Introduction: Fabric Dye Sprinkle
Picture of Fabric Dye Sprinkle
I accidentally created a new dying technique using powder dyes. It requires sprinkling of dyes and then pouring water on it to get mesmerizing colors and flows. Check the instructable for complete directions.
Step 1: You Will Need
Picture of You Will Need
Fabric( I have used cotton here, this techniques may not work on silks as the colors may flow excessively)
Powder acid dyes
A paint brush to sprinkle the dyes
Water
Steamer
Some old newspapers
Acid/ vinegar to set the colors permanent
Step 2: Wet, Wring the Fabric
Picture of Wet, Wring the Fabric
Start by wetting your cloth, this help it take dye better.
Once wet, wring out as much water as possible, this step is crucial as if there is too much water on the cloth the dyes will bleed.
Step 3: Sprinkle the Dyes
Picture of Sprinkle the Dyes
Spread your fabric flat out on a plain surface. Now sprinkle your powder dyes on it, I used a paint brush to do so. The closer you spray to the fabric the more concentrated the dots would be.
Experiment with your sprays and create a pattern which you like. I wanted blue and yellow swirls so I overlapped some of the dye so that the colors could intermingle.
Step 4: Pour Water
Picture of Pour Water
Once you are happy with the placement of your dyes pour tiny amounts if water over the dye . The dyes will start bleeding on the fabric, this will create the effect.
Start by drops of water and gradually increase the amount. Stop when you are happy with what you have achieved. You can leave some portions of the scarf without adding water to create more variations.
Always remember that the colours will keep bleeding till the fabric is wet. So make sure that you wait for it to dry and check the results before adding more water.
Let it dry whilst still laying flat.
Step 5: Wrap and Steam
Picture of Wrap and Steam
Once the fabric is dry, it has to be steamed to set the colours permanent. For this warp the fabric in newspaper. Make sure that the fabric does not touch itself, as colour would transfer at those points.
I have used a gas steamer to steam my fabric. Check the dye instructions to know how much acid is required for the dyes. Steam it for 40- 50 mins.
Step 6: We Are Ready
Picture of We Are Ready
And voilà, your scarf is ready to wear.
Ror more creative ideas visit my blog. :)
TesseractCloth (author)2016-06-01
This is a fun technique but the best dyes to use on cotton are Fiber Reactive Dyes, acid dyes can wash out and fade from cellulose even with steaming. A spray bottle works really great for applying soda ash water so you can control how much one area spreads with how much you saturate it. Lovely scarf!
Yes, i realised that after the first wash. The colours bled excessively, but thanks for the appreciation :) would use the other dyes next time
About This Instructable
659views
7favorites
License:
Bio: I love to create and I love to share ideas, so here we are!
More by tangytinge:Globe clay cowHealing TeaHand Dyed Rainbow Tassel Scarf
Add instructable to:
