3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
FREE 17" LCD Monitor - How to do it?
FREE 17\" LCD Monitor - How to do it?
Do you badly need a 17" LCD monitor? Meanwhile, are you broke? OK. Now I'll teach you how to find a used non-functional Dell 1702FP LCD monitor and show you how to fix it!.. If you succeed, you'll save another hazardous electronic from ending up in a landfill.
Dell 1702FP is a really neat LCD monitor. Here are some specs:
Contrast Ratio: 350:1
Aspect Ratio: 5:4 (Regular)
Max. Resolution: 1280 x 1024
Inputs: VGA/DVI
The bad thing: it has a very common problem: it fails to power on after a certain period. The marketplace is full of faulty Dell LCDs.
The good thing: the fix is very easy. All you need is to replace a capacitor, and voila! it works again. The cost of capacitors won't exceed a dollar. Considering that you have the tools handy, then your only cost is acquiring a faulty monitor...
TOOLS NEEDED: Philips screwdriver (no. 0 and 1), pliers, soldering iron, solder, utility knife...
PARTS NEEDED: Electrolytic capacitors - 2 pieces 10uF 16V (critical ones), 6 pieces 22uF 16V, 4 pieces 100uF 25V
Step 1Go and find a faulty Dell 1702FP!
Well, not a very easy and quick job, but still easier than you think! If you are not willing to pay for it (like me) go and check out IT services at your school, look at recycling centers, curbside garbage bins, etc. I am sure you'll come across one. I found two only at my department! If I check the whole university I am sure I'll find dozens more...
If you are willing to pay some for it, go check ebay! You can get something ranging from $10 to $40 including shipping. Make sure you are getting the power brick, too. Otherwise you'll shell out another $15-$30 for it.
The fault description you are looking for is "blinking LEDs" and "no picture". Sharp ears can hear a soft clicking sound coming from inside the monitor, too. Make sure that LCD has no cracks, visually it looks fine, etc.
If you are overwhelmed with search results, you can narrow it with tags like "AS-IS", "BROKEN", "FOR REPAIR", "FOR PARTS" or "FAULTY"... Also, check the ones with very low bidding price/history. There are not many people looking for faulty LCDs, yet. :-)
157 comments
1-40 of 157next »
Mar 12, 2012. 11:20 AMdgluck says:
Great teaching. On my now dark 1702FP, the capacitors are much smaller than the black one in your pic (C604) and silver/black colored. And the leads don't seem to go all the way thru the board. Can they be soldered on the same side as the capacitor rather than on the back of the board as I expected? Thx. :Dani
Jan 30, 2012. 9:43 PMaoscar2012 says:
Please I need information about conector of video board because i broked the white conector (CN202 of 10 pin), i need the order of colors wires from pin 1 to pin 10. Please write me the order of cables. Thanks for all (aoscar@speedy.com.pe)
Dec 10, 2011. 8:27 AMlepolgr says:
Your fix still works great!! My old, up to now reliable, Dell 1702FP monitor died last week and I found your fix by using my not-so-good CRT backup monitor to do a Google search.
I ordered all the caps you listed but only needed to change out the two 10uf 16v caps that are labeled as C604 and C507.
Back in business and loving it. :-) Thanks much.
May 27, 2011. 8:43 PMcurious77 says:
thats a nice instruction set, thanx for it. i made my screen come back to life again
May 12, 2007. 8:22 PMNightshade says:
Could I use a 35w vdc cap. When I bought the caps they only had one 16w. COOL Instructable. Thanks
Jul 15, 2010. 5:55 PMCadillac84 says:
Short answer: yes. The w goes with the vdc and is, thus, wvdc (working volts direct current). So the designation is actually 35 wvdc = 35 volts. The thing that makes the working voltage important is that voltages higher than the rated wvdc may cause a breach of the dielectric (insulation) between the layers of the capacitor. Think of a capacitor as two sheets of aluminum foil with a sheet of waxed paper separating them. If the voltage between the two aluminum foils becomes too high, a spark will pop through the waxed paper and that will be the end of that! It is not practical to make capacitors of arbitrarily high voltage tolerance because of expense and size constraints. The voltages inside computer circuitry once we get past the power supply are less than twelve volts for the most part. That's why 16 volts is a good number for most applications. If the 35 wvdc capacitor will fit in the space, it should be just fine.
Dec 18, 2008. 5:35 PMAnonyMouse69 says:
I fixed a old hansol H550 that died from work (they bought a enw one and was gonna toss the ols one out) so I took it. hooked it up and you could see the image on the screen, when powered on you could see it light for like half a second then go black, but the images was there. so no backlight. researching (before I found this site) I found the caps on the inverter were a issue so I took it apart, replaced several caps (maybe less than 3 bucks at radio shack) and the monitor was brought back to life! now given the backlight wasnt super brignt like it was new, I think due to the fact the monitor was on 24/7 on a computer that didnt have power save, so it ran for years powered on so I suspect the lamps are dimmed a little. but for $3 in parts, its a handy monitor for using as a test for computers, or for a secondary computer that doesnt need a super bright hi def lcd monitor :) here is a pic of it after it got working.
May 7, 2010. 3:30 PMLibvree says:
I recently received an H550 (also from McDonalds) with the same problem as Hemingray. Could you tell me which caps you replaced? It would save me a lot of time :)
Jun 19, 2009. 9:49 AMHemingray says:
Do you remember which caps? I have an H550 from here at mcds the manager let me have that has the same problem (lights for 1/2 sec then dead with image still on LCD)
Apr 16, 2010. 7:38 PMLeolaJD says:
Have you ever worked on the 2000fp Dell?  I have that one.  I don't see any physical sign that there are any problems with the capacitors.  No leakage, and they don't look swelled up, although I've never seen this type before.
Jim
Oct 13, 2009. 8:10 PMgoldivox says:
The 2 caps were all my dead 1702fp needed for resurrection; thanks!!
Jun 23, 2007. 1:36 PMdarimini says:
Sorry, could someone explain how these snaps work? I have a Dell LCD 173FPb with a power issue, and I need to get the cover off, but the snaps look a little different (narrower openinings) and I can't figure out in which direction to press.
Sep 24, 2009. 1:17 PMjoyone123 says:
My monitor is Dell LCD 173FPb as well. I can open one side with a flathead screwdrivier but other sides are still tight. Any suggestions?
Sep 26, 2009. 5:08 AMdarimini says:
Are you maybe prying the one side you're loosening too much so that it's tightening the other sides? I had to be a little aggressive with the sides without snaps. I ended up with scratches on the other sides of the monitor, and there were a couple of times when I cringed and pulled, praying I wouldn't break it. It worked, and it didn't snap in half, but I had to pull harder than I was comfortable with. Whatever that's worth.
Jul 27, 2009. 11:18 AMkjreisman says:
Thanks for the great instructable! I got my 1702FP from my dad several years ago and it's my 5 year old son's screen now. I had never soldered anything before but I got it working in under 15 minutes. Picture is bright and looks better than ever.
Jul 13, 2009. 4:03 PMjkesa says:
Worked for me just replacing C507 and C604. In fact, I accidently broke off C604 and it still worked fine, heh.
Jul 9, 2009. 10:23 PMThousandParadox says:
i replaced the 2, 10uf 16v capacitors and It worked grate!... But it Broke again 1 week later! i think ill try getting Higher voltage capacitors like DKW said on step 6 (i should have read the comments)
Jun 4, 2009. 6:22 PMstellarwarlord says:
I bought all the caps you mention but only replaced the two caps at c604 and c507 to get my 1702FP working again. Here's the link to where I got my caps: http://www.parts-express.com/pe/showdetl.cfm?Partnumber=020-1014%20%20%20%20%20%20%20&FTR=020-1014&CFID=10534636&CFTOKEN=52523994
I used a 15w soldering iron and some fine silver solder I had laying around.
Thanks a lot for the Instructable!
Jul 2, 2008. 11:36 PMabadfart says:
sweet i have an old dell monitor that stopped working but i found a A/V to VGA cable for $5 so im going to hook it up to a vcr
Jun 2, 2009. 11:19 AMDerin says:
Make sure that it has the correct connections.That's how the electronics store ripped me off with a "composite to usb cable".It was just composite leads hooked up to an USB plug.
Jul 24, 2008. 11:25 PMAdmiral Puffinfresh says:
Aww damn I need one of those for my PS3. Where'd you find it?
Jun 2, 2009. 4:42 PMabadfart says:
i think it was newegg
Sep 20, 2008. 11:45 PMbomberman3 says:
i would check monoprice.com (huge selection of cables)
Feb 4, 2009. 8:08 PMtysonscott2002 says:
so i have the 1702fp monitor, and the lights along the bottom turn on normally, as if the monitor is on, and running, but the screen never changes, no flashes, no backlight.. and i have also replaced the critical 10 ohm caps.. help, please!
Mar 16, 2009. 7:44 PMxfactornos says:
Its a 10 micro farad. which is 10 x 10-6
The little u means micro.
10 ohms would be a resistor.
Hope this helps.
Apr 27, 2011. 12:16 AMtysonscott2002 says:
yea.. my bad, i meant what i knew, lol. i did replace them with 10uf caps, NOT resistors, i just said the wrong thing. anyways, i replaced the critical caps (even though they looked fine) with new ones, and still nothing, and the board looks just fine everywhere else, but i have yet to look at the underside of it.
Apr 27, 2011. 8:14 AMDerin says:
Try replacing the screen and backlight.
Nov 4, 2008. 12:25 PMericpwong says:
will it work with a Dell 1800FP?
May 31, 2009. 1:24 PMReCreate says:
It should Work For Many Devices, It could be as simple as a capacitor and as complex as the processor
Sep 3, 2007. 9:51 AMhacster says:
Hey Thearchitect.. You simply are a genius. Thank you for a very very usefull guide Best regards Hacster
Dec 7, 2008. 11:05 PMsethu005 says:
hi, there are vertical lines in my 17 inch L.C.D. monitor. please tell me how to fix it
Apr 30, 2009. 10:20 AMDerin says:
The TFT's are probably disconnected.I don't know a solution.
Apr 25, 2009. 11:18 AMgururaj says:
Hi thearchitect, Thank you very much. After replacing that 2 faulty,10uf capacitor said by you, my monitor is working fine now. Really very good posting. How could you guess that these two capacitor might be faulty. Anyways Thank you once again.
Jan 9, 2009. 10:59 PMDKW says:
Something I have found over the years I have spent repairing electronics is that using Electrolytic Capacitors rated at about twice the working voltage of the device is best. The voltages of the above named Capacitors are only 2 volts above the working voltage of the Monitor witch is 14 volts. The least voltage I would use is 25 volts, and if I have room I would use cap's rated at 35 volts. Remember the Capacitance is generally critical, And never use a capacitor rated at a lower working voltage then your project. Allelectronics.com is a great parts source.
Mar 23, 2009. 3:27 PMsarach says:
Thank you for posting this comment! I called Radio Shack and all they had were the 10uf 35 V and I know NOTHING about capacitors and circuitry so I wasn't sure if more voltage would fry my monitor completely or not. You rock! Sara
Mar 28, 2009. 11:07 PMDKW says:
On my monitor I replaced both 10uf caps and the monitor has been running 100%. The higher working voltage just takes the stress off the caps.
1-40 of 157next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
14
Author:thearchitect
I love fixing things...
