Introduction: FUN Gloop Corn Flour Experiment
Picture of FUN Gloop Corn Flour Experiment
Step 1: Ingredients
Picture of Ingredients
Small amount of water Small shallow bowl Regular cornflour (powder) Tablespoon
Step 2: Adding the Cornflour
Picture of Adding the Cornflour
Add approxaty 2-3 tablespoons of cornflour into the bowl.
Step 3: Add the Water
Picture of Add the Water
Add approximately 3 and a half tablespoons of water to the corn flour
Step 4: Mix Well
Picture of Mix Well
Mix well till all the corn flour has been removed from the sides of the bowl
Step 5: Done
Picture of Done
Squizze ALITTLE bit and open your hand It should start to melt Then squizze it again the repeat CAUTION DO NOT TROUGH DOWN DRAIN THROUGH IT IN THE BIN. if you crumble it just put a TINY TINY amount of water i it and mix bit if tou crumble to nuch, it doesnt work. if you get the mix in your hair, IT IS FINE. Just Rinse it In some water because it DESOLVES very very quick so don't worry Same go for your clothes Only use on lamanate tables/counters Do not use on carpet. If mix gets on floor, Either use a damp cloth to remove or use hands! You can eat alittle bit if you want
Clairebear55996 (author)2013-08-26
It is just fun to play with
GorillazMiko (author)2013-02-11
What am I supposed to use this with?
GM
About This Instructable
1,252views
18favorites
License:
More by Clairebear55996:How To Clean Your Zen Magnets / Neo Cube / Buckey BallsFUN Gloop Corn Flour Experiment
Add instructable to:
