FRAGRANCE SPRAYER
3,717
9
7
Posted
Introduction: FRAGRANCE SPRAYER
INTRO
This is a very effective and powerful room air sprayer. It uses a portable vacuum cleaner or a
car vacuum cleaner with a built in blower. You can use any type of perfume, deodrant, moth
balls, ODONIL (wax perfume packet for toilets- sold in INDIA) shaving lotion, rose water etc.
Liquid perfume works best.
Once when I was out of room freshner this idea came to mind. Hope you enjoy it.
Step 1: ITEMS REQUIARED
These are the items needed for this project.
1.A vacuum cleaner with blower. (Hand held type)
2.A can of perfume or any type of good smelling deodorant. As mentioned in the INTRO any
type of liquid can be used.
3. An old small handkerchief or a ball of surgical cotton.
Step 2: STEP 2
Open the dust chamber by pressing the unlock button of the Dust chamber.
All parts of the VACUUM CLEANER are named in this photograph, so it becomes very easy to follow.
For this project a video demo is not required.
You can even do the job by looking at the Photographs. They are self instructive.
Step 3: STEP 3
In this step you detach the dust filter from the main body by pressing the unlock button shown
in the photograph by an arrow.
Step 4: STEP 4
In this step please check to see if the can of perfume is working or not, or is it empty?
Step 5: STEP 5
In this step take out the Air / Dust filter from the Dust Chamber.
Step 6: STEP 6
In this step spray a good amount of perfume on the handkerchief, or cotton ball whichever you want to use.
You can also place some moth balls in the dust chamber for spraying in your closet or cupboard.
You can use Shaving lotion or any type of good smelling liquid.
Step 7: STEP 7
In this step roll the handkerchief into a ball and carefully place the perfume sprayed
handkerchief in the dust chamber.
Take care to see that it dose not block the air intake opening.
Step 8: STEP 8
In this step please note that the air / Dust filter is not fitted back, in reverse position.
The photograph shows the correct sides of the filter.
Step 9: STEP 9
In this step after aligning the proper side of the air filter with the Dust chamber spray some
more perfume on the Air / Dust Filter.
Step 10: STEP 10
In this step fit back the air filter to the dust chamber with the sprayed handkerchief inside the dust chamber. Check to see that the handkerchief dose not block the air intake opening.
Note to see that the air filter is fitted back in its right position.
Step 11: STEP 11
In this step fit back the front assembly housing to the main body of the vacuum cleaner.
This includes the sprayed handkerchief inside the dust chamber and the air filter.
Step 12: STEP 12
This step concludes the FRAGRANCE SPRAYER instructions.
Now you can start spraying your house with any sweet fragrance of your choice.
  • Sew Warm Contest 2018
  • Paper Contest 2018
    Paper Contest 2018
7 Comments
where do u live in india? i live in chennai
CUTTACK, Orissa.
hi:
This could be dangerous, especially if the fragrance containes
a propellent like butane or  a perfume or aftershave contains
alcohol , as the fumes will possible escape out of the bag
or pass through the motor, where there is potientely a source of iginition
hope the info helps ... Paul
Great job, but I don't think I'd be willing to use a vacuum to spray for a few seconds in my house. Maybe for a huge room... *shrug* anyways, good job -
Very true......My house is large and I got fed up of using commercial room freshener as they are expensive. This job is meant for large houses with big rooms. Thanks.
You could set something like this up to a switch or timer, then place it in you air duct system close to the fan. It would spread the fragrance evenly throughout the house, as long as all vents were open. Then you wouldn't even have to carry it about the house.
