyberciti.biz/tips/running-x-window-graphical-application-over-ssh-session.html
ssh -X pi@192.168.1.39
The default password is "raspberry", you can change it after the initial setup.
and once logged into the Rpi and after some initial setup configuration (if any) try this command:
$ sudo ifdown wlan0 && sudo ifup wlan0
If you still have problems trying to connect to your Rpi using the WIFI, follow the instructions of this website, with very specific information about this step.
WiFi Issues ? Start here !
https://www.raspberrypi.org/forums/viewtopic.php?f...
Step 3: Setting Up the Webcam
Picture of Setting Up the Webcam
A FPV vehicle obviously needs some kind of video capture device, and streaming it.
I tried several webcams. The best are the ones which have hardware mjpeg encoding, less cpu usage and less memory requirements.
Another mjpeg's advantage is that it requires no plugins or browser extensions, it can be played natively in most web browsers.
And we'll use any web browser from pc. laptops, tablets, smartphones, TV, using chrome, firefox, safari, opera, iceweasel... as the only software requirement for the end user.
Now you should be able to connect to you Rpi with the wifi usb dongle,using ssh from your pc.
All the instructions are performed from a remote pc conected to the RPi
Connect the camera to the Rpi, and check if it is recognized.
$ dmesg
See if your camera is in the output.
To check our camera capabilities we can install uvcdyncrt
pi@raspberrypi ~ $ sudo apt-get install uvcdynctrl<br>pi@raspberrypi ~ $ uvcdynctrl -f
We're looking for
Pixel format: MJPG (MJPEG; MIME type: image/jpeg)
Frame size: 640x480<br>Frame rates: 30, 25, 20, 15, 10, 5
Frame size: 160x120
Frame size: 1280x960<br>Frame rates: 30, 25, 20, 15, 10, 5
We will also install a bunch of packages related with v4l
$ sudo install v4l2ucp v4l2loopback-utils v4l2loopback-source gem-plugin-v4l2 libjpeg8-dev libv4l-dev
And we finally must install mjpeg streamer. But it is not yet on the raspbian repositories
$sudo apt-get install subversion libjpeg8-dev imagemagick libav-tools cmake git clone <a href="https://github.com/jacksonliam/mjpg-streamer.git" rel="nofollow">   https://github.com/jacksonliam/mjpg-streamer.git<...>
$cd mjpg-streamer/mjpg-streamer-experimental
$export LD_LIBRARY_PATH=.
$make
To run mjpeg streamer
$./mjpg_streamer -i "./input_uvc.so" -o "./output_http.so"
To see the photos or video, we simply must open a web broser, and:
To take pictures
http://192.168.1.39:8080/?action=snapshot
Or video
http://[ your IP address]:8080/?action=stream
You can watch it on your tv web browser too.
Later In the seventh step of this instructable we will return to configure some more things related with the video streaming and we'll see how to integrate it into our system.
Step 4: Setting Up the Electronics
Picture of Setting Up the Electronics
The original electronic setup was composed of a PCB and 6 simple dc motors. No servos or limit switches in the boom or arm, so do not force them too much.
To power the RPi we'll use an external usb battery pack of 10Ah.
To power the motors we'll use a 12v lead battery 7Ah, with a dc-dc step down module to 9,6v.
Each wheel has its own dc motor. The steering system is quite simple. Like a caterpillar vehicle.
  • To go forward, all wheels spin forward.
  • To go backwards, all wheels spin backwards.
  • To go right . the two left wheels spin forward, and the two right wheels spin backwards.
  • To go left . the two right wheels spin forward, and the two left wheels spin backwards.
I tried to savage as much as possible so I sawed the original circuit, removing the rc parts.
I obtained three pieces of the pcb, one composed of 4 relays that control the 4 motors.
The other two parts are typical transistors H bridges, that control the boom and the arm-shovel motors.
The PCB was literally sawed so many conductive tracks were severed and had to be rebuilt later soldering cables.
This requires some knowledge in the electronics involved, some skill and be willing to spend some time.
Any mistake, a wrong connection, a shortcircuit... could destroy your RPi once connected.
In case you choose to do this, you must test it thoroughly before conecting the hacked pieces of circuitry to the RPi.
You'll need to do extensive testing with a multimeter, and simulating the RPi signals with a 3v battery pack.
Maybe the most simple, safest and straightforward way to control the motors is using 2 sets of 4 relay modules.
They're cheap and safe to use as most of the them are opto-isolated.
*I didn't review (yet) the circuit sketches in the pic, so review them, if you plan to build anything with them.
Step 5: Webiopi and Control Software (1)
Picture of Webiopi and Control Software (1)
We need to set up our Pi to use Python to communicate with the GPIO pins.
Install python packages
sudo apt-get update<br>sudo apt-get install python-dev
sudo apt-get install python-rpi.gpio
Installing the WebIOPi framework
http://webiopi.trouch.com/
Webiopi is the ready-made framework that allow us to remotely handle our GPIO's, Serial, I2C, SPI, 1-Wire...
Works almost out of the box, safe, without any special knowledge, for the client there's no need to use any additional software, just a web browser.
It is not available yet in the raspbian repositories. But but installing it is quite easy.
$ cd ~
Getting the file:
$ wget <a href="http://sourceforge.net/projects/webiopi/files/WebIOPi-0.7.0.tar.gz" rel="nofollow">  http://sourceforge.net/projects/webiopi/files/Web...>
When finished, extract it:
$ tar -xvzf WebIOPi-0.7.0.tar.gz
Enter the directory
$ cd WebIOPi-0.7.0/
Run the setup script as root:
$ sudo ./setup.sh
It could take a long time. Answer YES to all dependencies.
Once finished test it
$ sudo webiopi -d -c /etc/webiopi/config
If you find this error
AttributeError: 'module' object has no attribute 'GPIO'
You can solve i following the instructions here:
http://slicepi.com/raspberry-pi-2-webiopi-error-at...
In the webiopi-0.7.X directory is the /python directory:
1.CD into /python/native/ Edit the file: cpuinfo.c change "BCM2708" to "BCM2709"
2.While still in python/native/ Edit the file gpio.c change #define BCM2708_PERI_BASE 0x20000000 to #define BCM2708_PERI_BASE 0x3f000000
3.Head back out to your root webiopi-0.7.X directory and run setup.sh again.
You can easily start it
$ sudo /etc/init.d/webiopi start
Now open a browser, check what it is your local IP.
http://192.168.1.39:8000
Default user is webiopi
Default password is raspberry
To stop it
$ sudo /etc/init.d/webiopi stop
If we wish to start webiopi when starting the Rpi
$ sudo update-rc.d webiopi defaults
Recommended sites:
http://forums.connectedly.com/raspberry-pi-f179/ho...
I specially recommend this site. In Spanish, but very clear and with a lot of comprehensible information.
http://www.hackplayers.com/2013/12/construye-tu-pr...
Step 6: Webiopi and Control Software (2)
Picture of Webiopi and Control Software (2)
Finally to use our toy we need to create or configure some files.
Create a folder
$mkdir /home/pi/cambot
Get into that folder
$cd /home/pi/cambot
FILE 1. stream.sh
Copy this script. We will name it stream.sh. It is useful to run our video streaming in the background. we can change the device, resolution and frame rate.
#!/bin/sh
PLUGINPATH=/usr/src/mjpg-streamer-code/mjpg-streamer
STREAMER=$PLUGINPATH/mjpg_streamer
DEVICE=/dev/video0
RESOLUTION=640x480
FRAMERATE=25
HTTP_PORT=8001# check for existing webcam device
if [ ! -e "/dev/video0" ]; then
  echo "stream.sh: Error - NO /dev/video0 device" 2>&1 | logger
  exit 2
fi
#PLUGINPATH=/usr/local/lib
$STREAMER -i "$PLUGINPATH/input_uvc.so -y -n -d $DEVICE -r $RESOLUTION -f $FRAMERATE" -o "$PLUGINPATH/output_http.so -n -p $HTTP_PORT" -b
FILE 2. cambot.py
Create a python file called cambot.py
#imports
import webiopi
# Libreria GPIO
GPIO = webiopi.GPIO
# Definición constantes                              #
# GPIOs motores DERECHA
L1=22  #  Derecha-adelante
L2=23  # Derecha-atras
# GPIOs motor IZQUIERDA
R1=13 # izquierda-adelante
R2=19 #izquierda-atras
# GPIOs motor pluma
B1=25 # arriba
B2=26 # abajo
# GPIOs motor brazo
P1=24 # arriba
P2=16 # abajo
# Funciones motores derecho                          #
def right_stop():
    GPIO.output(L1, GPIO.LOW)
    GPIO.output(L2, GPIO.LOW)
def right_forward():
    GPIO.output(L1, GPIO.HIGH)
def right_backward():
    GPIO.output(L2, GPIO.HIGH)
# Funciones motor izquierdo                          #
def left_stop():
    GPIO.output(R1, GPIO.LOW)
    GPIO.output(R2, GPIO.LOW)
def left_forward():
    GPIO.output(R1, GPIO.HIGH)
def left_backward():
    GPIO.output(R2, GPIO.HIGH)
# Funciones motor pluma                              #
def pluma_stop():
    GPIO.output(B1, GPIO.LOW)
    GPIO.output(B2, GPIO.LOW)
def pluma_sube():
    GPIO.output(B1, GPIO.HIGH)
def pluma_baja():
    GPIO.output(B2, GPIO.HIGH)¡
# Funciones motor brazo                              #
def brazo_stop():
    GPIO.output(P1, GPIO.LOW)
    GPIO.output(P2, GPIO.LOW)
def brazo_sube():
    GPIO.output(P2, GPIO.HIGH)
def brazo_baja():
    GPIO.output(P1, GPIO.HIGH)
# Definición macros                               #
@webiopi.macro
def go_forward():
    right_forward()
    left_forward()
@webiopi.macro
def go_backward():
    left_backward()
    right_backward()
@webiopi.macro
def turn_left():
    right_forward()
    left_backward()
@webiopi.macro
def turn_right():
    right_backward()
    left_forward()
@webiopi.macro
def stop():
    left_stop()
    right_stop()
@webiopi.macro
def plumaarriba():
     pluma_sube()
@webiopi.macro
def plumaabajo():
     pluma_baja()
@webiopi.macro
def brazoarriba():
     brazo_sube()
@webiopi.macro
def brazoabajo():
     brazo_baja()
@webiopi.macro
def brazoplumastop():
    pluma_stop()
    brazo_stop()
# Inicialización                                     #
def setup():
# Instalacion GPIOs
    GPIO.setFunction(L1, GPIO.OUT)
    GPIO.setFunction(L2, GPIO.OUT)
    GPIO.setFunction(R1, GPIO.OUT)
    GPIO.setFunction(R2, GPIO.OUT)
    GPIO.setFunction(B1, GPIO.OUT)
    GPIO.setFunction(B2, GPIO.OUT)
    GPIO.setFunction(P1, GPIO.OUT)
    GPIO.setFunction(P2, GPIO.OUT)
def destroy():
# Resetea las funciones GPIO
    GPIO.setFunction(L1, GPIO.IN)
    GPIO.setFunction(L2, GPIO.IN)
    GPIO.setFunction(R1, GPIO.IN)
    GPIO.setFunction(R2, GPIO.IN)
    GPIO.setFunction(B1, GPIO.IN)
    GPIO.setFunction(B2, GPIO.IN)
    GPIO.setFunction(P1, GPIO.IN)
    GPIO.setFunction(P2, GPIO.IN)
In this script we'll define which gpio pins will be used. And the macros that will be used by another file...
The configuration is simple. We initialize the gpio pins using OUT, and we change the state for the different movements using HIGH or LOW. I used some words in Spanish. brazo= arm, pluma=boom
Step 7: Webiopi and Control Software (3)
Picture of Webiopi and Control Software (3)
We want this script (cambot.py) to be called when initializing the webiopi server.
We must specify it in the configuration file located at /etc/webiopi/config in the SCRIPTS section.
FILE3. /etc/webiopi/config
[SCRIPTS]
# Load custom scripts syntax : # name = sourcefile # each sourcefile may have setup, loop and destroy functions and macros #myscript = /home/pi/webiopi/examples/scripts/macros/script.py cambot = /home/pi/cambot/cambot.py
In the same file, we'll change the passwd-file, doc-root and index.file locations.
[HTTP]
# HTTP Server configuration enabled = true port = 8000 # File containing sha256(base64("user:password")) # Use webiopi-passwd command to generate it passwd-file = /etc/webiopi/passwd # Use doc-root to change default HTML and resource files location #doc-root = /home/pi/webiopi/examples/scripts/macros doc-root = /home/pi/cambot # Use welcome-file to change the default "Welcome" file welcome-file = index.html
FILE4. Index.html
After that we need to generate the psswd file, so run the webiopi-passwd command.
$ sudo webiopi-passwd
WebIOPi passwd file generator Enter Login: webiopi Enter Password: Confirm password: Hash: f576340c89121g9gf5673c4b1a7d6g04bv67c7894a456ce370fe1bf2v5c25798 Saved to /etc/webiopi/passwd
Finally we create the file index.html
In the location specified before. The controls are created using jQuery and the javascript functions to call the macros in the python script The video streaming It is also embeded using the [IMG] tag. Copy the file (index.html), remove the parentheses.
Step 8: Final Steps
Picture of Final Steps
There's another optional script, as a failsafe in case the wifi conection becomes too weak.
If you're planning to use your vehicle near the wifi source, there's no problem, but if you're using it in the outside and the vehicle looses the signal, it will continue doing was it was doing at that moment, with no possibility to stop it.
This pyhton script tests the signal and if the Quality level becomes lower than 50 ( value taken from /proc/net/wireless) stops the webiopi server. You must see what's the apropiate value in your case. So that you can restart webiopi manuallly and put your vehicle into safety or leave it where it is. I called it deten.py It uses less that 1% CPU.
Beware, I'm not a programmer but I had to create this script myself as I couldn't find anything to do the job, so ...
Anyway as far as I tested it runs ok, and does the job. We'll run it in the background as we'll see later.
FILE5. deten.py
#!/usr/bin/python<br># Script seguridad en caso de perdida señal wifi. As a failsafe in case of signal loss #
#Ajustar el valor según necesidad(defecto a 50).Adjust the value to your needs(default 50)#
#No me responsabilizo de su uso.Disclaimer.No guarantee at all #
# C. BAHILLO                                                   #
from subprocess import PIPE
import subprocess
import time
pro = subprocess.Popen("cat /proc/net/wireless", shell=True, stdout=subprocess.PIPE, stderr=subprocess.PIPE)
data = pro.communicate()[0].split()
valor = int(float(data[0:][30]))
while True:
 time.sleep(1)
 if valor < 50:
     subprocess.Popen("sudo /etc/init.d/webiopi stop", shell=True
There are many ways to initialize all of this ( the video streaming, the webiopi server, failsafe script..).
It can be automated so that when booting our Rpi, the webiopi server starts too.
If you change your mind...
$ sudo update-rc.d webiopi remove
But I like to use it launching a tiny script I called inicia.sh So I log into the RPi using shh and launch it.
FILE6. inicia.sh
#!/bin/bash<br>/bin/bash streamer.sh
python3 deten.py &
We place ALL these files into the Cambot directory
We go there
$ cd /home/pi/Cambot
LET'S PLAY
 $ sh inicia.sh
Step 9: LET'S PLAY
Step 10: Next Challenge: Controlling the Vehicle in Murguía,Spain From Kentucky, USA
Picture of Next Challenge: Controlling the Vehicle in Murguía,Spain From Kentucky, USA
In a few days a friend will try to control the toy excavator from 6500km away.
Now charging, prepairing for the event. It is quite easy to recharge, with a car battery charger(old edited later).
The results were better than expected!!!
The user was in Kenctucky, using a web browser in a PC.
The vehicle was in Alava, Spain, 6500km away, connected through a wifi router.
The average lag for the ouput response was about 3 seconds.
Sometimes the vehicle got freezed and didn't respond at the first or second input from the user.
Sometimes it continued running for several seconds, despite the user was trying to stop it ( here the script deten.py is a must if the vehicle is alone).
But most of the time it worked fine!!!!!!!!!!!!
The video is horrible, only a toy excavator moving, just for fun, just a "souvenir" for my friend Ritchie :D
The first man in the US to control a toy excavator in Spain LOL.
Ritchie, thanks for being my testing operator!
AlbertJ (author)2016-11-13
Very cool project. Thanks for sharing. I tried to look at the index . html code, but received "Request forbidden by administrative rules" error both in Chrome and Firefox. Any chance you can send the file to al5322 "at" outlook "dot" com?
bahi (author)AlbertJ2016-11-21
Copy the content of the post above and save it as index.html
I copied it here.
bahi (author)2016-11-21
<!DOCTYPE html PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN" "http://www.w3.org/TR/html4/loose.dtd">
<html>
<head>
<meta http-equiv="Content-Type" content="text/html; charset=UTF-8">
<meta name="viewport" content = "height = device-height, width = 420, user-scalable = no" />
<title>CamBot</title>
<script type="text/javascript" src="/webiopi.js"></script>
<script type="text/javascript">
function init() {
var button;
button = webiopi().createButton("bt_up", "/\\", go_forward, stop);
$("#up").append(button);
button = webiopi().createButton("bt_left", "<", turn_left, stop);
$("#middle").append(button);
button = webiopi().createButton("bt_stop", "X", stop);
button = webiopi().createButton("bt_right", ">", turn_right, stop);
button = webiopi().createButton("bt_down", "\\/", go_backward, stop);
$("#down").append(button);
button = webiopi().createButton("pl_ar", "PA", plumaarriba,brazopalastop);
$("#left").append(button);
button = webiopi().createButton("pl_ab", "PB", plumaabajo,brazopalastop);
button = webiopi().createButton("br_ar", "BA", brazoarriba,brazopalastop);
$("#right").append(button);
button = webiopi().createButton("br_ab", "BB", brazoabajo,brazopalastop);
button = webiopi().createButton("bp_stop", "S", brazoplumastop);
$("#top-down").append(button);
function go_forward() {
webiopi().callMacro("go_forward");
function go_backward() {
webiopi().callMacro("go_backward");
function turn_right() {
webiopi().callMacro("turn_right");
function turn_left() {
webiopi().callMacro("turn_left");
function stop() {
webiopi().callMacro("stop");
function plumaarriba() {
webiopi().callMacro("brazoarriba");
function plumaabajo() {
webiopi().callMacro("brazoabajo");
function brazoarriba() {
webiopi().callMacro("palaarriba");
function brazoabajo() {
webiopi().callMacro("palaabajo");
function brazoplumastop() {
webiopi().callMacro("brazopalastop");
webiopi().ready(init);
</script>
<style type="text/css">
button {
margin: 5px 5px 5px 5px;
width: 50px;
height: 50px;
font-size: 24pt;
font-weight: bold;
color: black;
</style>
</head>
<body>
<div id="content" align="center">
<img width="640" height="480" src="http://YOUR.IP.HERE:8001/?action=stream"><br/>
<div id="up"></div>
<div id="middle"></div>
<div id="down"></div>
<div id="left"></div>
<div id="right"></div>
<div id="top-down"></div>
</div>
</body>
</html>
creativemanblog (author)2016-04-25
hey can't you use arduino
hey bahi can you give your email id
bahi (author)creativemanblog2016-04-25
Probably, using arduino yun, not sure about using arduino uno even with a wifi shield. At least not with the same features.
ritchiesmith (author)2016-04-29
Thanks for inviting me to participate in this project. It was a lot of fun and very interesting.
bahi (author)ritchiesmith2016-04-29
Thanks to you my friend.
bahi (author)2016-04-28
mjrovai (author)2016-04-25
Very nice project! I will try it! thanks.
bahi (author)mjrovai2016-04-26
Thanks.You're welcome!!
I had never tried something like this before.
It was easier than I expected. Carry on!
hey man this is awesome......
i like it . i only vote for you
Oh, thank you so much!
I'm very happy you liked it!
About This Instructable
3,607views
88favorites
License:
More by bahi:FPV Internet Controlled Toy ExcavatorQuick fix excessive shifter gear playEasy motorcycle windshield
Add instructable to:
