3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Fabric Stencil Guitar
I patched up the neck and body that were mangled in my last project, (The Skateboard Guitar) and experimented with spray paint and the idea of using fabric as a stencil.
I used Dupli-Color Truck/Van/SUV paint, which I believe is a lacquer. I'm not sure if the chrome is a lacquer, but it seemed to be compatible with the black and clear on a test piece of wood.
Using this type of paint is good because it dries quickly, so you can add new coats within a half hour or so, but it takes months to really cure and harden, which means after doing the clear coats, it has to hang somewhere for a month or two before you can wet sand it to a shiny mirror like finish.
I'm at the waiting stage right now, I will let you know how it turns out.
The chrome isn't supposed to be clear coated, so it turned out kinda gray. I almost wish I had used red or purple or something, but that will have to wait for the next project.
Step 1Prep the Body
Prep the Body
Here is the body from the skateboard guitar. I have filled in the big hole in the front of the body with 2 blocks of wood and wood putty. The wood putty didn't work out so well, and I ended up using Bondo auto body filler to get it right.
At this stage I wasn't sure what this was going to turn into, but I went ahead and sanded the blue paint off, down to the factory paint or sealant.
After painting it with primer, all the remaining flaws really stood out, and I added more bondo, sanded, added more bondo, sanded, primered, more bondo, more sanding. This was the most time consuming part of the whole project.
If I had started with a used Fender or Squier body, I could have just roughed up the finish with 400 grit and sprayed primer and been ready to go.
35 comments
Nov 6, 2011. 3:20 PMuna_amor says:
Awesome work! The fabric looks like a burnt out velvet. Pretty creative way to use that type of fabric. Gives it a real Steve Vai look, or a design you would see on one of his guitars. Love it!
Mar 7, 2011. 5:39 PMubercop says:
love it! really love it!!!
Aug 16, 2010. 10:43 AMscoochmaroo says:
This is beautiful. The applications for this technique are endless!
Jan 23, 2010. 2:04 PMbigpeace says:
i've been using bondo on one of my project guitars here recently. if you get the stuff in the can, you can add a little less hardner and makes it last a little longer while spreading it. bondo can be VERY aggravating until you get used to it lol. i'm using what you've got in the tube to fill in low spots and chips. cool instructable though, i'll keep this one in mind.
Jan 22, 2010. 3:14 AMhardcase says:
That fabric stencil idea is brilliant. Nice work. Have to try that! Not on my Les Paul though.
Dec 1, 2009. 9:38 PMlufegasa says:
it looks sooo cool but i dont understand how u use fabric as a stencil, i would love to do it though, so can u explain a little bit more??
Dec 2, 2009. 6:34 PMlufegasa says:
ohhhh ok!! i thought it might be something like that but i wasn't sure....
thank u!!! i'll have to give it a try
Nov 3, 2009. 5:55 PMJAZ97 says:
you think i can do this on a guitar i built it isnt hooked up yet or any thing but i might use red and black instead
Nov 10, 2009. 1:25 PMJAZ97 says:
true that
but i have a plate like on the guitars i build so easy wiring and you can change the cover of it
Nov 10, 2009. 3:50 PMJAZ97 says:
i wish my cameras broken and i sold alot of them ill try and get something up k
Nov 10, 2009. 3:52 PMJAZ97 says:
i also dont make meny of them because they are hard to make and you can get cuts like when cutting cheese
Nov 10, 2009. 3:56 PMJAZ97 says:
and then you would basicly put a wood peaice over it and screw it into the guitar for you can have a cool design and let it be inetrchangble
Oct 21, 2009. 9:53 AMSleka says:
Damn, that looks mighty fine, I'm about to paint my guitar and this technique is pretty awesome, so maybe i'll use it!
Sep 25, 2009. 8:06 PMadhdkid says:
sweetness... where did you find this beat up guitar?
Sep 13, 2009. 8:36 PMERCBIENG says:
I LOVE IT...it looks awesome
Aug 6, 2009. 3:04 PMLotus14 says:
Very cool. When i was a kid (when dinosuars ruled the world), this was a technique used on some hot rod paint jobs, it was called "lace" or "lacing." You could also do a "candy" technique by spraying a transparent color lacquer over the lace job. Where did you get the filters for your mask? I have the same mask but can't find filters anymore.
Sep 7, 2009. 2:27 AMscott8692 says:
i might do this to my strat been thinking of repainting it but havent really chose how to paint it ....now i know
Aug 7, 2009. 10:01 PMguitarman63mm says:
I will attest that the chrome-ish crap they sell at Advanced Auto Parts is NOT a lacquer-based finish. Several months back, I made a tailpiece for one of my guitars, and sprayed on many thin coats of that junk, only to try and topcoat it with lacquer, to which it had a terrible reaction. I ended up just scraping it all off and leaving the metal bare, with a single coat of clear. I don't know if my problem with that combination was totally my fault, or a reaction between solvents, but I'd steer clear of it. It'd be a crying shame for you to go to all this work and then have my problem... Good luck.
Aug 20, 2009. 2:08 PMSparrow40k says:
Cool!, Does it still look perfect if your put a finish over it?
Aug 8, 2009. 9:07 PMzjgz says:
That is a very nice effect. I'm tempted to try that on one of my old strat knockoffs.
Aug 7, 2009. 6:30 AMmemphissound says:
Very cool effect!
Aug 6, 2009. 7:55 PMBen Harden says:
It looks amazing! Keep up the awesome work
Aug 6, 2009. 3:34 PMinkstainedheart says:
This is going to be a GORGEOUS guitar! I've seen the lacing technique done on furniture and other things before, but I had never thought to use it on an instrument. Nice work!
Aug 6, 2009. 7:29 AMjcsugrue says:
Wow, that really looks pretty awesome. I'm definitely going to give this a try!
Aug 5, 2009. 5:33 PMLuminousObject says:
Sweet.
Aug 4, 2009. 1:57 PMbaken411 says:
looks amazing can't wait to see the whole thing together
Aug 4, 2009. 1:14 PMdarkstar1 says:
Wow nice one
Aug 4, 2009. 12:13 PMArkarinum says:
Awesome!
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
13
Author:ntagn33
