loading
Step 11: The Code
Does not matter what kind of PC do you use just have an Arduino IDE on it. I am copying the code here, but if you want you can download this .rar file and after extraxting you'll be able to upload the codes on the microcontrollers. Please be attentive and upluad the codes that you need not the other.
Code for the Joytick Controlled Robot:
// The code was made by Tamás Imets for an Arduino UNO project
#include <softwareserial.h>
#include <afmotor.h>
int command = 0;  //incoming serial data
int led = 3;
SoftwareSerial bluetooth(A0, A1);
AF_DCMotor M1(1, MOTOR12_64KHZ); //initialize motor1 that is connected to the M1 port, this motor moves forward and backward
AF_DCMotor M2(2, MOTOR12_64KHZ); //motor2 is connected to M2 and this turns BB-8 left and right
int cmd;</p><p>Servo head;
void setup() {
  bluetooth.begin(9600);
  Serial.begin(9600); // set up Serial library at 9600 bps - this is the speed the serial interface will work all
  head.attach(9); //attach servo to pin D9 or to servo2 on motor shield
  M1.setSpeed(255); //set default speed
  M2.setSpeed(255); //set default speed
  pinMode(led, OUTPUT); //connect here the blue LED
}</p><p>void loop() {
  battery = analogRead(A5);
  if (battery <= 570) {
    M1.run(RELEASE); // stopped
    M2.run(RELEASE); // stopped
  if (bluetooth.available()) {
    cmd = bluetooth.read();
    Serial.write(cmd);
    switch (cmd)
      case 'C':
        break;</p><p>      case 'A':
        M1.setSpeed(255);
        M2.setSpeed(255);
        M1.run(FORWARD);
        M2.run(FORWARD);
        break;</p><p>      case 'B':
        M1.setSpeed(100);
        M2.setSpeed(100);
        M1.run(FORWARD);
        M2.run(FORWARD);
        break;</p><p>      case 'D':
        M1.setSpeed(100);
        M2.setSpeed(100);
        M1.run(BACKWARD);
        M2.run(BACKWARD);
        break;</p><p>      case 'E':
        M1.setSpeed(255);
        M2.setSpeed(255);
        M1.run(BACKWARD);
        M2.run(BACKWARD);
        break;</p><p>      case 'F':
        M1.setSpeed(255);
        M2.setSpeed(255);
        M1.run(FORWARD);
        M2.run(BACKWARD);
        break;
      case 'G':
        M1.setSpeed(100);
        M2.setSpeed(100);
        M1.run(FORWARD);
        M2.run(BACKWARD);
        break;
      case 'H':
        M1.setSpeed(100);
        M2.setSpeed(100);
        M1.run(BACKWARD);
        M2.run(FORWARD);
        break;
      case 'I':
        M1.setSpeed(255);
        M2.setSpeed(255);
        M1.run(BACKWARD);
        M2.run(FORWARD);
        break;
      case '0':
        digitalWrite(led, LOW);
        break;
      case '1':
        analogWrite(led, 50);
        break;
      case '2':
        analogWrite(led, 100);
        break;
      case '3':
        analogWrite(led, 150);
        break;
      case '4':
        analogWrite(led, 200);
        break;
      case '5':
        analogWrite(led, 255);
        break;
}</p>
Code for the Brainwave Controlled Robot:
<p>#include "Mindwave.h"<mindwave.h><br>#include "Ultrasonic.h"</mindwave.h></p><p>Mindwave mindwave;
Ultrasonic ultrasonic(A4, A5);
int medlimit = 70;    //set limits
int attlimit = 65;    //set limits
const int motorA1 = 6;    //motor A positive (+) pin to pin 6 (PWM) (from L298 module!)
const int motorA2 = 9;    //motor A negative (-) pin to pin 9 (PWM)
const int motorB1 = 10;   //motor B positive (+) pin to pin 10 (PWM)
const int motorB2 = 11;   //motor B negative (-) pin to pin 11 (PWM)
int battery;</p><p>int distance;         //vconst int motorA1 = 6;
int prevsignal = 0;</p><p>void setup() {
  Serial.begin(MINDWAVE_BAUDRATE);
  battery = analogRead(A3);
  pinMode(motorA1, OUTPUT);
  pinMode(motorA2, OUTPUT);
  pinMode(motorB1, OUTPUT);
  pinMode(motorB2, OUTPUT);
  pinMode(13, OUTPUT);
void onMindwaveData() {
  if (mindwave.quality() < 90) {
    digitalWrite(13, HIGH);
  } else {
    digitalWrite(13, LOW);
  if ((mindwave.quality() < 95) && (prevsignal == 0)) {   //if you blink
    digitalWrite(motorA1, LOW);
    digitalWrite(motorA2, HIGH);
    digitalWrite(motorB1, LOW);
    digitalWrite(motorB2, HIGH);
    delay (1500);
    prevsignal = 1;
  }</p><p>  if ((mindwave.quality() < 95) && (prevsignal == 1)) {
    digitalWrite(motorA2, LOW);
    digitalWrite(motorB2, LOW);
    prevsignal = 0;
  }</p><p>  if (mindwave.quality() == 100) {
  }</p><p>  if (mindwave.meditation() > medlimit) {
    digitalWrite(motorA1, HIGH);
    delay(600);
    prevsignal = 0;
  }</p><p>  if (mindwave.attention() > attlimit) {
    digitalWrite(motorB1, HIGH);
    delay(600);
    prevsignal = 0;
  }</p><p>  if (distance <= 10) {   //check if there is an obstacle
    delay (600);
    prevsignal = 0;
  }</p><p>}
void loop() {
  distance = ultrasonic.Ranging(CM);
  if (battery < 700) {
    delay (1000);
  } else {
    mindwave.update(Serial, onMindwaveData);
}</p>
Code for the Joystick R/C Controller:
<p>//Made by Imets Tamás</p><p>#include <softwareserial.h>
SoftwareSerial BTserial(2, 3); // RX | TX
char *controller;
int x;
int y;
int led;
void setup() {
  Serial.begin(9600);
  BTserial.begin(9600);
  controller = "0";
}</softwareserial.h></p><p>void loop() {
  x = analogRead(A0);
  y = analogRead(A1);
  led = analogRead(A2);</p><p>  if (x > 0 && x < 250) {
    BTserial.write("A");
  else if (x > 250 && x < 400) {
    BTserial.write("B");
  else if (x > 500 && x < 520 && y > 500 && y < 520) {
    BTserial.write("C");
  else if (x > 600 && x < 750) {
    BTserial.write("D");
  else if (x > 750 && x < 1050) {
    BTserial.write("E");
  }</p><p>  if (y > 0 && y < 250) {
    BTserial.write("F");
  else if (y > 250 && y < 400) {
    BTserial.write("G");
  else if (y > 600 && y < 750) {
    BTserial.write("H");
  else if (y > 750 && y < 1050) {
    BTserial.write("I");
  //LED
  if (led > 50 && led < 200) {
    BTserial.write("0");
    BTserial.write("1");
  if (led > 200 && led < 400) {
    BTserial.write("2");
  if (led > 400 && led < 600) {
    BTserial.write("3");
  if (led > 600 && led < 800) {
    BTserial.write("4");
  if (led > 800 && led < 1050) {
    BTserial.write("5");
}</p>
Plz need help <br>
<p>Hello, yes I am here.</p>
For how many distance the camera work? It is work on wifi? <br>
For how much the camera work? And it work on wifi? I need same wifi source to connect it to my phone?
Can i do it without programing skills? I can just copy the code and past in the prog.app?
Yes you can ☺
Hello i need your help with sonething please can i you with email or any app like facebook ,....? This is my email Roudyhazzouri2001@gmail.com
Thx :)
<p>Hi, AMAZING PROJECT, really loved it, want to try out something similar on my quadruped project,</p><p><a href="http://www.instructables.com/id/QUATTRO-the-Arduino-Quadruped-Robot/">http://www.instructables.com/id/QUATTRO-the-Arduin...</a></p><p>but i have used up all my pins for the servos, any suggestions?</p><p>thnx in advance</p>
Bonjour, <br>Bravo pour votre projet. Une question : comment avez vous branch&eacute; la cam ?<br>D'avance merci
<p>hey, thanks for all the links and step by step instructions. my parts are all ordered and are begining to come in the mail. I got the double gear box first..what ratio did you build the double gear boxes? they can be built in 4 configurations...12.7/1 or 38.2/1 or 114.7/1 or 344.2/1. I am happy to play around to see what works, but what did you use??</p>
<p>I found this just now and thought it might help.</p><p>https://www.pololu.com/product/114/specs</p><p>If you look in the different tabs (specs, faqs) there is enough info to know what rpm each ratio will get.</p>
<p>Same here. My gearbox arrived today and I was wondering the same thing. The ratio used in the video looks good to me, so I was wondering which you used.</p>
<p>wow nice</p>
<p>amazing! voted all 3!</p>
good work
<p>very nice!!!!</p>
<p>Magnifique! Excellent Build!</p>
<p>wow. This is very good. </p>
<p>a tank controlled with brain??cant imagine what a full size will look like lol!</p>
<p>Du bist mir wirklich am besten, ich bin sehr stolz auf Dich! Viel Spa&szlig;, Erfolg und Ausdauer! Ich bin immer bei Dir Schatz! :)</p>
<p>Dankesch&ouml;n Kicsipuca! :) </p>
<p>That is good project </p>
This is the coolest thing I've seen ever
<p>Thank you very much! You can give me a kindly Vote. ;) </p>
<p>would you be willing to sell this to me on ebay?</p>
<p>Sorry :) I can't...</p>
<p>verry nice</p>
Oh this is a verry nice project.I vote for you:))
About This Instructable
25,119views
446favorites
License:
Bio: Hi, I'm Tamas (Thomas), a 17 years old Hungarian guy. My hobby started more than 10 years ago. I learn electronics, physics, programming, IoT ... More »
More by Imetomi:FPV Virtual Reality Arduino Controlled Tracked Robot Solar Powered R/C Drone DIY Smart Follow Me Drone with Camera (Arduino Based)
Add instructable to:
