3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Fabric Wallet
Fabric Wallet
This fabric wallet was super easy to make, it only took about 2 hours to make. It ended up being a little bigger that i had first planned but turned out great!
It is 8" by 4"
Step 1Gather supplies
gather supplies
Well, first of all you need to gather supplies, for this project you will need:
-small scraps of different fabrics (including 1 about 1o'' by 10"  square scrap)
-7 inch zipper
-button (mine was about 1 1/2")
-tiny piece of quilt batting or felt/thick cloth
-elastic hair tie (thin ones works better)
-clear plastic (I used a zip lock bag)
-thin cardboard (Kleenex box worked great!)
-color coordinated thread
-fusible interfacing (i don't know if it really does anything...but i put it on)
-sewing machine
-scissors
-ruler
-cutting mat and rotary cutter(you can use scissors, but a rotary cutter is easier)
-iron
4 comments
Jan 6, 2012. 7:48 PMkatvanlew says:
Very cute wallet. I love any project that uses fabric scraps. You could also use plastic canvas instead of the cardboard if you wanted.
Jan 26, 2012. 1:16 PMmarceec says:
I have a waterproof substitution suggestion for the cardboard that may also provide RFID-reader protection (as mentioned in susanrm's comment). Cut a rectangle of the desired size from a clean, dry, empty pet kibble or coffee bean bag with a foil/mylar lining (more substantial than a chip bag). If you want greater stiffness and don't care about the RFID issue, you could cut the piece from discarded clamshell-style plastic packaging. It is thin, relatively pliable, abundant, and not readily recycled yet in many areas.
Dec 28, 2011. 8:26 AMTabbyDeAnne says:
This is a beautiful wallet! Thanks for sharing:) 5 Stars!
Dec 23, 2011. 3:31 PMsusanrm says:
Excellent wallet! Add a layer of aluminum foil in there to make it RFID-reader-proof.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:yoyotom
