3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Fabric Bend Sensor
Step 8Software Visualization
  • last photo ←
To visualize the change in resistance in the bend sensor you just made you can also hook it up to your computer via a microcontroller (Arduino) and use a little bit of code (Processing) to visualize it.
For Arduino microcontroller code and Processing visualization code please look here >> http://www.kobakant.at/DIY/?cat=347
See the orange bar in the pictures. How it is on the right of the computer screen when the wrist is bent. And at the very left when the wrist is straight!!
Have fun and thanks for reading. Let me know what you think.
9 comments
Mar 12, 2010. 5:14 AMkatsideswide says:
Hi! Thanks so much for your previous help, i've managed to get some velostat and "shieldit super" conductive fabric, but i've found that when i put a piece of velostat loosely between the two layers of shieldit, it bridges the gap instantly and reacts as though i'd connected input 1 to ground. When the wires are unconnected the whole graph just wiggles all over the place. Have i got the sensitivity wrong somehow?
I think i need a multimeter.
Huge thanks,
Susan
Mar 12, 2010. 9:57 AMkatsideswide says:
Hello,
Thanks for your advice! I've tested it with a 9v battery and an led, it gives a great response! (although it heats up a little...) I'll fiddle with the resistors as you recommend, although i can't find the option for the internal resistor, is it in the arduino sketch or the processing sketch?
-Susan
Mar 12, 2010. 2:54 PMkatsideswide says:
Ah! i've got it working! thank you so much!
Oct 7, 2011. 4:27 AMRichuk says:
Hi Plusea,
The links you posted appear broken, do you have them still.
Many thanks in advance!
May 8, 2011. 8:15 AMcuchara says:
Hi Plusea,
i really like your work, it's awesome!
I've followed your instructables and managed to build a bend sensor which I am now trying to visualize. The site to download the code and application does not exsits though.. :( Did you move the code somewhere?
Thank you and keep u the amazing work!
Cuchara
Aug 30, 2011. 2:50 AMghough says:
You could use the standard Arduino Analog Input code, albeit slightly altered, to find the bend. I did it this way and then I was able to visualise it in Blender using a simple python script that read the bend sensor value from the serial port and applied it to the movement of an object.
This is just an alternative option in case you can't find the code of course.
May 17, 2011. 11:55 PMwindrago says:
I have the same issue - cuchara, did you manage to find the files for the visualization?
thx
amok
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
346
Author:Plusea
