Fabric Bend Sensor
Step 1Materials and Tools
Materials and Tools
MATERIALS:
The materials used for the sensor are basically cheap and off-the-shelf. There are other places that sell conductive fabrics and Velostat, but LessEMF is a convenient option for both, especially for shipping within North America.
Velostat is the brand name for the plastic bags in which sensitive electronic components are packaged in. Also called anti-static, ex-static, carbon based plastic. (So you can also cut up one of these black plastic bags if you have one at hand. But caution! Not all of them work!)
To make the sensor fully fabric one can use EeonTex conductive textile (www.eeonyx.com) instead of the plastic Velostat. Eeonyx normally only manufacture and sells its coated fabrics in minimum amounts of 100yds, but 7x10 inch (17.8x25.4 cm) samples are available free of charge and larger samples of 1 to 5 yards for a minimum fee per yard.
The exact neoprene i used for the bend sensor is:
quality: HS
thickness: 1,5 mm
both sides: nylon- / polyesterjersey (standard)
one side: grey, other side: neon green
but you can defiantly try and experiment with different qualities and thicknesses!
also with different materials. i can imagine that foam rubber and similar will work.
one good thing about the neoprene is that it has jersey fused to either side which gives it a nice feel against the skin but also makes sewing easier, as stitches otherwise rip through the plain neoprene.
- Conductive thread from www.sparkfun.com
also see http://cnmat.berkeley.edu/resource/conductive_thread
- Neoprene from www.sedochemicals.com
- Stretch conductive fabric from www.lessemf.com
also see http://cnmat.berkeley.edu/resource/stretch_conductive_fabric
- Fusible interfacing from local fabric store
- Regular sewing thread from local fabric store
- Velostat by 3M from www.lessemf.com
also see http://cnmat.berkeley.edu/resource/velostat_resistive_plastic
- Machine poppers/snaps from local fabric store
TOOLS:
- Pen and paper
- Ruler
- Fabric and paper scissors
- Iron
- Sewing needle
- Popper/snap machine (handheld or hammer and simple version)
- Possibly pliers for undoing poppers
For connecting to your computer:
I'm not going to go into detail here, because this Instructable is really more about the sensor itself and less about this connection. But if you have question just send me message.
- Arduino physical computing platform from www.sparkfun.com
- Arduino software free from www.arduino.cc
- Processing programming environment free from www.processing.org
- Crocodile clips from www.radioshack.com
- A pullup or pulldown to the ground of your Arduino, with a 10-20 K Ohm resistor
- Some wire and solder and stuff
10 comments
Dec 15, 2009. 8:51 PMwindrago says:
I am following your instructable right now - I have only one question where do I get the software that you use for the measurement? (the graph that you show in the video)  - I have been on arduino web site but I didn't see anything. I am new and exicited at this.
Aug 13, 2008. 4:46 AMtewfik says:
WOW Really nice thing you've done here. I love the concept, could be used as you depicted as a glove-control-interface according to your video, it seems that you need some noise-filtering on pc-side (or arduino-side), just a thought you said that it is possible to measure the angle from this sensor, is it linear (ideally) or something non-linear and by the way, is the conductive fabric available or is it a special material you have to order on the internet ? very nice instructable thanks for sharing
Aug 14, 2008. 12:12 PMendolith says:
What's the circuit connecting the sensor to the Arduino? The sensor is just one half of a resistor divider to the ADC? You could do digital filtering in software, but it might be easier to do it with just an electronic filter.
Aug 14, 2008. 6:02 PMendolith says:
By "series" you mean "one resistor divider for each sensor"? Just putting a capacitor across the sensor terminals will act as a low-pass filter and get rid of some of the fluctuations.
Aug 14, 2008. 6:43 PMendolith says:
So try a 1 microfarad capacitor across the 20K resistor. That will start filtering at 8 Hz (8 vibrations per second, still high for hand movements). If that doesn't do anything noticeable, try 10 microfarad, etc. If you go too high with the value it will respond very slowly, though, so you have to find a good value for the response you want.
Aug 15, 2008. 11:21 AMtewfik says:
yes, a low pass filter will do fine, also you will decrease the cutoff frequency of your system and thus you won't sens rapid movements / variations (well, this is the role of a low pass anyway)
maybe a bit of processing on the microcontroller would be nice too
i find that moving average filters give good results, and maintain a good level of accuracy
if you want to have some "high"-tech filtering, try kalman filters, this is like magic ! kalman filters can handle high frequencies while rejecting noise effects without disturbing the system dynamic, also, a bit pain to implement , especially on 8bit systems
Moving Average - Wikipedia
Kalman Filter - Wikipedia
Apr 7, 2009. 7:49 AMgerritzalm says:
Hi, Currently i'm building the sensor for a graduation project, but I have big problems finding the Velostat in the Netherlands/Europe. Any advice to replace it/use different material(s) or a fine webshop? Thank you very much
Mar 16, 2009. 8:17 PMvitorls says:
Hello
I´m very happy with the bend sensor you send to me.
Now I try to construct more with your very good instructable. It´s not easy because the materials is dificult to find, but i thing i can go to the end.
I go use the bend sensors in this project: http://fotocrono-fatosensivelwireless-vls.blogspot.com/
before i made a glove with a normal bend sensors, but now I made suit that i´m going to use your sensors for i read some moviments of the body. The ideia is to translate the moviments to generate sound poetry.
Thanks again
Vitor LS
Thanks a
Mar 17, 2009. 11:16 AMvitorls says:
Hello Hannah I´m from a litlle step to find all materials to construct the bend sensor. I only miss the velostat. Of course I know your project: Puppeter. It´s because of that I discover your bend sensors. When I discover that project I´m very happy because I saw for the first time that it´s possible to do something similar to my ideia. That project its clouse to my project, and in the Puppeter project I see its possible to do. In my project the main diference going to be in the content, but maybe I go use accelerometros and gyroscopios. I go use sound poetry, disconstruct and construct again the phrases. My intention it´s try to revel one occult truth from the body language. Your project It´s became very inspirer and give me confidence to start, and for that i say thanks again! I do this for my master course and I hope you don´t mind if I make reference to your very good work. Thanks for you like my loveGlove. I will send to you my upgrades from my bloog. bye Vitorls
Feb 28, 2009. 7:47 AMtechie says:
I was thinking that you could have these sensors in your clothing attached to a battery powered Arduino. Then you could program it with the 8x8 led controller from Modern Device (http://moderndevice.com/) to create different patterns of leds sewn into your clothing. It could be quite interesting at night.
Great instructable!
Mar 10, 2009. 4:11 PMtechie says:
Yes, I was using you in an indefinite sense of anyone reading the post. I am thinking of some sort of display. I just got some velostat and am anxious to create some sensors. In the dance project, did you find that the sensors fatigued over time and had to be replaced? Leah Buechley's work is quite wonderful. Thanks for the link! cheers
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
333
Author:Plusea
