Remove these ads by
Signing UpStep 1What You Need...
2. (1) 240ohm resistor
3. (1) 510ohm resistor
4. (1) LM317L Regulator
5. (1) KBP210 Bridge Rectifier
6. (2) Phone line cables
Remove these ads by
Signing Up| « Previous Step | Download PDFView All Steps | Next Step » |
All Steps Viewing
From the pictures you have posted they are 1/4 watt axial. But who knows?
You really should post this info as people going to buy these parts to build this will not know what values to get.
plzzzzzzz answer me
salman.jaany@gmail.com
Money saving hidden electricity
First, don't use the KBP210 Bridge Rectifier. That's used to convert AC to DC but the voltage on the phone line is already DC so all it does is waste 1.4V of your power source (when current has to flow through diodes it burns up extra power). You can tell he has his multimeter set on DC voltage in the video, this verifies that's what's coming out of his wall jack. I guess it would save you if you accidentally connected the green and red wires backwards but just don't do that.
Second, if you already have DC, figure out what voltage you need for your device and use the LM317L or another adjustable regulator. He has the resistor network connected incorrectly so refer to the datasheet from Texas Instruments. What you need to do is hook up the resistors so when you get your desired voltage on the Output pin, the Adj pin sees 1.25V. The way he shows it hooked up it looks like the circuit will just output 1.25V (the Adj pin draws so little current it's at effectively the same voltage as the output it's hooked to through a resistor). You need one resistor going from the output to the Adj pin, and one going from the Adj pin to your ground.
Anyways, check your output with your multimeter before you hook it up to your valuable electronics.
i wonder why he isn't using filter capacitor? ???
by the way nice hacking :)
THank YOu again! :)
marC:)
danialjose(at)gmail(.)com
http://noelbautista.com/blog/diy-solar-lantern-part-13/
It would also work if you use 38/3.4 = 11 LEDs in series.
Also "not a good idea" in the UK is huge great coils in your loft to gather any "spare" electrical energy. Don't know about the flourescent tube under the power lines trick though - but not that useful unless you're living in a tent !
this will also work when the power is out because all(most) phone lines have a battery backup at the head-end since the equip runs at around -48V (give or take) so they cant just plug it in to an outlet.
the voltage on the line powers the phone %100 and when a call is placed for that number a massive amount of voltage is sent down the line to power the ringer. (not enough to kill you but you will definitely know when it is ringing)
when you take the phone off the hook it closes the circuit and prepares for the number
when you use the line you are actually getting a dial tone which means that you are taking up one of the central offices lines... they might notice if you have been on the phone for 8 hours
correct me if i fubar'd any of this
