3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Fabric watch-strap cover
Step 7Put pieces together
Put pieces together
Now it's time to start putting your watch-strap together.
Lay one of your main strap pieces right side up. Then position the two tunnel pieces, wrong side up, aligned with one edge. Your template may help you see where to place them along the edge, as in the picture. Match up the pattern if you are doing that.
Remove the template (without disturbing the pieces) and place the other main strap piece, wrong side up, on top of the first. Again, match the patterns if appropriate. Pin the pieces together, and then tack them together with a contrasting colour of thread. You can skip the tacking, but it will produce better results, particularly if you are using a sewing machine for the next bit.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:kicking_k
