What is a Question?
Questions are a super-easy way to get answers from the Instructables community. Learn how to build, do, or make anything! You just ask a question and the community will provide answers. You choose the best answer!
Submit a Forum Topic! The forums are the place to ask questions, share a cool project from another site, find collaborators for your latest project, or discuss anything of interest to the Instructables community.
Do you have a lot of images to upload?
If you prefer to upload your images before you submit, then this is for you.
Remember to tag them so they will be easier for you to find when you are viewing your library.
You can also upload images when you are creating your posts.
Did you find a bug or have a suggestion for us?
We appreciate all the help our users give us in tracking down bugs and making the site better for everyone.
PhotosPhotos
I connected the Positive end to one line of the female phone jack and the negative to the other. You could wire it directly to your light but I chose to do it this way so I could test other sources with just a phone jack interface cable. The Red and Green go to corresponding colors on the phone line that plugs into the wall.
i live in pakistan where the phone line voltage are 24v,......... i use this scheme (diagram) and get output voltage..... but the problem is that my LEDs get fade after 15 seconds..... when i disconnect one input cable and reconnect it the LEDs again get on Working....... what should i do please guide me, thanks
Considering the flak you are taking, I thought I'd make a few suggestions... Besides "do not mess with somebody's supplier of 911 services", that is...
Here goes: right now, your 317 is getting hit by rather large 120 hertz pulses, 40,50 volts or more. It will die eventually, but what doesn't? Put a resistor in series with the input of the 317 to drop some of the excess voltage into waste heat. Ideally, you compute the value of the resistor based on the total load (317 running=2mA, LEDs, in SERIES, 10mA)=12mA. You want the output voltage to be say, 5 white LEDs with each "dropping" 3 volts = 15 volts DC. The 317 wants an overhead of 3 volts, so the ideal input voltage is 15V + 3V=18V. So you need to drop the "raw" pulsating voltage down to 18V. Lets say it is 45V, then 45-18=27V that has to be dropped, at 12mA. Ohms law R=E/I = 27/.012 = about 2200 ohms. Power dissipation being what we do with it, we must know what power rating the resistor should have P=E*I = 27 * .012 = 0.324. Go with a 1 watt to be safe. Between the resistor and the 317 input, connect an electrolitic capacitor 22uF/150v capacitor (positive to the input!)so that the dropped voltage is somewhat consistant. Keep in mind that the 100V ringing pulses might evntually blow the capacitor, but that's fun too. Just don't be looking straight down at it when it happens.
Of course, with enough LED's, you wouldn't need ANY other parts but!
Now, your circuit should last long enough for the FCC to drop by your place. They do not need a contract with you to fine you or drag you to court. Good luck.
