3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
FREE 17" LCD Monitor - How to do it?
Step 6Replace the faulty capacitors!
Dell used surface mount electrolytic capacitors on this monitor. They are no different than regular electrolytic capacitors, only a plastic bottom part which enables robots place components on the board.
We will start by replacing two capacitors: 10uF 16V... I heard that most of the time this replacement is enough to make the LCD work again. These two capacitors are labeled as C604 and C507. If changing these won't help, you may try to replace remaining capacitors.
Prepare your soldering iron, solder, utility knife (or something else to cut the capacitor legs short). Start heating your soldering iron...
And the capacitors! Here is the list of all electrolytic capacitors that Dell 1702FP has on board:
2 pieces 10uF 16V (critical ones)
6 pieces 22uF 16V
4 pieces 100uF 25V
STEPS:
De-solder the old capacitors! Polarity is printed on the board, so you don't have to pay attention to polarity when you are de-soldering the faulty ones.
Reshape the legs of the new capacitors into T figure. Trim the long legs, so you'll have legs only long enough to sit on the circuit board firmly.
Solder the capacitors on the circuit board. Pay attention to the polarity. All electrolytic capacitors come with polarity signs on them. Put them on the board in correct direction, otherwise they will blow up. Look at the last photos on this step, these are new capacitors in place.
21 comments
Mar 12, 2012. 11:20 AMdgluck says:
Great teaching. On my now dark 1702FP, the capacitors are much smaller than the black one in your pic (C604) and silver/black colored. And the leads don't seem to go all the way thru the board. Can they be soldered on the same side as the capacitor rather than on the back of the board as I expected? Thx. :Dani
May 12, 2007. 8:22 PMNightshade says:
Could I use a 35w vdc cap. When I bought the caps they only had one 16w. COOL Instructable. Thanks
Jul 15, 2010. 5:55 PMCadillac84 says:
Short answer: yes. The w goes with the vdc and is, thus, wvdc (working volts direct current). So the designation is actually 35 wvdc = 35 volts. The thing that makes the working voltage important is that voltages higher than the rated wvdc may cause a breach of the dielectric (insulation) between the layers of the capacitor. Think of a capacitor as two sheets of aluminum foil with a sheet of waxed paper separating them. If the voltage between the two aluminum foils becomes too high, a spark will pop through the waxed paper and that will be the end of that! It is not practical to make capacitors of arbitrarily high voltage tolerance because of expense and size constraints. The voltages inside computer circuitry once we get past the power supply are less than twelve volts for the most part. That's why 16 volts is a good number for most applications. If the 35 wvdc capacitor will fit in the space, it should be just fine.
Jun 4, 2009. 6:22 PMstellarwarlord says:
I bought all the caps you mention but only replaced the two caps at c604 and c507 to get my 1702FP working again. Here's the link to where I got my caps: http://www.parts-express.com/pe/showdetl.cfm?Partnumber=020-1014%20%20%20%20%20%20%20&FTR=020-1014&CFID=10534636&CFTOKEN=52523994
I used a 15w soldering iron and some fine silver solder I had laying around.
Thanks a lot for the Instructable!
Sep 3, 2007. 9:51 AMhacster says:
Hey Thearchitect.. You simply are a genius. Thank you for a very very usefull guide Best regards Hacster
Dec 7, 2008. 11:05 PMsethu005 says:
hi, there are vertical lines in my 17 inch L.C.D. monitor. please tell me how to fix it
Apr 30, 2009. 10:20 AMDerin says:
The TFT's are probably disconnected.I don't know a solution.
Jan 9, 2009. 10:59 PMDKW says:
Something I have found over the years I have spent repairing electronics is that using Electrolytic Capacitors rated at about twice the working voltage of the device is best. The voltages of the above named Capacitors are only 2 volts above the working voltage of the Monitor witch is 14 volts. The least voltage I would use is 25 volts, and if I have room I would use cap's rated at 35 volts. Remember the Capacitance is generally critical, And never use a capacitor rated at a lower working voltage then your project. Allelectronics.com is a great parts source.
Mar 23, 2009. 3:27 PMsarach says:
Thank you for posting this comment! I called Radio Shack and all they had were the 10uf 35 V and I know NOTHING about capacitors and circuitry so I wasn't sure if more voltage would fry my monitor completely or not. You rock! Sara
Mar 28, 2009. 11:07 PMDKW says:
On my monitor I replaced both 10uf caps and the monitor has been running 100%. The higher working voltage just takes the stress off the caps.
Jan 24, 2009. 1:12 PMshello says:
Hi K, Your instructions and steps are excellent and clear for the DEll 1702FP monitor, however the symptoms described with the BLEDS are the same for me with my Dell E550 CRT Monitor. Do you have any experience with this monitor and what capacitors should I change to rectify the problem? Your feedback would be appreciated. Thanks.
Jul 27, 2008. 7:24 PMwannabetrumpt says:
really cool, but I'm stuck. After ripping the thing apart with my bare hands (ok.... maybe not, but I feel like it.) I actually have an HP 1702 but this got me going in the right direction. Reading up on the problem links to to caps as well. After scanning the circuit board and a funny orange one about twice as large, I can't find a single bad cap, or anything of that matter. Does anyone have any experience with this? I will post some pictures if I get a response by someone. (anyone notice that the HP 1702's look really cool when out of the ugly black housing? Stick two of those together and voila!)
Nov 25, 2007. 2:06 PMNanuq says:
Wow what a great instructable! You rock! So, this is related, but not exact (I don't think). My monitor power quit working the other day. After finding out that its no longer on warranty, I decided to take it apart and see if I could do anything. Now, I know a bit about computers but not so much about circuit boards and electronic stuff. There are a number of components that look like short AA batteries, with a plastic jacket and a metal top with an X on them. One of these components has obviously shorted out (or something); it is brown on the top instead of shiny metal and has a bit of crud on it. So...what exactly is this component, can it be replaced and how would one (or one's husband who is more electronically inclined) go about fixing/replacing it? Oh, and it is on a Dell 1905FP LCD monitor. Thanks so much and keep up the great work!!
Feb 5, 2008. 6:24 PMraghavranjan says:
Hi K, I thought I could fix my DELL LCD monitor lying in the basement for over an year. I opened it - But the PCB is different : Its a 1701FP and not 1702. There are many more capacitors - Any ideas? TIA
Dec 18, 2007. 5:29 PMNanuq says:
Hi K. the architect :-) OK, hoping you can give me further advice. I replaced 2 blown capacitors and now I appear to have power to the monitor and maybe a backlight (?) but still no input from the cpu. Any marvellous advice?
Dec 25, 2007. 12:57 PMwwward says:
Plug it in, silly! ☺
Nov 23, 2007. 3:29 PMmichajoh says:
Thanks, instead of trashing a good monitor, I put < $3 of parts and a little time and my flat panel is back in business. I only needed the 2 10s. Anything on a compaq tft8020?
Jul 7, 2007. 10:28 AMdarimini says:
I couldn't find the capacitors listed here at Radio Shack. I did find this 10µF 16V 20% Dipped Tantalum Capacitor, but when I went to the store, I noticed that it did not have any polarity indicators on it. And Radio Shack doesn't have any 22uF 16V capactors or 100uF 25V capacitors.
So: (1) Are Tantalums "neutral" or something? (2) Where are you guys buying your capacitors?
Thanks!
Jul 7, 2007. 3:38 PMdarimini says:
Thanks! Since I've posted, I found out that my blinking LED (I have a Dell E173FPb) is more likely a result of bad C5707 transistors. So now, since people are charging an arm and a leg for them (since they're in demand from this common problem), I'm trying to find an inexpensive alternative. If anyone could help with that, thanks! If not, thanks anyway!
Jun 12, 2007. 10:37 AMxenoalien says:
Does it show the polarity on the capacitor as a - and +?
Jun 12, 2007. 5:42 PMpm709 says:
the capacitor only shows polarity as a - on one leg..
Jun 12, 2007. 10:31 AMxenoalien says:
What type of solder should I use? Is there a good brand?
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
14
Author:thearchitect
I love fixing things...
