Fabric Printing with Citra-Solv
 by Ninzerbean
Featured
Any photograph, image or design that looks good in black and white is a great candidate for printing with Citra-Solv. It's permanent, can be washed in the washer, takes about 2 minutes to do and it's cheap and easy. Once you start printing it's hard to stop because the possibilities are pretty endless.
Step 1: What you need:
1. Citra-Solv. They have an incredible website with product info, art stuff, oder info, go here. If you live in the States you can find it at just about any Whole Foods. But save yourself a trip and go to their website if you live far from town. There are great ideas there that I didn't know about until after I wrote this 'ible.
2. Small shallow bowl
3. Cheap 1" or larger paint brush
4. Fabric you want to print on (this should be the smoothest fabric you can find - usually that means a tight weave, but experiment - if you don't have a lot of detail such as a photo you can use a looser
weave fabric.
5. An iron
6. Access to a copier that uses toner (most do, like a Xerox or Cannon etc.)
7. Newspaper or something to protect your dining room table if need be
8. A big spoon, wooden or metal
9. Some pins
10. Images you want to print
Step 2: About Citra-Solv:
Citra-Solv must have some other uses besides being used to print images onto fabric but I don't know what those uses are unless I read the side of the bottle. You can do that if you want. I am not going to be pedantic and do it here.
All that matters to you and I is that it is pleasant to smell, but you still need to use it in a well ventilatied room or outside, and you should try not to get it on your hands - it doesn't burn but it's not good for you. Keep it out of your eyes obviously - OK, I read the side of the bottle. A little bit anyway.
There is more info about this in the ironing section - be sure to read that too.
Step 3: What to do next:
Make a bunch of copies (on a copier) of photos you like or images or designs. Until you get the hang of it keep your images to about 4" x 4" (10 mm) to start with. You will find that you get better the more you do, but in the beginning just use some junky fabric. It takes a little practice to know how hard to burnish, how secure the paper must be not to be moved while you are burnishing and how much Citra-Solv to use.
You can use images that you have on your computer (I am assuming I don't have to say anything about copyright stuff here, you know the drill by now - DONT COPY other's work without permission). Print them in black in white or color - it doesn't much matter as you are going to be making copies of them on the copier that will be in black and white.
You are then going to lay the image upside down, meaning that you will be looking at the back of the paper. Now secure it to the fabric with those pins from the supply list.
Step 4: Brushing on the Citra-Solv
As you can see from the above photos the stuff is like water and it's easy to just wipe it across your upside down copy in under a second.
Step 5: Burnishing
This is where your spoon comes in. It can be a metal or a wooden one, but the idea is to rub and rub the spoon on the image. That rubbing pressure will make the ink, which has been turned into a liquid from the Citra-Solv, transfer to the fabric underneath.
Your printing/burnishing surface must be fairly hard - not as hard as a table and not as soft as a towel on top of a table; newspapers and a piece of fabric give about the right hardness. Think about how the paper would bend if you were burnishing on a really soft surface. Think about your lack of surface area on a really hard surface. Look for something to give you an in-between surface.
Step 6: Peeking
In this step you take out all but one pin and take a peek to see how you are doing - is the image all there? Is is smeared? Is is dark enough? I can tell you from experience that once you get the hang of this kind of printing you will not want to take a peek because no matter how careful you are to place the paper back down just right, it usually shifts just a tad. The result is a blurry print.
But the reason I want you to peek at this point is because you are just practicing. Peek enough times and you will soon get to the point that you won't have to.
Step 7: Ironing
Sometimes I don't remove the paper at all but iron right on it after burnishing. Sometimes I remove the paper and then iron. Sometimes I think I get a darker print if I iron right through the paper but I think more depends on the weave of the fabric.
Iron on a cloth to protect your ironing board. You are protecting it from smelling like Citra-Solv forever and also in case any ink goes right through your fabric.
I don't think it is a good idea to breath Citra-Solve fumes as they evaporate from the hot iron so you should do this outside or in a well ventilated room or wear a real gas mask. When I am working with it I tend to print many, many images on a piece of fabric so I wear a real gas mask, don't let this deter you from tying this 'ible. I use a lot so I take more precautions. It doesn't say anything on the bottle about it being harmful if inhaled (it does smell pretty good too) so it must not be, but it's just common sense to me. (Yes, I read the side of the bottle after all).
Step 8: Hints
Weave matters. The tighter the weave the more detail you will have in your print.
Poke just a small hole in the top of the Citra-Solv bottle so the stuff doesn't evaporate too fast and so you have more control as you pour it into that shallow dish.
Iron your fabric before you start printing because you really need a flat smooth surface.
If you are printing on a T-shirt put something inside the shirt so you don't have ink bleeding through to the back of the shirt.
I know you will ask but no, you cannot use this technique with stuff you print out from your inkjet printer. I tried it and nothing happens, no ink transfers because no ink dissolves. Laser printers I do not know about - try it and let us know.
An Addtional Note: I tried this technique with a color laser copy (not to be confused with a color laser print, which I have not tried yet) and there was no transfer at all. The color copy (from Kinkos) was a few years old. A brand new copy may have a dfferent effect.
Remember that if you are printing an image with words on it that they (the words) will print in reverse. Actually the image will print in reverse too. You probably already knew that but just in cae you didn't, make them backwards before you make your copy so you can read them. Some really great copiers have this feature - so if yours does, use it. You will only forget one time.
Step 9: The best step - you can wash it!
Yes you really can. I have even tried to bleach it with no effect at all. It's on there for good.
Step 10: The End
Happy Printing. Don't hesitate to ask me questions, and please rate my Ible. Citra Solv has a great link to finding printers and copiers that work well - here.
1-40 of 239Next »
lainey310 says: Oct 12, 2012. 6:59 AM
HELP, I have a samsung color lazer multi format printer, lazer
I printed out a page from graphic fairy, bought the citra solv did everything you did and got nothing/
what am I doing wrong
Ninzerbean (author) in reply to lainey310Oct 12, 2012. 7:43 AM
It's a printer, not a copier - your Samsung - you say so yourself. Please read the comments, you will find a lot of information there about the difference between copiers and printers and inks, toners, carbon based toners etc. I do not know what a graphic fairy is, is it is a place you went and had your printed image copied and if you asked them if they were using a color copier or a simple black and white one?
lainey310 in reply to NinzerbeanOct 12, 2012. 8:00 AM
sorry graphic fairy is a web site that you could print images off ofon your computer, so your saying that a printer could not be used for this project, could you tell me if I take a copy of the print to a printing place would they make one that will work, Thanks for your help, Idid read alot ofthe comments but
I guess Im still not understanding,
Ninzerbean (author) in reply to lainey310Nov 4, 2012. 3:29 AM
If you go to the Citra Solv website there is a lot of new information about printing that was not there when I wrote this 'ible, of special interest to you would be this section.
Ninzerbean (author) in reply to lainey310Oct 12, 2012. 12:08 PM
Sorry to put you off like this but you really must read all of the comments to get the best understanding,otherwise I'm repeating myself.
Light_Lab says: Oct 9, 2011. 9:44 PM
Are you sure you need the Citra-Solv? I have been doing this for years by just ironing the paper with a really hot iron. I mostly use laser printer printouts but they are made by exactly the same process as modern thermal photocopiers.
I am thinking that the Citra-Solv is just acting as a heat transfer medium because you get about the same amount of transfer as I do when I don't pre-chill the paper.
Here briefly is my best method (but I have had success with variations):
(1) Chill your print paper overnight in the fridge (wrap in plastic to avoid condensation).
(2) Print a mirror image of your design out on a B&W or colour laser printer while the paper is still cold.
(3) Re-chill the paper and take it out of the fridge just before ironing.
(4) The iron has to be very hot, it should yellow paper slightly, Make sure the steam setting is off and there is no water in the iron. (And old iron kept for the purpose is best.)
(5) Place the design toner side down onto the fabric on a good flat ironing board and make sure the fabric is flat (pre-iron if needed).
(6) Iron until your patience is gone or the paper goes yellow. At times I have sprayed the paper with water from a mister to try to increase heat transfer.
(7) If you are really lucky the paper will be stuck to the fabric by the fused toner and you will have to wash it off with water. That usually gives the best result. Other times it just falls off dry, that usually means some of the toner will be still stuck to the paper.
viv664 in reply to Light_LabAug 1, 2012. 9:14 AM
hi
can i chill multiple papers in the fridge or freezer in one plastic bag before ironing??? was going to attempt your process today! i am very excited because it will hopefully produce a crisp print especially with thin straight lines. :-)
Light_Lab in reply to viv664Sep 30, 2012. 3:00 AM
Hi viv664, Sorry to take so long to reply, been a bit ill and trying to make up for lost time.
You should be able to chill multiple sheets together but I have never tried it. Keep in mind that paper is a good insulator and chilling will take longer to get right to the middle of the stack.
Ninzerbean (author) in reply to Light_LabOct 10, 2011. 12:30 AM
Wow, that sounds great, I assume it it then washable too? Thank you for sharing!
Light_Lab in reply to NinzerbeanOct 16, 2011. 3:41 PM
They do fade a bit with washing. This is never a bold full contrast result but sort of rustic so if that is what you are after a bit of fading is OK. I did a black design on a handkerchief about 10 years ago; it has been used and washed hundreds of times and the design is very faded but still visible.
I have been thinking lately that one experiment I haven't tried is to iron from the fabric side. The melted toner should move toward the heat by fluid absorption. Next time!
Ninzerbean (author) in reply to Light_LabOct 17, 2011. 6:27 AM
Well that is the difference then, I guess the Cirtra-Solv 'melts' the toner during the transfer and because it is plastic it wont fade or wash out. I think your process is only transferring the ink from the image instead of actually embedding the toner into the fabric. Why not write up an 'ible on your technique - I'm sure it would be very popular, I know I would enjoy seeing it.
Light_Lab in reply to NinzerbeanOct 20, 2011. 3:49 PM
Are you saying that the Citra-Solv prints don't fade with washing at all? How many times have you washed them? When I say "They do fade a bit with washing." I mean they start to look a little less intense after about 2 or 3 years of typical washing.
I guess I could do an Instructable on it, what would be cool would be to do a proper comparison of several methods to see what works best. I am not sure if I can get Citra-Solv here in Oz though.
Ninzerbean (author) in reply to Light_LabOct 20, 2011. 7:24 PM
No they don't fade at all with washing - I show that in the 'ible. Even bleach does not effect them - see photos in 'ible. Yes it would be great to see comparables! There is a link to the Citra-Solv site in the 'ibel so you can see if you can get it in Oz - where ever Oz may be. Are you like a munchkin or a witch or Toto or something? I think you can only get the stuff in the real world though. When I use this technique it gets run though so much stuff, like over-dying, bleaching, re-dying and such that even though when it is all finished I usually use the fabric in a quilt, I am not afraid that any more washing will fade it, though a typical quilt only gets washed as much as the cat lies on it and makes it worth washing.
We cold even print the same image - your way and my way and then wash however many times you want and post the results with photos.
Light_Lab in reply to NinzerbeanOct 21, 2011. 6:18 PM
Oz = Australia, locals pronounce it Oz-trail-ya so Oz has become a standard in emails and SMS's. Even though I don't drink, there is a lot of beer drunk here and I imagine broom riding witches, dancing scarecrows and munchkins are seen quite often. i{^_^}
As far as the bleach goes; toner colours are predominately pigments not dyes so very resistant to bleach and sunlight; particularly the black. Fused toner is more likely to be lost from fabric by extensive mechanical agitation ie as the fabric fibres wear away. Hence most of my articles that have faded eg the handkerchief, is so threadbare now I would say it is just about had it's day. I really only keep it because it was my first experiment with toner.
I will definitely try to get some Citra-Solv. Actually I should really get serious and checkout exactly what polymer is used for the toner binder and see what appropriate solvents I can find around the lab.
I have to tell you though the "chill trick" pretty well leaves very little toner on the paper when I get it perfect. I suspect that any solvent will only make the lines more diffuse. This would be good for photos but perhaps not as good for text and logos.
Comparing results for the same image is a great idea, I am buried in projects at the moment though, I will take this up thoroughly as soon as I get time.
Ninzerbean (author) in reply to Light_LabOct 22, 2011. 2:31 AM
I think being that you are so far away (and in the real world) is only the more reason we should try this. We can do a collaborative 'ible, it's pretty easy, we can PM each other to set up the private stats to start it. I am as busy as you are but when the mood strikes you just PM me with an image you want to try and we can go from there. I can send you some fabric samples so we are both working with the same 'ground'.
When we are done we can post a link from this 'ible to our 'ible.
uhsnamih says: Jun 3, 2011. 6:19 PM
Can we use a laser printer???
Ninzerbean (author) in reply to uhsnamihJun 4, 2011. 4:08 AM
No you can't, you must use a carbon based toner COPIER, not a printer. For a better explanation of why, read through the comments.
Aight_then in reply to NinzerbeanAug 17, 2012. 1:10 PM
Ahhhhhhhh ... yes you can as a matter-of-fact, Ninzerbean! I have used acetone based fingernail polish remover as well as Citri-Solv using my Samsung 3051N desktop laser printer to transfer flipped, inverted, toner based images to metal for both electro etch and chemical etch resists. The Citri-Solv I gave up on first because it blurred more than transferred. I then gave up on the acetone when I discovered that there is an even BETTER TONER TRANSFER METHOD that could also be used to transfer toner based resists to glass as well ... via heat. I bought a Creative ' Versa-Tool ' (Walnut Hollow). It has it 's own transfer tip dedicated to toner transfer as well as many other tool tips. The first 2 I bought had no heat control but the new ones do ... so sweet ... if you use the right paper, transfer (I get 100% ... nothing left on paper) is way better than chemical transfer and certainly less biologically intrusive. Check out some of the stuff I have done.
Ninzerbean (author) in reply to Aight_thenAug 18, 2012. 4:30 AM
Sounds great! I will check out this tool, in the mean time post some of your work. Thanks for sharing this info too.
Aight_then in reply to NinzerbeanAug 20, 2012. 7:07 PM
You're welcome, Ninzerbean. I must ask: When you say ' post ' some of your work ... I am not really sure what you mean ... do an ' ible' !!!??? I have posted some pics of things (both glass and metal) that I have etched, to my profile. I have also posted captions but I have to be signed in to read them ... seems kinda pointless as far as being informative to others !? I figured maybe it was a Java problem so I switched from FF to IE .... same thing !? Then I figured I was doing something wrong, so I hit the FAQ (second page ' photo Captions' ) ... Caitlinsdad there says that the captions are kinda ' wonky ' and seems to imply that the captions might possibly only work if you have an ible ... any answers would be appreciated as I am really new here!? Oh ... any to anyone else who wants to gain a really good insight into the nuances of toner (yes they are truly different !!!), I found this super informative link : https://netfiles.uiuc.edu/r-evans4/www/toner.html
Aight_then in reply to Aight_thenAug 20, 2012. 7:21 PM
Oh never mind, Ninzerbean I figured it out ... silly me !!!??? I actually don't have any samples of fabric I have done photographed yet . I really do not think it appropriate to post unrelated stuff ( etched glass and metal have their own categories/ibles) here. As soon as I get some pics (today or tomorrow), certainly I will post. But ... I think your technique is way better for fabric than the transfer tool, your tones are more vibrant yet with decent contrast.
Ninzerbean (author) in reply to Aight_thenAug 22, 2012. 10:14 AM
Yeah, I checked out that tool, but it would take forever and a day to transfer with it on fabric you wanted to do a repeat on.
I just meant to attach your photos to a comment - when you have a chance. I think the 'unrelated stuff' would still be relevant here.
Aight_then in reply to NinzerbeanAug 22, 2012. 3:44 PM
Hey Ninzerbean. On the contrary ... it is quite fast with the right technique as I just learned. Earlier I said your tones are more vibrant with decent contrast (than the transfer tool) only because I am not used to transferring toner to fabric but rather glass and metal. Yesterday after looking at my sad picture transferred fabric, I thought what the heck, I'll give it another try. This time I will give it some pressure and higher heat. Blew me away !!! 5 minutes later my second piece was done with outstanding clarity and contrast. Had to try again, this time larger pic ... same quality. You can actually feel the embedded toner. Oh certainly your Citri-Solv transfers are awesome (and do have nice vibrancy and contrast) but I implore you ... TRY the tool. What I am going to do is make a small video and show you how quick it really is, hopefully I can change your mind. So below pictured is firstly the one that I supremely failed on (low heat and very little pressure). In the same picture is my second try (more heat and pressure). The second picture is the second try and my last try. Oh sorry for crappy photos. I have a cheap webcam I had to 'snap' pics from.
Ninzerbean (author) in reply to Aight_thenAug 24, 2012. 7:35 AM
5 minutes is a long time - to me. I can transfer a photo in less than a minute. Your transfer looks great! When I am using this technique I am doing dozens and dozens of repeats on fabric. Can you wash yours and have it look the same? That is key to me when transferring to fabric because it will be washed over and over. Have you tried color prints? I think that is why people ask if they can use a laser printer.
Aight_then in reply to NinzerbeanAug 24, 2012. 8:17 PM
Haha ... you're so totally like me Ninzerbean ... 5 mins. IS a long time for me too, at least that's what the wife says, DOH !!!??? Thanks for the nice comment. I actually tried hand washing and there was slight fading in areas but permanence is certainly desirable. Judging by the look of your transfers, I am thinking they are high in carbon. I think my toner has more plastic than carbon and it really feels like it after a heat transfer. Maybe Citri-Solv somehow ' fuses ' your toner (and any toner?) upon evaporation ... maybe ALL chemical transfers do that ... just an idea !? Did you check out the excellent and informative link on toner I sent earlier ? I have tried color prints on wood (actually MDF) with excellent results, but not fabric. You say you are doing dozens and dozens at a time ... WOW !!!??? As good as your technique is and as quick and durable the results ... you should have a custom print bidness, even though it is not printing per se!? Anyways ... here is the vid I just made (not the greatest quality):
http://www.youtube.com/watch?v=DTvyRhjY5c4&feature=youtu.be
TexasBarb says: Jun 22, 2012. 10:23 PM
Hi. I wanted to share what worked for me. I tried this several different ways. First time I made several things using the printouts from the library and it took a good ten or twenty minutes of rubbing with the edge and bowl of the spoon but made a nice faded tone with a vintage look to it.
Then I tried printing some off at the neighborhood gas station. For holding the print down I found using blue painters tape around the edges would stay on better if the citrisolve got under it. Masking tape released quickly. I held a cotton ball on the top of the bottle of citrisolve turning it over for two or three seconds to wet the cotton ball then rubbed the back of the print covering the whole back of the paper quickly to show the image. I started rubbing at one edge of the image with the edge of my spoon then raised a small corner to check if was doing anything and found It started transferring immediately! It made a dark crisp print that took maybe two minutes to do the entire thing!
It was Amazing! I had also tried some prints from office depot that didn't work. But all of the copy machines I tried that cost .10 cents a print at the station, grocery store, and a small printing company all worked great! It is worth the looking around to find that perfect printer. Once you see how easy it can be the possibilities are endless. And it's addictive. Just warning you. Lol!
Ninzerbean (author) in reply to TexasBarbJun 23, 2012. 5:42 AM
Thank you for sharing, obviously I just had the right copier and had no idea this technique would be anything other than as easy as it is with my copier. Even when I was taught it, the teacher must have had just the right copier, who knew it would be so hard to do with the new technology. I have a Canon PC941 and thankfully an extra ink cartridge. I bought both from Costco years ago. Probably 15 or 16 years ago and I am still on my first ink cartridge come to think of it.
craftdesigns says: Dec 27, 2011. 1:35 AM
I've been transfering toner copies to fabric for over 15 years. One hot iron is all it takes...no chilling the fabric or the copy, just slap the copy, image side down, on the fabric and press the paper with a hot iron. DO NOT slide the iron around...pick it up to move from one area to another. Take a peak after all of the image area has been pressed...if the image is transfered, you're good to go. If the transfer is not complete, continue pressing. Do not launder for one week.
If you want to color the print, use markers that are labeld either Textile or Fabric; these markers are intended for fabric and are permanent after heat setting (cover with paper and press with a medium heat iron). To hold the fabric stable while coloring with the marker, press freezer paper to the wrong side of the fabric (shiny side of the freezer paper on the fabric; press on the paper side of the freezer paper with a medium hot iron to secure it to the fabric). After the marker has been heat set, remove the freezer paper (it pulls off easily).
Other options for coloring: fabric paints; acrylic craft paints with a Texile Medium; permanent stamping inks. All of these supplies are applied with a brush. Heat setting usually is required for permanency (that information will be on the label).
If you're determined to use some type of chemical to transfer the image to fabric...go to the drug store and get a fingernail polish remover pen. That cheapo (and easily found) gadget will transfer as well as anything. Be sure to wipe the marker over the back of the entire image area to ensure the transfer of the image to the fabric. When the transfer is complete, press on the wrong side of the fabric to ensure permanancy. Do not launder for a week.
mmomeny says: Aug 18, 2011. 4:03 PM
Yep, it's ink side down.....I read through all the posts too. I did read one post on another site that said not all toner copy machines are the same. I don't know what that means.....I thought toner, was toner, was toner! I don't feel like driving all over town and stopping to use every copy machine from here to timbucktoo.
Ninzerbean (author) in reply to mmomenyAug 18, 2011. 4:09 PM
I understand, you can always send them to me to copy and I will send them back to you to print with. Just PM me.
mmomeny says: Aug 17, 2011. 7:01 PM
I tried this technique. I went to Staples AND to Kinkos to get toner based black and white copies made. I came home and followed this step-by-step and I have no image at all on my material. So I tried it on paper - still nothing!! What am I doing wrong??
I asked the guy at Kinkos if the copy machines were toner based and he said yes. I even peaked in side and saw the toner drum.......
Ninzerbean (author) in reply to mmomenyAug 18, 2011. 10:48 AM
Are you sure the paper is upside down? I am only asking 'cause there is no reason from what your wrote that this won't work. Have you read through all the comments for anything that may shed light on this? I am as mystified as you are.
otakutheiii says: Feb 7, 2010. 11:43 PM
 So what machines will work for this, so far all the machines in my town are newer and they don't work for this. Do I need to use an older copier?
Ninzerbean (author) in reply to otakutheiiiFeb 8, 2010. 4:40 AM
 Well I didn't think so, you have to use a copier that doesn't do anything except copy for one. If it prints also it is not going to use the carbon based toner and of course it must only copy in black and white, that's been covered. I would think that any small office or home based business would have one you may ask to borrow or pay to use. I did not think this was going to be hard but technology advances may have made it so. You are welcome to send my your images and I will copy them for you on mine, pm me.
vcote in reply to NinzerbeanJul 21, 2011. 4:05 PM
You need to ask for a printer that uses "toner" if the person doesn't know what you're talking about ask them if the ink is powder or liquid. Powder=toner liquid=waterbased ink. Another way to tell is that usually toner cartriges are giant compare to ink. The print also come out of the copy machine or printer HOT. This is a toner printer.
Most all commercial printer and copy machine are toner printers.
Ninzerbean (author) in reply to vcoteJul 21, 2011. 6:41 PM
Of Course! I never thought how simple it is to tell the difference, thank you!
bradleypowell in reply to NinzerbeanMay 14, 2010. 5:57 AM
 A lot of small businesses have ink based "all-in-one" printers.  Laser printers and copiers use toner which has a small metal core coated with a substance that can melt (carbon mixed with polymer).  They work by having a laser draw the pattern on a drum, magnetically charging it, and the toner sticks to that charge.  Then the paper rolls against it while being heated, melting the coating on the paper.  This process is probably dissolving the paper fibers and allowing the toner coating to move to the shirt to be melted by the iron.  Since it isn't a stain, bleach wouldn't have any effect...
This is a really great idea!  Thank you very much for the post.
Ninzerbean (author) in reply to bradleypowellMay 14, 2010. 11:42 AM
You are most welcome, but I have to disagree with your idea about the paper fibers because, well actually if you try it (I hope you will) you will just "feel" that that is not the case, but everything else you said is spot on correct. What I believe is happening is that the toner is "melted" away from the paper onto the other surface. Try it and see what you think afterwards.
xhudaman says: Dec 16, 2009. 5:36 PM
nice ible i was just wondering since i'd like to try this where can i pick up citri solv i've never heard of it before and i dont think i know of stores that carry it so please tell me where in toronto i can pick it up...and 1 more thing i have an hp photosmart if i use the scanner on it to copy the picture will it work?(the comments left me a little confused lol)
Toaster Muffin in reply to xhudamanDec 16, 2009. 6:06 PM
Check out the Citra-Solv website to find out where to buy it in Canada. No, your printer wont work, you have to use a copy from a carbon based toner copier. If in doubt go around town and get copies made from machines that only copy in black and white, make notes of where you got the copies and see which ones work.
1-40 of 239Next »
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
